Samsung UN55B7000WF - backlight present but no image
  • northwestdad
    • Feb 2014
    • 51
    • usa
    Re: Samsung UN55B7000WF - backlight present but no image
    have to head out so unable to do full check.
    voltage readings with TV on are 131.5 one way and 11.93 the other way. Does that sound better?
    Also...when checking the ohms. Putting the probes on either side of fuse got a reading of 000.0 one way, and then simply "Open" on the screen when I reversed them. No beep either way.
    I will need to check the other stuff when I get back home tonight.
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      Just for clarity,I numbered the fuse sides......(see pic)
      With TV UNPLUGGED: meter on ohm(beep mode),red probe on 1,black on 2,what is the ohm reading? And maybe reverse red and black also,read again...
      With TV plugged in and ON: meter on 20volt DC,black probe on chassis or a screw on the tv,red probe on 1=.... volts? Then with red probe on 2=....volts?
      **little confused here:
      I Assume you mean 13.15volts and not 131.5?
      Also,13.1`5 the one way,11.93 the other way? As in one side of fuse and then OTHER side of fuse or same spot but probes of meter reversed?
      000.0 one way,open with probes reversed,that almost sounds as if your measuring a diode(unless a diode is parallel to the fuse,seems unlikely)
      I hope you don't measure OHMS while tv is ON,cause you can't do that...**
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        Hurry back,we're not done electrocuting you...
        • selldoor
          Slow Learner
          • 7870
          131 volts on a tcon - yes?
          No !!
            May be 131.5mV? Need to see the meter, I can also tell that the meter was not set to 20V scale otherwise it would have shown OL, it is more likely to be in the auto-range mode. Invalid reading or not proper reporting what it is showing on the scale (I.E. mV, V, etc.) is always hard for us to help troubleshooting the problems.
            • northwestdad
              • Feb 2014
              • 51
              • usa
              #26
              TV unplugged measuring ohms as described above: 12.8 first way, 0.F apears the 2nd way (over range I assume)
              TV plugged in and powered on and measuring volts: 11.93 one way and 131.2 mV the other way. My meter is on AUTO
                "TV plugged in and powered on and measuring volts: 11.93 one way and 131.2 mV the other way. My meter is on AUTO" Do you mean one end of the fuse show 11.93VDC, and the other end of the fuse shows 131.2mV? Sounds like blown fuse.
                • northwestdad
                  • Feb 2014
                  • 51
                  • usa
                  #28
                  Yes budm. That is correct. 11.93 V one way and 131.2mV with the probes reversed.
                  • selldoor
                    Slow Learner
                    • 7870
                    #29
                    I would say the fuse is open ( bring back the $5 meter )
                    • northwestdad
                      • Feb 2014
                      • 51
                      • usa
                      #30
                      Does this confirm the issue is with the tcon? In particular this tiny fuse?
                        Yes. So you have bad fuse or the load connected to the fuse is bad and causes the fuse to blow, the shorts may not show up when measuring the resistance on that end of the fuse that show 131mV and ground due to other active device that is not turn on until power is applied. Do you know how to use your meter current measuring mode (10A DC mode)?
                        • northwestdad
                          • Feb 2014
                          • 51
                          • usa
                          #32
                          Budm...you are referring to the 10A Max slot on my meter? I know how to set it up but am not familiar with using it. Again, very little experience using a multimeter except for high school science class back i the 80's. I do't mind probing around the tcon or main board, but would not be comfortable examining the powerboard with the TV plugged in.
                            I think the best way right now is to get a 4A fuse from Radio Shack or car fuse, then solder the wires to each end of the fuse, the other end of the wires will be soldered to each end of the blown fuse, no need to remove the old fuse, wrap the new fuse in electrical tape, and see if it will function.
                            BTW, look at the LCD panel and find the sticker that will show the model number of the panel so we look up the spec sheet for it.
