Sharp LC-60LE810UN
  • nicholas1110
    • Aug 2012
    • 127
    • usa
    #41
    Re: Sharp LC-60LE810UN
    Are you doing the reset correctly? In your first post you mentioned how you did the reset, but this is not the correct way to do it on this model. Here is the correct process.
    To reset the lamp error detection off mode
    1. Plug tv in.
    2. While the 1-1 blink is acurring, hold volume - and channel ^ , while holding the two, press the power on button.
    3. The v logo should shut off, release the buttons.
    4. Press the power on button, if the short in the led is taken care of the tv should turn and function.
    If this does not work, try to enter the service menu.
    1. Plug tv in.
    2. Press and hold volume - and input buttons, while holding them, press the power button.
    3. Tv will turn on, with the letter k on the screen.
    4. Press and hold volume - and channel down.
    5. Service menu will appear, you should see lamp error in the list, set to 0 if it is anything higher.
    The key to these procedures is pressing the power button while holding the other 2 keys. Older TVs you hold the keys down and plug the tv in. Which seems to be how you have been trying to do the reset procedure.
    I also suggest installing your original main board into the tv before attempting the reset.
    Hope this info helps.
    -Nick
    • sceamey
      • Dec 2014
      Originally posted by freakaftr8
      I have an idea I just repaired a 46 inch version of this TV also the sensor pads for the buttons are very sensitive and make sure that the circuit board behind the sensor touch buttons is properly pushed against the panel the plastic panel one of the either power button input button or volume down button are not being recognized. Best thing to do is get some Windex and clean the plastic panel where the sensor touch buttons are and then try again it's going to take some time but fiddle around pressing on the power input volume down and it will reset it's a pain in the butt but it will work eventually. I think this is what a lot of people having a problem with.
      How do I know if touchpad is the problem. I haven't gotten the tv to do anything just blinking light.
      • freakaftr8
        • Oct 2012
        • 3743
        It's hard to tell.but I used.my finger and rubbed across the sensor pad to create friction. just a real pain in the butt I had this problem on two of them for they were responding to the touchpad buttons and it turned out that it was a bad connection between touch pad and plastic panel. The TV should respond to the buttons if it's not it's definitely touchpad issue
        • gamethriller
          • Oct 2014
          • 153
          1. Plug tv in.
          1. Plug tv in.
          -Nick
          Thank you sir this worked for me.....
          • Jimbo2032
            • Nov 2015
            • usa
            #45
            Hey everyone, I'm Jim from Georgia.
            Sorry to play the part of necromancer here and bring up a zombie thread, but I was wondering if the OP is still satisfied with his repair?
            Is it still in operation?
            How is the color temperature vs the stock LED?
            If there is a difference, is it noticeable while installed?
            How about the brightness compared to the originals?
            Thanks in advance, lots of good knowledge on this site!
            -Jim
            • freakaftr8
              • Oct 2012
              • 3743
              I'm not sure about replacing just one LED if that's all you have out I just removed and bridged the one LED that was bad in my set and it's been running straight 24 hours for 1.5 years at my father in laws house. I just took the gamble since it was one led the voltage will climb ever so slightly on the rest of the LEDs on that strip but it has not caused an issue nor does it cause a functionality issue. And it still looks great. Just thought I'd throw that out there in case you only have one LED bad and if you do how much do you want to bet that is the top right LED on the top right side board
              • Jimbo2032
                • Nov 2015
                • usa
                #47
                I got mine apart, man that was a lot of screws, and discovered that not one but two LEDs have gone out on the right side bottom. The lenses were about to fall off.
                I think I'll go with the above mentioned LEDs as replacements.
                • djluis
                  • 12
                  #48
                  If I disconnect the switch panel, and leave the IR board coonected, should it turn on with remote?
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    If you dont have a blinking error code upon plugging it in then it should power up via remote.
                    but if im remembering correctly isnt the ir part of the sensor pad.
                    • cloo
                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                      by cloo
                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                      After doing a factory reset this problem was gone and the picture was back to...
                      01-06-2025, 06:02 AM
                    • EazyBone
                      Un50cu7000 2 blink oddity *partially solved
                      by EazyBone
                      I write this to maybe help another with this TV.
                      So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                      The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                      03-18-2024, 10:24 PM
                    • Mitike
                      SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
                      by Mitike
                      Hello guys,
                      I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
                      According to other sharp SM-s it is lamp error (I can't find SM for this model)
                      And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
                      If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
                      02-16-2020, 08:11 PM
                    • SdlewisSr
                      Sharp LC-80LE632U 2-5 blink code
                      by SdlewisSr
                      I have a Sharp LC-80LE632U with a 2-5 blink code. I have narrowed it down to the T-Con/Panel. I get the error if both or either ribbon cable is connected between the T-Con and the Panel. If I disconnect both ribbon cables, I get no error and the TV powers up just fine.
                      Does anyone know if this is a definite bad Panel or is there a chance that the T-Con could still be at fault?
                      07-11-2021, 07:36 PM
                    • c00lman
                      Sharp LC-90LE745U 3 slow and 1 fast Blink
                      by c00lman
                      hi, new member her and apologize if this has been discussed.. tried to search and most of the result are for LC-xxLe6xx series and not sure if it's applicable to the 745U.
                      the TV stopped turning on and after the V logo stayed solid for a minute or 2, it gives the 3 slow and 1 fast blinks which from what I researched are internal communication error.
                      did some voltage measurement on the power supply out.
                      Pin 1 and 2 = 0V --> PNL 12V
                      Pin 3 and 4 = 0 V --> GND
                      Pin 5 to 8 = 13V --> UR 13V
                      Pin 9 to 12 = 0 V --> GND
                      PIN 13...
                      06-21-2021, 05:18 PM
