Replacing backlights in Vizio V755-J04
  • EazyBone
    • Jun 2023
    • 1353
    • United states
    I use a 77 OLED in my bedroom. Used to have an 82 in it. You get used to it. We think the 77 feels small now.
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      I feel that's a VERY large screen for a bedroom.
      Unless, of course, you have a massive bedroom.
      What is your viewing distance?
      • EazyBone
        • Jun 2023
        • 1353
        • United states
        Maybe 9-10 feet I'm not fully sure. Definitely works good
        • x_orange90_x
          • May 2015
          • 727
          I have a 55 in my bedroom about 10-12 feet away and it seems quite adequate 🤔
          • KYBOSH
            • Oct 2011
            • 581
            • Unknown
            I guess its true what they say... everything is bigger in EazyBone's bedroom
            • EazyBone
              • Jun 2023
              • 1353
              • United states
              #26
              Lol KYBOSHthat banana is hilarious.
              It's adequate until you try it. I have been plagued with big tv syndrome now. Why would you want a small screen? Plus half of movies cutoff like 40 percent of the damn screen making it even SMALLER. I would put a 100 inch if it made sense.. but it doesn't. Especially since I can't afford a 100 inch OLED. And not with a 2 yr old around that's for sure.
              • bpcannan
                VIZIO M557-G0: Backlights or ???
                by bpcannan
                'Morning,
                I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                10-29-2023, 06:36 AM
              • csmith
                Vizio-D50u-D1 Pulsating Backlights
                by csmith
                This Vizio came in the shop with no backlights. Replaced all the strips with replacement from Shop Jimmy. Set now has backlights but lights pulsate on left side. Half the screen brightens up then goes to normal then repeats.
                Am I looking at a defective strip? Thanks in advance.
                11-07-2024, 02:56 PM
              • x_orange90_x
                by x_orange90_x
                01-29-2025, 09:24 PM
              • ajshoe
                vizio E60-E3 backlights, sound, no video
                by ajshoe
                Have a free Vizio E60-E3 pickup - sound and backlights work. set turns on and stays on for a period then cycles off and back on. NO VIDEO. If I remove left side (from front of TV) of TCON cable - set has pic on right side (from front of TV) with white screen on left side. With right side TCON cable disconnected - no pic on either side.
                Does this mean remove right side (from front of TV) tabs ?
                Like a second opinion before possibly destroying set....
                04-07-2023, 01:59 PM
              • x_orange90_x
                Vizio E470i-A0 Dark Areas After Replacing Backlights
                by x_orange90_x
                I just replaced the Backlights in a Vizio E470i-A0 last night and I've noticed the light is not uniform across the panel. There's a patch where you can actually make out a few individual LEDs, the top and bottom of the screen are noticeably darker than the midsection, and the center left is crystal clear. The LEDs I bought were brand new from Amazon.
                It was late when I was reassembling it and it had been apart for a few weeks... Did I maybe put the diffusers in the wrong order? That's the only thing I can think would cause this. What's odd though is the section that appears bright...
                03-07-2020, 01:46 PM
