CRT oscilloscope display problem !!
  • SM-Piyes90
    • Feb 2014
    • 120
    • Morocco
    Hi every one
    To be honest i was really confused where to put this topic and since the scope i got contains a CRT screen on it i thought maybe its a good idea to put it in this section , but any ways if its not mods can move it to the right section .
    Ok back to the heart of the matter .
    Today , as usual i was planning to use my scope to check the output signal of a PWM ic ( ka7550 ) , so i turned the scope on , connected the ground clip to cold ground , and tried to measure the output with the probe , and by mistake i shorted some pins of the IC .
    Now i get a constant trace leaning downward ( see picture bellow ), and i cant show any measured signals on the screen .
    Here is a list of the inside of the scope content :
    - CRT screen tube
    - Main card containing power supply and channel 1 and 2 voltage/ vertical position controls circuitry .
    - Side card containing HV CRT power transformer + time , sweep mode , horizontal position controls circuitry .
    • 30956
    Re: CRT oscilloscope display problem !!
    same problem on both channels?
    • SM-Piyes90
      • Feb 2014
      • 120
      • Morocco
      Yes , i get the same display on both channels , but the short was caused by probe on channel 1 .
        Have you tried adjusting the trace-rotate control? Does the ground lead still have continuity to the mains protective earth/ground? Have you tried other probes?
        • Ltank
          • Jun 2013
          • 776
          Most Scopes have Rotate trim pot on front or back of scope.
            I meant trace-rotate, not sure why I wrote trace-width!
            • SM-Piyes90
              • Feb 2014
              • 120
              • Morocco
              Hi every one .
              I can rotate the trace , but i can't get any signal to show up on the screen unfortunately ,
                • 30956
                you need a schematic to investigate the Y-amp but you still didnt list the make & model!
                • SM-Piyes90
                  • Feb 2014
                  • 120
                  • Morocco
                  Yes i forgot that , sorry , its HUNG CHANG 5502 20 MHz made in korea .
                  And here is a partial schem , i hope we can get something out of it :
                    "Today , as usual i was planning to use my scope to check the output signal of a PWM ic ( ka7550 ) , so i turned the scope on , connected the ground clip to cold ground , and tried to measure the output with the probe , and by mistake i shorted some pins of the IC " By any chance you are trying to make measurement in the Primary hot side of the circuit? Also if you put your probe on the scope 1KHZ output test port on the front of the scope you see nothing?
                    • SM-Piyes90
                      • Feb 2014
                      • 120
                      • Morocco
                      Nothing at all , by cold ground i meant IC's GND , the power supply i was testing is also out of service .
                      I still can't believe how a spark can cause this damage , i guess there should be some protection like a fuse or something , the IC i was testing has a max voltage of 12 Vdc
                        Is the IC in the primary side of the circuit?
                        Sounds to me that you are working in the primary side of the circuit so what ever you are working on should be connected to the isolation transformer so the the Line and Neutral are floated.
                        So right now the scope will not show any wave from when connected to the scope built in 1KHZ generator?
                        • SM-Piyes90
                          • Feb 2014
                          • 120
                          • Morocco
                          The IC is actually on the middle of the power supply ,taking power from the primary side and the output of the IC (ka7552) is connected to a MOSFET gate , i will post some pictures of the power supply later of course .
                          But the problem is i have already desassembled the scope , i didn't notice the 1 khz generator until now
                            • 30956
                            that schem is the gun-drive,
                            we need the other page(s)
                            • SM-Piyes90
                              • Feb 2014
                              • 120
                              • Morocco
                              Do you mean the card containing the HV transformer ? i only got this page btw .
                                • 30956
                                no, not the HV, there is a sheet with a connector caled p3something on it.
                                that handles the Y deflection.
                                if you look at the schem you posted at the tube, the Y coil wires are on the left and it just shows a connector to another board.
                                  • 30956
                                  o.k. i did some searching.
                                  they trade under the name "Protek"
                                  and i found a newer manual that may be close.
                                  • R_J
                                    • 9535
                                    May be the same as a Protek, stj ,you beat me to the manual
                                    • SM-Piyes90
                                      • Feb 2014
                                      • 120
                                      • Morocco
                                      Nice find stj , thanks a lot , i hope its similar to the 5502 .
                                      So right now after having disassembled the scope a part , i see two main cards :
                                      -one is related to the time control , horizontal control and contains a high voltage section, witch i guess is supposed to power the cathode ray tube .
                                      - the other one is certainly the vertical and voltage controls , also contains a power supply section coming straight from 220 V transformer's secondary .
                                        What happen when you change the time base, and when change the the VOLT/cm knobs from min (mV) to max (V)?
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
                                        • perzyk23
                                          Lenovo T580 - LCD Panel problem - error 0288
                                          by perzyk23
                                          Good morning,
                                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                          10-25-2024, 12:42 AM
                                        • SDNarcia
                                          Dell 15R-5521 keyboard problem (KBC?)
                                          by SDNarcia
                                          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                          As additional information,...
                                          07-20-2024, 10:47 PM
