Samsung UN55B7000WF - backlight present but no image
  • vargas_otero
    • Mar 2016
    • Puerto Rico
    #41
    Re: Samsung UN55B7000WF - backlight present but no image
    Hi, I find the fuse blown in t-con board. But I can't determine the value in amps on this.
    • alro7779
      Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
      by alro7779
      Hello there!
      Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
      08-07-2025, 11:53 AM
    • wolf1976
      samsung ue40d6100 has no backlight no sound and image
      by wolf1976
      hi to all
      on the above model of samsung i have the faults i have told already on the title
      iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
      any idea from someone what can i measure so i can find the problem ?
      the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
      11-17-2024, 01:02 PM
    • rimwall
      Sony KD-65x7500D - double image - Tcon or Panel?
      by rimwall
      This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
      I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
      11-18-2025, 02:09 AM
    • mi16rs
      SAMSUNG UE32M4005AW BACKLIGHT OK BUT NO IMAGE
      by mi16rs
      Hi i have a samsung UE32M4005AW that have backlight but no image , i have changed the main board but still the same problem , so i guess it as a fault on the panel board , could some one help me on this ? thanks...
      02-08-2024, 03:19 AM
      09-07-2024, 05:50 AM
