JBL ES-150-P standby issue
  • proditaki
    • Aug 2023
    • 18
    • Netherlands
    I recently bought a faulty JBL ES-150P subwoofer that was completely dead.
    After replacing 2 open resistors (R255 and R256) in the DC Power supply the unit started working.
    It plays fine. But when it wants to go into standby mode, after 10 minutes, it starts cycling for a while. (see video on youtube)
    The noise from the speaker goes away and i'm pretty sure the interval changes and i only hear one relay clicking on the end (light still goes red/green)
    After cycling for like 30 secs to a minute it eventually goes into standby. It also wakes up fine when you present an audio signal. (Above also occurs without a source connected to the LFE /Line in)
    I'm at a bit of a loss
    Datasheet attached.
    So far replaced
    R255 / R256
    C162 / C161
    C166 / C167
    C134 / C136
    U103
    So far checked
    C168 C169 C170 C171 (ESR good)
    C131
    C132
    C126
    U101
    Q103
    Q102
    Q101
  • debruina
    • May 2020
    • 29
    • Nederland
    Re: JBL ES-150-P standby issue
    1. Check C16/C18 ? 10uF np
    2. If it has brown glue on the board, remove it
    Picture would help
    • proditaki
      • Aug 2023
      • 18
      • Netherlands
      Ok. I took some pictures. I already had it reasembled for testing
      • proditaki
        • Aug 2023
        • 18
        • Netherlands
        Picture would help
        The ESR on C16 and C17 is fine. i removed them from circuit to test. Well within spec.
        • proditaki
          • Aug 2023
          • 18
          • Netherlands
          Also replaced C18 & C19 but no difference.
          • debruina
            • May 2020
            • 29
            • Nederland
            If it has sound than probably the amp board is Okay. Did you check +15/-15 voltages? manual page 30/31? caps, next i would check the mute circuit.
            It's more or less the same amp used in those HK subwoofers. Eventualy they all fail. The glue in you pictures is still white. When it becomes dark it becomes a conductor. Then you get all kind of strange problems. Yours looks still okay
            • proditaki
              • Aug 2023
              • 18
              • Netherlands
              Yeah the sound seems fine.
              I did check the caps on the +15V lines and replaced some (which were borderline faulty) by new ones (which i checked before replacing) but to no effect.
              Id did check the "big" caps on vcc+/- and vbb+/-
              so yeah probalby something in the mute circuit.
              i already replaced U103 for a brand new opamp (you see it sitting in a socket in the pictures i took because the pcb traces are quite fragile and i didnt want to have to desolder it twice)
              i did measurements on Q101, Q103 adn Q102 they seem fine.
              • proditaki
                • Aug 2023
                • 18
                • Netherlands
                Ok i fixed it.
                The service manual was rev 0.
                In the revision i have they changed a few things and they use a 6v power supply for the mute/standby circuit, which i completely missed because the 15v power supply is still there (obviously, it's just disconnected from that circuit ) .
                THe +6V / -6V power supply was more like +4.5 / -7V because of one failed cap. So i replaced them all, it's working fine now. Thanks!
                • cyberdyne82
                  • Jun 2024
                  • france
                  Bonjour, Je me présente rapidement dans un premier temps. J'ai une petite quarantaine d'année, developpeur web. Je suis un grand fan de musique et de film en tout genre.
                  Je possède un enssemble home cinéma JBL Northridge E80 depuis plus de 10 ans. Depuis quelques semaines, mon caisson basse le ES150P a son système de stanby qui bug. En effet il est censé se mettre en veille au bout de 10min plus ou moins. Maintenant, il n'y a plus les 10 minutes donc lorsque je regarde un film, écoute de la musique il s'allume et se met en standby toutes les secondes presque. Lorsque je met de la musique ou un film avec des basses il ne s'éteint pas et le son est excellent comme au début.
                  Je ne suis malheureusement pas du tout connaisseur en électronique, je n'ai pas de matériel également et JBL ne peut rien faire pour moi car les pièces d'origines de rechange n'existent tout simplement plus.
                  Je suis presque sur que ce n'est pas grand chose. Si jamais quelqu'un habite sur Paris et peut m'aider ça serait très gentil.
