LG OLED55CX Clicking No Power
  • cheebster
    • May 2008
    • 373
    Hello, i have this OLED here, as the topic says OLED65CX.
    TV shows standby led, when pressed the PSU clicks, then shut down.
    Disconnecting the 12V VIN from the T-Con, make the TV boot up, led flashes like normal and it stays on.
    What i've tried so far:
    I have a working TV, an OLED55C1. Similar TV... Took all the boards to the C1, 1 by one, and everything works. So basically, all of these boards from the defective CX (PSU, Main, TCON) works either 1 by 1, or together on the working C1.
    However, none of the C1 boards work on the CX, same issue remains. Only thing that changes, the C1 mainboard doesn't even try to boot on the CX panel, it stays red solid.
    I have the OLED PANEL TESTER 2022 little jig by LG as shown here : https://www.youtube.com/watch?v=6kNcFzLZzmM and when tried, i get the CX panel to show all colors, no problem there.
    So basically:
    PSU tested OK on another TV
    Main tested OK on another TV
    T-Con tested OK on another TV
    Panel tested OK by LG testing Jig.
    My logic fails here. It still points at the panel itself though, but IDK what to try next. It seems the LG diag jig isn't that reliable after all ?
    I also tested cleaning the FPC flexes connections to the panel from the T-Con, the cables. No luck..
    The CPU on the CX shows no signs of having any kind of overheating damage either (well, it works on the C1 too)
    If anyone has an idea on this one ! Thanks..
  • Diah
    • Feb 2013
    • 6376
    you have one or more OLED Cells pulling more currents which trick the T-CON error detect and send it to MB MICOM PIN 6 as i remember to shutdown the TV.
    Korean they play with JIG .. but they didn't offer SW to remove this error detect so user can remain use his TV when it show no lines or big damage on screen... for example Philips do give file for this removal on OLED sets.
    so if you have clean screen displaying the pattern then yours only way to manually disable this rail between T-CON and MB. at t-CON side
    • Diah
      • Feb 2013
      • 6376
      one things more.. you got until now good experiences with OLED so you know how to start with Panel buffer boards
      • cheebster
        • May 2008
        • 373
        Hello, thanks for your replies Diah. Buffer boards, well they are hidden under metal it's kinda hard.
        Ok so, to bypass the error detection, you say micom pin6.. I found this on the T-CON, pulled the pin on the connector backside, still does not power on.
        Do we have an idea on how to bypass the error detection ? I have tried this rail also on a defective sony oled, but it doesn't power on. Cutting the track doesn't do the job it seems
        Do i need to ground this pin ? Is there any reliable pinout/schematics of these connectors/tcons available ?
        • cheebster
          • May 2008
          • 373
          Oh, i got the tv running! Running out of time this morning but messing with a small piece of tape, i think pin 41 blocked will confirm. What i can tell now, is that tv powers on and image is great.
          Will also check service menu to find out what's happening, what faults were recorded in the main.
          • Diah
            • Feb 2013
            • 6376
            it would be nice of you to explain with photo to other new user so they know what we are talking on.
            i wrote before now you are expert with OLED .... enjoy
            • cheebster
              • May 2008
              • 373
              Hi there, yes sure. TV works fine, and by inspecting the frame i see a missing bit of paint near the right corner, bottom. When i press the panel the picture gets distorted (prolly a short between frame and cof or similar. By using a piece of paper slided between panel and metal frame pressure does not create fault anymore.
              So here is a picture of the service menu showing the BDP errors telling the tv power on problem was a panel fault. However, now it's restored to full usage. Not an expert by any means imho !
              Thanks,
              • Diah
                • Feb 2013
                • 6376
                you have burn image on screen i can tell from photo... if this the case you need to send IN_STOP , or downgrade then update complete firmware.
                • Diah
                  • Feb 2013
                  • 6376
                  did youown now the JIG tool ? i would like to DIY it to be easy tool to users test OLED Panel and its T-CON, the top side we do know and we did it in different way to switch PW_ON & TCON_ON & DRV_on... but the interesting to have the downside of tool if there eeprom to switch pattern or just in_circuit dummy and the rest T-CON do it within eMMC
                  any one have an idea and this tool please update the downside... at least we will have cheap tool for all
                    • 12208
                    • U.S.
                    Ok, so to be clear, you had a panel problem, using the piece of paper made it work correctly. Does this mean you no longer need the piece of tape that you used to block the signal?
                    • bohaboha
                      • Nov 2012
                      • 1000
                      • sweden
                      nomoresonys i think it was that because he did not talk about the tape anymore and i did use that solution long time ago
                      • cheebster
                        • May 2008
                        • 373
                        Yep, using this tool Diah and the backside doesn't have any form of chip or anything just the pcb, very simple tool indeed. Yes nomoresonys i used tape on pins 39-41 to block the signal. I also found the panel fault, on right side coner an object hit it, so it creates a short under the panel. I slided a soft plastic piece between metal frame and panel corner, prevented the short (i could make it freak out by pressing the corner) and now even with pressure i isolated the fault. Tv works like new !
                          • 12208
                          • U.S.
                          Thanks Bohaboha and Cheebster.
                          • bohaboha
                            • Nov 2012
                            • 1000
                            • sweden
                            good to know a piece of tape and the tv works again
                            • x_orange90_x
                              TCL 50S535 bad tcon or panel issue?
                              by x_orange90_x
                              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                              03-29-2025, 11:02 PM
                            • Oled_gambler
                              LG OLED; Component-level repair on OLED panel?
                              by Oled_gambler
                              So I gambled and (likely) lost $200 on a pair of OLED C1 televisions, hoping I can Frankenstein them into 1 working unit.
                              one had a physically-damaged panel and the other had a panel that would display normally (with the exception of a single vertical white line down the left-hand side) but turn off after around 10 seconds. I believed I would find an overheated processor (common on the CX) or a failed power board (also common).
                              Swapped the power, mainboard, and T-con from the dead panel TV and issue persists.
                              Looks like the actual panel is at fault. I can...
                              11-22-2024, 03:58 PM
                            • advant
                              by advant
                              02-03-2020, 12:25 AM
                            • mmartell
                              General Questions on the Relationship Between Mainboard, TCON and Panel
                              by mmartell
                              My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                              I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                              And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                              01-06-2024, 01:32 PM
                            • AK_777
                              Sony KD-65A1 Repair – 4 Red Blinks Error
                              by AK_777
                              Hi everyone!
                              I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                              Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                              02-20-2025, 04:15 PM
