LG OLED; Component-level repair on OLED panel?
  • Oled_gambler
    • Nov 2024
    • UNITED STATES
    So I gambled and (likely) lost $200 on a pair of OLED C1 televisions, hoping I can Frankenstein them into 1 working unit.
    one had a physically-damaged panel and the other had a panel that would display normally (with the exception of a single vertical white line down the left-hand side) but turn off after around 10 seconds. I believed I would find an overheated processor (common on the CX) or a failed power board (also common).
    Swapped the power, mainboard, and T-con from the dead panel TV and issue persists.
    Looks like the actual panel is at fault. I can use a piece of tape to block the shut-down signal to the mainboard to keep the tv from shutting down, but i'd like to attempt a component-level repair on the panel to restore the signal to that column of pixels.
    Is there any information out there about this?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4521
    • Italy - Milan
    The only thing i wish to know is if the faulty line is single pixel width and if the change of tcon made some changes to that line, the rest this time i will leave other users to answer first, i don't like to share my opinion and systematicly watch them not followed, good luck...
      Gigabyte AERO 16 OLED BSF-73DE994SO Notebook Specification for Upgrade or Repair
      This specification for the Gigabyte AERO 16 OLED BSF-73DE994SO Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-73DE994SO boardview and 16 OLED BSF-73DE994SO schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-07-2024, 06:38 AM
    • howardc64
      LG 49UJ6500 LCD panel lighter band that goes away
      by howardc64
      49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
      Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
      02-19-2023, 12:13 AM
    • triplefour
      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
      by triplefour
      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
      tcon is built into mainboard.
      Only one cable goes to panel boards.
      there is a cable from one panel board to the other that links them.
      cost cutting measure that results in us having harder time to diagnose.
      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
      07-28-2022, 07:59 PM
    • Storyteller12
      QN55Q60R Service Menu Panel Help
      by Storyteller12
      I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
      I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
      I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
      the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
      01-13-2024, 01:57 PM
    • Cento50
      OLED 55B6V only audio panel is black
      by Cento50
      OLED no display
      Lg oled 55b6v
      Hello friend to badcaps thank you for register to this forum.
      I have this problem.
      1- 24v go to 0v If have connected 4 flat cable panel and TV have only audio. And result D18 shorted.
      If disconnect 24v cable to tcon have this: TV on only audio. And result d18shorted.
      Vpres have short circuits, if disconnect 4 flat cable the diode D18 result good.
      Vpres is shorted and connected to tcon lock the 24v in protection. Have solution for investigate this little board?
      Thank s...
      10-12-2022, 02:50 AM
