End of line resistor for Westinghouse tx-42f430s
    Re: End of line resistor for Westinghouse tx-42f430s
    See post 19 I just updated. Look at the bottom side of the board.
    • audiofreak19
      • Apr 2013
      • 556
      • usa
      Wow blonde moment. Haha. Ok so I tested the marked pins and it gets 12v and 5v and 5v standby and bl on 0v and ps on has 4.52v
      • audiofreak19
        • Apr 2013
        • 556
        • usa
        These tv's are known for master and slave inverter boards going bad. Do you think this could cause an issue like this. The person I bought it from said over time it would take longer and longer to turn on and eventually stopped working which would sound like a cap
          "ps on has 4.52v" OK, so the PS_ON does not toggle HIGH (>2VDC = ON and LOW (<1VDC = OFF) when power switch is activated? If that is the case, the problem is in the main board.
            "These tv's are known for master and slave inverter boards going bad" That is correct. So if you fix or replace the main board, you will still have to deal with inverters going bad later on. If you do have 24VDC and the BL_ON signals but no backlights, then you may also have inverter problem also. I am not crazy about Westinghouse.
            • audiofreak19
              • Apr 2013
              • 556
              • usa
              #26
              Believe me I don't like them either. Well I don't have bl on so it looks like a main board is what I will need. I don't know if its gonna be possible to trouble shoot that at component level. I'm wondering if it's the processor that's bad sending that signal out.
              • audiofreak19
                • Apr 2013
                • 556
                • usa
                #27
                Ok so if the tv is on technically since the ps on is getting voltage and all. Why would that fuse on the power board not be getting any voltage?
                • audiofreak19
                  • Apr 2013
                  • 556
                  • usa
                  #28
                  Crap and I can't get ahold of this main board. Not even ebay. But someone on ebay has a repair service for the main board
                  • audiofreak19
                    • Apr 2013
                    • 556
                    • usa
                    #29
                    I wish I would have done this search. I feel like such a noob lol. Check this post on the forum. I'm gonna try it since it's the exact same main board
                    • audiofreak19
                      • Apr 2013
                      • 556
                      • usa
                      #30
                      Forgot the link. https://www.badcaps.net/forum/showthread.php?t=24690
                        I cannot see the fuses on the main board. To troubleshoot down to component level will not be easy, you can try simple test on the voltage regulators (3-pin).
                        • audiofreak19
                          • Apr 2013
                          • 556
                          • usa
                          #32
                          Turns out it was the cap stated in the other thread. Swapped it out with same cap from another board and fired right up. Only thing is right when u plug the tv in it turns itself on by itself. I heard that's usually a sign of something wrong with the main board. But it turns on and off just fine after that
                          • audiofreak19
                            • Apr 2013
                            • 556
                            • usa
                            #33
                            Do you think its ok to sell like this.
                            • Shinju
                              • Mar 2014
                              • 1239
                              I just got one of these units, orange light and nothing else.
                              • audiofreak19
                                • Apr 2013
                                • 556
                                • usa
                                #35
                                I just replaced that cap. I didn't check it cause I already had another cap laying around
                                  I would run it for about a week to see if it always comes on OK and no other problems, need to make sure you will not have inverter boards problem also.
                                  • audiofreak19
                                    • Apr 2013
                                    • 556
                                    • usa
                                    #37
                                    Ah ok.
                                    • Glitcher
                                      • Mar 2013
                                      • 673
                                      • USa
                                      #38
                                      Are you turning off the TV with the power button or just pulling out the power cord while its on?
                                      If you pull out the power cord while its on, most tvs will automatically turn back on as soon as its plugged in. Shouldn't happen if you turn off the tv first.
                                      • audiofreak19
                                        • Apr 2013
                                        • 556
                                        • usa
                                        #39
                                        Yea I use the button to turn it off but it still turns on by itself when it's plugged in to the outlet.
                                        • magneh
                                          Is this some kind of fuse resistor ?
                                          by magneh
                                          Hello guys
                                          Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                                          Seem to me like some kind of fuse resistor?
                                          After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                                          They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                                          The red band is larger than the 4 others, but I dont have much experience with these components.
                                          Also one of the orange...
                                          02-10-2025, 07:54 AM
                                        • corrize
                                          Replacing resistor fuse in Sony DV charger
                                          by corrize
                                          Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                                          So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                                          It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                                          06-30-2025, 06:59 PM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • bobby4star
                                          BN44-00517C dead - blown cap, resistor and fuse
                                          by bobby4star
                                          Hi All,
                                          I have a UE32ES6540 which is dead, customer reported a pop and a puff of smoke. PSU is BN44-00517C and has blown 221k 1KV cap, next to this a blown resistor RM811. Board mains fuse is blown.
                                          Has anyone seen this problem and will changing the cap, resistor and fuse likely fix it? One more ask, can anyone give me a 2nd opinion of this resistor rating of RM811? I think it's 0.24 Ohms but would like a 2nd opinion! See attached pic.
                                          Thanks!
                                          Bob...
                                          11-12-2020, 12:46 AM
