KDL-52EX703 6 blinks
  • holmzy
    • Nov 2009
    • 99
    I get 6 blinks / flashes on this tv. have managed to switch it on but the backlight is dim when BL_ERR is put on a resistor to ground. Any Ideas please?
  • holmzy
    • Nov 2009
    • 99
    Re: KDL-52EX703 6 blinks
    only has 3 boards in view psu, av main and t-con
    • R_J
      • 9535
      6 blinks is Backlight error, Possible problem, Bal board . The board on the right looking from the back.
        This is LED backlights do it does not use balancer or high voltage inverter circuits.
        Can we see straight shot pictures of the backside of the TV?
        • holmzy
          • Nov 2009
          • 99
          thats it it only has 3 boards! the psu measure 316v dc going into the backlight via thin red and blue wires
          • holmzy
            • Nov 2009
            • 99
            What I dont understand is whats reporting the error? also the other thing I noticed when I turn up the backlight the voltage from the psu to backlight does not change. So is the t-con adjusting brightness?
              The T-CON does control the backlights brightness for the dynamic contrast so they can claim that the TV has very high contrast ratio. I will need to look for the service and training manual for this model next. You can try disconnecting that small connector on the T-CON board to see if the backlights will stay on.
              • holmzy
                • Nov 2009
                • 99
                I got this service manual but its really poor! which t-con cable? I think if I do that the tv does not boot up! I can fiddle in a few hours when my daughter goes to sleep. cheers
                  The small white connector. I did not look at the service manual yet.
                    So they call the main board "BAL", you are right, the service manual is not really good at all. It does not even give the voltage test points. As RJ suggestion, it can be the BAL board per service manual.
                    • holmzy
                      • Nov 2009
                      • 99
                      just tried that quickly and i get the 5 flashes indicating t-con issue. the set did not even switch on!
                      • holmzy
                        • Nov 2009
                        • 99
                        I managed to a full sw update on that no probs! with the dim backlight!
                        • holmzy
                          • Nov 2009
                          • 99
                          all functions on the menu seem to function, and the backlight has no dark spots indicating faulty led. yet 6 blinks and when BL_ERR bypassed dim backlight!
                          • holmzy
                            • Nov 2009
                            • 99
                            any ideas? i'm tempted to take t-con out and check for fuse issues but then again it does work! and the led power seems legit at 316v as the caps are labelled 320v / 325v. and it does not drop. the picture itself seems perfect when BL_ERR bypassed just dim.
                            I dont understand where its getting the backlight error from? is it the t-con? as thats the only thing connected to the screen and av main
                            • holmzy
                              • Nov 2009
                              • 99
                              I found dimm and dimm dc on the power board going into av main. can this be bypassed?
                              • holmzy
                                • Nov 2009
                                • 99
                                see here
                                • holmzy
                                  • Nov 2009
                                  • 99
                                  any help?
                                  • holmzy
                                    • Nov 2009
                                    • 99
                                    could really use help. the dimming voltage seems to rise to 1.2v to display a half dim screen then screen goes off and v drops to 0.3
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      might be a bad led or 2 in the string.seems voltage is too high.
                                      many i test have vf around 160v.316 on a line with a 320v cap?
                                      look to the led strips.
                                      • holmzy
                                        • Nov 2009
                                        • 99
                                        Hi just did some experiments and found:
                                        v on dc = 327v
                                        caps = 350v
                                        when ambient sensor is off and I increase backlight and everything to max the backlight fails to light up and voltage drops to 250/150 range. decrease backlight and it come back and voltage rises again.
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
                                        • Userrrname
                                          Tx-pr42gt30 6 blink
                                          by Userrrname
                                          👋🏻I recently got a tx-pr42gt30, I bought it in non-working condition. When I opened it, I saw that all the transistors and diodes had been removed from the tnpa5330, and several microcircuits were in poor condition, so I decided not to try to repair it. Instead, I bought another tnpa 5330 (also AB), which was already repaired (according to the seller, the board was repaired and worked before the screen was damaged), transistors were also changed on it, but Chinese copies were installed (there is no round hole in the middle, the inscription is easily erased) and a pair of transistors that...
                                          Today, 07:53 AM
