LG 86UK6570PUB 3 Red Blinks
  • ChattFix
    • Oct 2021
    • 79
    • US
    Originally posted by Diah
    Dont Touch the Mainboards... there are wrong info written from one user.. this set. are ONE SoC. there are no T-CON on MB... it had separted T-CON.. LVDS damage make the panel in test pattern.
    show me the 2 LVDS contact Pins from both side.. don't trust your glasses..
    if some one never had this set under his hand should keep silent
    Here are the cables under my scope.
    • Diah
      • Feb 2013
      • 6363
      clean them.. the black spots . but be careful as they are dry now... this set have many issue resulted with LVDS cable... but you need to repair the LED BL... and check the 4 ribbon cable too from both side to clean them..
      PFC from Main SoC stoped working because of error on LED BL.. so no signal go to T-CON. only VCC 12V will be on T-CON... this condition are the same when we testing the T-CON & Panel as standalone... EGB pattern will show.
      MB cant captured .. because this action only need JTK Module from LG.
      on MB you have eePROM and eMMC, the eePROM sending the start so you have Power ON ... and tthe rail of 13V will be provided to Panel T-CON via IC1100 ... so every things sound good..
      this why i wrote don't Touch the MB unless you repair the LED BL
      • ChattFix
        • Oct 2021
        • 79
        • US
        Okay so clean the copper pins, then replace the all of LED backlights correct?
        • Diah
          • Feb 2013
          • 6363
          YES
          • ChattFix
            • Oct 2021
            • 79
            • US
            YES
            Should I pay the extra on ShopJimmy for quality or does it matter?
            • EazyBone
              • Jun 2023
              • 1321
              • United states
              #26
              Just buy em on eBay. Shopjimmy takes them out of new tvs, so essentially all are used anyway. On eBay at least they are new and significantly cheaper. I've had better luck on eBay then shopjimmy TBH.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4318
                • Italy - Milan
                #27
                Oh my god... that's incredible..
                1) i see what the user shows me, i saw 2 boards on picture, i thought it had only 2 boards also because of the 2 Twins lvds ribbons output, i cannot know every hundreds tv models in the world! User Diah must calm with its words, i have never hamed a tv.
                2) It's fool to dismantle Cyclope's tv for the doubt of bad backlight, and i do not see any sign of that, much more safe and easy to do the test i have already said, 2 minutes test!
                3) I have never seen in long hobbist career a tv set that enables tcon power but not tcon input data due to bad BL and no BL, that is nonsense words, some people lives only to be present on a forum and shots their s*itting everywhere..
                4) Tcon auto test not called is a common fault and can depend, for me, by many reasons including bad tcon (most common), but in this case with no BL it belongs more to a bad main board case, so post a decent (much light) picture of tcon, i guess a Monster tv have power source directly from power board, this could explain why tcon is fed by power but without data, MB can turn on power but software doesn't provide data, 3 blinks spy led can tell standby software is working but not full software..
                5) Power board has no clear feedback pin to MB for BL working state, so i guess software can't stop due to BL issues, there is a mistery pin MS that is more common back light activation (always present in every tv)
                • Diah
                  • Feb 2013
                  • 6363
                  2) It's fool to dismantle Cyclope's tv for the doubt of bad backlight, and i do not see any sign of that, much more safe and easy to do the test i have already said, 2 minutes test!)
                  the fool here who read and write with out understanding LG TVs Plat Forum,.. & the different between Analogue & Digital Circuit.
                  more doesn't worth to write..
                  • nubinator
                    how can i test individual leds without tester
                    by nubinator
                    Hello I have TCL 65S4 and it has no backlight, seems common problem on this tv to have bad LED's. I have no tester though I thought I could just test each LED with 2xAA batteries for 3v but it doesnt light up at all?
                    I saw a vid with LED tester on this TV and it had 130v for 1 good line which is 24 LEDs does that mean it needs around 5.5v per LED?
                    10-25-2022, 11:05 PM
                  • tmhobadcap
                    TCL 65S403 Backlight LED Question
                    by tmhobadcap
                    I got the TV from a friend. He claims that no image but sound from the TV.
                    I confirmed that when shine a flashlight on to the screen, I can see the image. And this should be backlight problem.
                    I open up the TV and found a few leds failed. And now I am ordering a new set of backlight strips for it.
                    But there is something that I do not understand when checking the leds. I do not have an led tester. I only use a bench power supply. I first set the voltage to 3V and current to 10mA. I could not light up the led until I increase the voltage to 12V. I understand most...
                    05-25-2025, 11:03 AM
                  • Pipolups
                    Corsair K70 LUX RGB dying LEDs
                    by Pipolups
                    Hi there !
                    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                    10-08-2024, 11:58 AM
                  • edugimeno
                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                    by edugimeno
                    Hi There!
                    I'm trying to help my friend who owns a restaurant be just bought.
                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                    09-05-2024, 09:34 AM
                  • Misterfixit
                    Sharp LC-58Q7330U No Backlight
                    by Misterfixit
                    This set has the known reputation of failed led backlights. The set does not turn on, but when plugged in, the power led stays lit for about 5 seconds followed by two short blinks and then it repeats itself. While shinning a flashlight on the screen, you can make out the Sharp logo, then it goes out and repeats the cycle. I measured some voltages across the led backlight connector. What has me puzzled is that when I place the negative lead of my vom on the led backlight pin connector (in which the black wire going to the leds was), I measure as high as -228volts, and then it falls to -95 volts...
                    06-04-2023, 07:39 PM
