I would just let it sit like that for a couple hours, it might be that people are quiting too early before everything is done updating, maybe.
Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
This topic has been answered.
Diah nomoresonys
I reformatted the drive (with RUFUS) and installed the file again (changing the name to upgrade_loader).
I plugged the thumb drive into the TV and tried to boot from disk but it didnt take.
I unplugged it. This time I pressed both the POWER and (-) when I plugged it back in and as soon as I did i saw a solid green status light.
I let go of both buttons and the light turned from green to pulsing white. The thumbdrive was constantly active as indicated by the drives built-in LED.
When I returned about 40 minutes later the status light is a solid dim white and the TV looks normal. It seems the firmware update is complete but there is still no picture.
now no picture you need to disconnect U ribbon at the panel buffer boards left and right .. you will have 3/4 picture...
75 size id there broken small vcc line on screen glass will make the hole screen blank.Comment
this what i wrote before at post #131 - 137, so you are successful now with firmware and parts married.
I believe it should have updated no problem.
I will remove U-cables tomorrow morning and report back.
If VCC line is the issue I maybe out of luck.
I have never even attempted such a repair as cutting these small traces.
I have watched it done (in amazement) on youtube but never dared to try it myself.
I wouldnt mind giving it a shot but only if properly guided by an expert who is patient with a new student.Comment
LEFT
RIGHT
Very Interesting Video!
As an aside... has anyone had any experience with a short killer device like the one he uses?
Edit to add:
Primer for reference
What is CKV1 CKV2 CKVB CKVB2 & Common Electrode of LCD
But their example was a simpler TV set (with a conveniently placed PMIC). I am studying the video still.
Will look if there is a schematic for this TV somewhere online so easily check the appropriate component(s).Comment
Ok, so what was the vgl, vgh etc. readings on the tcon? When those correct voltages are missing it may very well be a sign of a panel short.Comment
Doing more reading I saw that the CKV lines short to their corresponding CKVB lines (CKV1 goes with CKVB1 and so on).
I figured I could go in and measure the resistance of the pair to see if I could at least get a clue about what might be happening.
This logic maybe completely wrong but I figured I'd see what I could see.
Conveniently the T-Con has a section of test points dedicated to the CKVs and CKVBs.
All the CKVs and CKVBs have ~12.0MΩ of resistance (11.95M-12.0M).
Just out of curiosity i started checking the CKVs against themselves (CKV1 to CKV2) and none of those were shorted either (roughly 3MΩ if I recall).
Im not sure if this is the proper way to go about checking them for shorts but I thought it was worth a try to see what I could find out.
The search continues...Comment
Another (seemingly sure fire) way i have seen on Youtube it to tap the blank screen when the power is on.
You will see flashes of white light pop up. I have done this and this TV responds in this way.Comment
I spot checked those already but using the ground from the chassis. but i went back just now to check again will check again (with the grounds you specified) and they are all showing as not shorted . I will post the resistances shortly.
Edit to Add:
The ones you asked to to measure show a resistance of 2.34-2.35MΩ on each of the legs of 6 legged SMDs (rectifiers?.
The 2 legged device reads 2.468MΩ.
Curiously on the panel board on RIGHT side, the same SMDs all read as OPEN (no resistance at all).Last edited by KYBOSH; 05-08-2025, 12:46 PM.Comment
I updated the post the data lotas requested. But i think your low opinion of youtube videos and tutorials isnt quite right or fair. A lot of amazing and informative things there and im quite appreciative of the content creators efforts. Of course not everyone or everything is good on their but a lot of it is.Comment
by x_orange90_xFinally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
Has anyone else had this happen to their tv?
10-05-2024, 05:01 AM -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by ryandesignHello! I would like to repair my father's Sony Bravia KDL-40v4100 LCD TV. It was in perfect working order the last time I used it before the pandemic. Then it sat plugged in but unused for a year or more. And now everything still works except that there is no picture on the screen. A relay can be heard to click when the power cable is connected. When the power button is pressed there is a green power LED and then the backlight turns on. If I connect an HDMI cable and play something with audio I can hear it through the speakers. The remote control buttons are recognized. There is just never anything...
by justin35Hello,
i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
from what i read online it looks to be an emmc issue…
i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
i took out the board and say an samsung 16gb emmc
i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
i could try to put one instead of the 16gb one, but will it work?
where do i get the software from?
any help will be much appreciated!...03-06-2024, 12:26 PM -
by x_orange90_xI just got an XBR3 that does not appear to be turning on. As soon as you plug it in the SONY logo and the green power light come on but the screen stays dark. Pressing the power button once gives a single blink of the power light and it remains on. Holding the button in for about 4 seconds causes the logo and the power light to turn off, but as soon as I let go of the button they come right back on.
I have an XBR4 that if I recall correctly has a very distinct relay click when you turn it on, however I'm not hearing that from the XBR3. I just got it yesterday and haven't had a... - Loading...