                  Let me introduce myself briefly. I am in my early forties, a web developer. I am a big fan of music and all kinds of movies.
                  I have owned a JBL Northridge E80 home theater system for over 10 years. For the past few weeks, my subwoofer, the ES150P, has been experiencing a standby system issue. It is supposed to go into standby mode after about 10 minutes. Now, it no longer waits 10 minutes, so when I watch a movie or listen to music, it turns on and goes into standby almost every second. When I play music or a movie with bass, it doesn't turn off and the sound is excellent as it was in the beginning.
                  Unfortunately, I am not knowledgeable about electronics at all, and I also do not have the necessary equipment. JBL cannot help me because the original replacement parts simply no longer exist. I am almost sure it is not a big issue. If anyone lives in Paris and can help me, it would be very kind.​
                  • marx30
                    • Oct 2024
                    • 3
                    • Poland
                    Ok i fixed it.
                    Hello proditaki. I have exactly the same problem
                    Could you tell me which caps did you replaced? They are on preamp board or little board near to power plug?
                    • marx30
                      • Oct 2024
                      • 3
                      • Poland
                      It is probably cap 220 uf on preamp board
                      • kamueone kamue
                        • Jun 2025
                        • germany
                        MY SOLUTION
                        Hi to all,
                        I have expirenced the same Problem. After a while the Sub wanted to AUTO Standby, and gone nuts. Cycled endlessly On and OFF or did not come ON after OFF.
                        I did not like that AUTO Standby so i disabled it completly.
                        Just cut one of the legs of the Resistor R142.
                        The Capacitor does not get any current to fill him self up, and if that does not happen nothing else Triggers. So Always ON. Just unplug when not needed or POWER OFF.
                        If you need the AUTO OFF Function just replace C131 - Capacitor (220 µF, low leakage) - LOW LEAKAGE EC 220uF 16V ±20% (RoHS)
                        For those that want to know why this works:
                        🔬 Technical explanation – RC time constant
                        The Auto-Off feature in the ES150P works using a standard RC timing circuit (resistor + capacitor), which delays switching based on signal absence. The timing is determined by this formula:
                        τ=R×C\tau = R \times Cτ=R×C
                        In this case:
                        • R142 is the resistor
                        • C131 is the capacitor (220 µF, low leakage)
                        • The voltage across C131 slowly changes when no audio signal is present.
                        • When that voltage crosses a threshold (usually into an op-amp or comparator like U103), the circuit triggers the Auto-Off state.
                        🔁 What happens if you remove R142?
                        R142 present (e.g., 330 kΩ) Auto-Off works after ~10 minutes
                        R142 increased (e.g., 10 MΩ) Auto-Off takes much longer (30+ mins)
                        R142 removed (open circuit = ∞ Ω) No current can charge/discharge C131 → Voltage never reaches trigger level → Auto-Off never happens
                        In other words, the capacitor never reaches the voltage that tells the circuit to shut off.
                        📘 Verified by Service Manual
                        The JBL ES150P Service Manual, page 12, says:
                        Auto-Off Function → Check U103, Q101, Q102, C131, R142
                        This confirms that R142 and C131 are essential parts of the timing circuit. If you remove R142, you break the circuit — the timing voltage never changes — so the Auto-Off logic can't do its job.
                        HOPE THIS HELPS
                        • SuperJames
                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                          by SuperJames
                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                          Specs
                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                          Backstory
                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                          10-23-2023, 04:09 PM
                        • high-tech
                          Samsung UN55F7050AFXZA ver. TD01 power cycling
                          by high-tech
                          Hello everybody, I could use some help on this one... It's got me guessing...
                          I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                          (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                          (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                          (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                          (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                          9. ground (PWM2) 10. 0.9 volts cycling...
                          09-15-2020, 03:39 PM
                        • Drewwol11
                          Samsung QN49Q70RAFXZA Power Cycling Issue
                          by Drewwol11
                          My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
                          I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the...
                          08-31-2021, 09:32 AM
                        • rounin
                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                          by rounin
                          🛠 Original Issue
                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                          04-19-2025, 01:18 AM
                        • ugamazing
                          by ugamazing
                          12-17-2024, 07:05 PM
