so i have this TV and it turns on but all that happens is the LED turns on but not picture on the screen and i have no idea why this is happening, i have attached some pics if that will help anyone.
lg 46LD550
Re: lg 46LD550
I am not sure if this power supply inverter board combo has built-in pull up resistors on the PS_ON and bl_on PIN or not, so for quick test, unplug the TV from the outlet and then disconnect the cable between the power supply board and the main board, then plug the TV into the outlet to see if the backlights will come on.Never stop learning
Re: lg 46LD550
Originally posted by budm View PostI am not sure if this power supply inverter board combo has built-in pull up resistors on the PS_ON and bl_on PIN or not, so for quick test, unplug the TV from the outlet and then disconnect the cable between the power supply board and the main board, then plug the TV into the outlet to see if the backlights will come on.
Re: lg 46LD550
"i disconnnected the cable from the two boards and the red LED light would not come on after i plugged it in to the wall again." that is normal because we remove the power feeding the main board you removed the cable. So the backlights did not come on then?
Next we will need to test the voltages.Never stop learning
Re: lg 46LD550
Originally posted by budm View Post"i disconnnected the cable from the two boards and the red LED light would not come on after i plugged it in to the wall again." that is normal because we remove the power feeding the main board you removed the cable. So the backlights did not come on then?
Re: lg 46LD550
Re: lg 46LD550
http://www.shopjimmy.com/media/catal...9506-top_2.jpg
On that white connector p201, you need to check the DC Voltage on the 'POWER' pin, use the metal chassis as the ground ref point for the meter, you should see the voltage on the 'POWER' pin toggle betweedn < 1V and > 2VDC when the power switch is toggle on and off.Never stop learning
Re: lg 46LD550
Originally posted by budm View Posthttp://www.shopjimmy.com/media/catal...9506-top_2.jpg
Re: lg 46LD550
I have no idea what is available at Wallmart or Sears since I have never buy meter from those place before. Me someone can chime in. I would say $50~75 meter should be good enough for now.Never stop learning
Re: lg 46LD550
Originally posted by budm View PostI have no idea what is available at Wallmart or Sears since I have never buy meter from those place before. Me someone can chime in. I would say $50~75 meter should be good enough for now.
Re: lg 46LD550
On that white connector p201, you need to check the DC Voltage on the 'POWER' pin, use the metal chassis as the ground ref point for the meter, you should see the voltage on the 'POWER' pin toggle betweedn < 1V and > 2VDC when the power switch is toggle on and off.Last edited by ixiboneheadixi; 06-24-2014, 10:27 AM.
Re: lg 46LD550
Originally posted by Shinju View PostI actually do have a question, does your mainboard have a LED status light what color does it illuminate when you turn it on or apply power? your LG lay out is very similar to the 42LH50-UC unit I am currently trying to figure out!
