I get 6 blinks / flashes on this tv. have managed to switch it on but the backlight is dim when BL_ERR is put on a resistor to ground. Any Ideas please?
KDL-52EX703 6 blinks
Re: KDL-52EX703 6 blinks
This is LED backlights do it does not use balancer or high voltage inverter circuits.
Can we see straight shot pictures of the backside of the TV?Never stop learning
The T-CON does control the backlights brightness for the dynamic contrast so they can claim that the TV has very high contrast ratio. I will need to look for the service and training manual for this model next. You can try disconnecting that small connector on the T-CON board to see if the backlights will stay on.Never stop learning
I got this service manual but its really poor! which t-con cable? I think if I do that the tv does not boot up! I can fiddle in a few hours when my daughter goes to sleep. cheersAttached FilesComment
The small white connector. I did not look at the service manual yet.Never stop learning
So they call the main board "BAL", you are right, the service manual is not really good at all. It does not even give the voltage test points. As RJ suggestion, it can be the BAL board per service manual.Last edited by budm; 06-02-2014, 11:38 AM.Never stop learning
any ideas? i'm tempted to take t-con out and check for fuse issues but then again it does work! and the led power seems legit at 316v as the caps are labelled 320v / 325v. and it does not drop. the picture itself seems perfect when BL_ERR bypassed just dim.
I dont understand where its getting the backlight error from? is it the t-con? as thats the only thing connected to the screen and av mainComment
might be a bad led or 2 in the string.seems voltage is too high.
many i test have vf around 160v.316 on a line with a 320v cap?
look to the led strips.
Hi just did some experiments and found:
v on dc = 327v
caps = 350v
when ambient sensor is off and I increase backlight and everything to max the backlight fails to light up and voltage drops to 250/150 range. decrease backlight and it come back and voltage rises again.Comment
by jinu_jHi
4. D930 - Shorted Schottkey Diode...-
by mikey5791Hi to all forum members,
Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor... -
I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors... -
by artvandalaiThe resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y3 Photos
by flat-eartherI have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries.... - Loading...