                            • northwestdad
                              • Feb 2014
                              • 51
                              • usa
                              #34
                              I should be able to do that.
                              Here is the label info too
                              thank you all for your help and input
                              • northwestdad
                                • Feb 2014
                                • 51
                                • usa
                                #35
                                Well...the issue can now be confirmed that it was this tiny "N" fuse that was faulty. I built a separate 4A fuse and soldered it to either side of the open fuse. I now have an image!! However...when I turned the TV for the first time after creating the fix, there were a couple sparks as a different component on the right side of the board fried (I was not able to see any obvious damage, but I saw the spark and smelled the burnt component). Regardless...the display continued to work perfectly and and no other issue was noticeable. I kept he display going for about 30 minutes before shutting down and unplugging. Without knowing what blew, or it's significance, I will just purchase a new TCon board so I can rest knowing my house isn't going to burn down.
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  #36
                                  Maybe whatever sparked - dry joint or whatever was what blew the original fuse
                                  the one you have in now is perhaps more forgiving.
                                  I think new board is a wise decision - if nothing else saves you having to dismantle it all again.
                                  Make certain you get the exact same board as per the barcode label and
                                  try and get the seller to confirm it will work with your panel.
                                  Quote them the info from the panel label.
                                  Let us know how you go on.
                                  • northwestdad
                                    • Feb 2014
                                    • 51
                                    • usa
                                    #37
                                    Board number is 35-D043524 per the label on the board itself. Interestingly all the boards with the same number I have found online are for a different model of this TV (UN55B6000).
                                    • northwestdad
                                      • Feb 2014
                                      • 51
                                      • usa
                                      #38
                                      Forum experts...any thoughts on the T-Con board number being referenced for a different model of TV? There are certainly a lot of boards out there that say they're for the UN55B7000, but literally everything I've found with the part number printed on the label for my board is for the UN55B6000. Any chance they put the wrong board in at the manufacturer and that is why the fuse crapped out?
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        #39
                                        No Expert but I have looked and find the same - however the other Tcons that fit yours
                                        also appear to fit the 6000 model so on that basis yours should fit both as well.
                                        Personally I would just fit or have someone fit the correct fuse - they do blow just out of old age - bit of a power surge and exposure to heat.
                                        • northwestdad
                                          • Feb 2014
                                          • 51
                                          • usa
                                          #40
                                          I'm finding these boards online for anywhere from $45 - $95 USD. I feel I would have to pay someone at least that much just to replace the fuse, or spend twice as much on higher quality soldering equipment to do it myself, so simply buying a working board is something I don't have a problem doing, especially when considering I was given the TV for free.
                                          Also...I got into the service menu to see how many hours of use it had and was shocked that it has nearly 14,000 hours. This was purchased by my company in 2011 and mounted in the conference room and was hardly ever used except to hook up to a laptop for large screen presentations 1-2 times per week. I suspect that since the screen would go blank after being disconnected from the laptop that folks forgot to turn the TV off and it would remain powered on for days or weeks on end.
                                          • alro7779
                                            Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
                                            by alro7779
                                            Hello there!
                                            Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
                                            08-07-2025, 11:53 AM
                                          • wolf1976
                                            samsung ue40d6100 has no backlight no sound and image
                                            by wolf1976
                                            hi to all
                                            on the above model of samsung i have the faults i have told already on the title
                                            iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                                            any idea from someone what can i measure so i can find the problem ?
                                            the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                                            11-17-2024, 01:02 PM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                          • mi16rs
                                            SAMSUNG UE32M4005AW BACKLIGHT OK BUT NO IMAGE
                                            by mi16rs
                                            Hi i have a samsung UE32M4005AW that have backlight but no image , i have changed the main board but still the same problem , so i guess it as a fault on the panel board , could some one help me on this ? thanks...
                                            02-08-2024, 03:19 AM
                                            09-07-2024, 05:50 AM
