Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
This topic has been answered.
Try installing a jumper between FB 332 - FB 331 and then check by disconnecting the left cable, then the right cable...Note: This is with the TV off, disconnected from the mains and both LVDS cables connected (if this makes a difference).Both FCCs On Right FCC Off Only Left FCC Off Only Both FCCs Off FB_VRB + FB_332 2MΩ↑ 51.3KΩ 4.18KΩ 2.4MΩ FB_1 + FB_331 6.13KΩ 11.81KΩ 2.58KΩ 3.1MΩ FB_331 + FB_332 14.4Ω 5.6kΩ 5.6kΩ 9.5kΩ FB_1 + FB-VRB 2MΩ↑ 2MΩ↑ 2MΩ↑ 13MΩ↑ Comment
Sorry my friend... I didnt understand.
You want me to jumper FB_332 & FB_331 and see if I get an image on the display?
Or are you asking what happens on the display when we disconnected one of the cables?
If this is the question then the result was we still did not get any sort of image.
https://www.badcaps.net/forum/troubl...74#post3511374Comment
Here are the resistance values with FB_331 & FB_332 jumpered together.Both FCCs On Right FCC Off Only Left FCC Off Only Both FCCs Off FB_VRB + FB_332 40.4kΩ 2.0MΩ↓ 1.0MΩ↑ 2.58MΩ FB_1 + FB_331 6.16kΩ 11.2kΩ 2.97MΩ 2.92MΩ FB_331 + FB_332 0.2Ω 0.2Ω 0.2Ω 0.2Ω FB_1 + FB-VRB 2.0MΩ↑ 1.0MΩ↑ 7.0MΩ↑ 6.4MΩ
Note: the resistance of FB_VRB + FB_332 was actually decreasing with the right FCC off and the left FCC on.
Just posted the results of the jumpering.
I will go and turn the TV on with the jumper connected an to see if I have any picture at all.Comment
Lotas was on the right track to do the test... but i read as usual there are jumping from users to distribution the method.... why ? unknown for me... any wayDiah et al. Any tips on my next step?
who want to repair TV he should know how its work and which circuit built in...
at time i wrote no need to attempt standalone test... cause i do know what are going between the circuit as i asked man test... this is not to make me over all but know how as i am proud on my self i do proud on lotas R_J
back to the issue... yours FRC SoC are out from the circuit... this why you didnt have any error code when you disconnect the LVDS..... 12VCC_T-con etc..
BL_ERR can be register as it goes to Main SoC direct--- but all related video will go to FRC SoC then to main SoC... at time FRC SoC out of business... the main SoC will remain work as its not job to monitor this FRC.... he just receive error..... this subject are huge... i just explained in simple way..
OP you will not able to repair it but we can definitely say where are the issue... take out the all heat sinks of MB and post focused high resolution Photo and remark on it any low V you find on the MB... my wish no more distributionComment
Thank you for this insight! As i a still learning would you be kind enough to point out the chips/components you say are bad? I dont know where they are located.back to the issue... yours FRC SoC are out from the circuit... this why you didnt have any error code when you disconnect the LVDS..... 12VCC_T-con etc..
Sorry for my last post, was done in hurry.. ok now, have you understood how the feedback circuit is? It's very simple, since i was not able to find another FB test point , the FB_VRD is probably part of it, but i never read this type of acronym, maybe here is different from other sets, maybe this is not passive circuit as usual but is something dialogating with an ic on the panel strip boards, otherwise i think the feeback can be different enough, i can try to interpret, so why VRD? near the FB_VRD there is a VRD signal, does it stays for "Vertical ready"? Is it a simple loop that travels trough the gate drivers sequence? Is it VRD the starting signal and FB_VRD the returning one? Can you check in ohm between them with panel connected and panel disconnected? Then with continuity tester, check between first connector VRD and all second connector pins to find corrispondence, do the same with FB_VRD.. Similarily FB331/FB332 could be a totally different check, they can stay for "3,3v feedback connector 1/2", so connect all the panel, turn on and check voltage on these 2 pins.. but i'm unsure what means 3,3v feedback anyway..PS: so the old knowledge from Germany is came back, i was sure he came back, and he promptly started polemics against me.. too good to be true he abandoned the site..Last edited by Davi.p; 11-29-2024, 07:31 PM.Comment
I searched and the only SONY reference that I could find for VRB is as a reference test voltage for certain chipsets and boards but its noted as VRB. So this may lend support that this is not a passive circuit but rather an active one with a voltage.[INDENT]...the FB_VRD is probably part of it, but i never read this type of acronym, maybe here is different from other sets, maybe this is not passive circuit as usual but is something dialogating with an ic on the panel strip boards, otherwise i think the feeback can be different enough, i can try to interpret, so why VRD? near the FB_VRD there is a VRD signal, does it stays for "Vertical ready"?
I have only see one test point marked VRD. Where is the other one you want me to check against?
Im not sure I quite understand the "3,3v feedback connector 1/2" part but once I get the mainboard back in I will take voltage readings of all these FB points and report back.
Thanks again for the input!Comment
you AS°°°OL°.. i am here to kill yours mice virus... when the cat is away the mice dance on the table...
its useless when some one try to solve issue and you want to follow other... what 3.3V how you will be in the forum to follow to different issze..
any way... just plame your self if you didnt find from me any more response..
yours issue at the is area FRC and iQ circuit... check first all F of FRC & iQ
I really respect you guys and have great respect for the forum. As a laymen when someone more knowledgeable than me tries to show me something I am grateful and try in earnest to listen and learn.
I have noticed the animosity between a few of you Legends, Veterans and Hobbyists
but I definitely want to stay out of all that. Firstly I dont know how it started. Then I dont know the facts and current events. And lastly I dont know how you guys wish to settle it. For all I know you all will go skiing together in the Alps over the holidays. I hope i do not rub anyone the wrong way by taking suggestions, tip and advice from whoever is good enough to offer it. I see nothing wrong with taking a voltage reading as Davi.p requested as it does not directly relate to or interfere with what you asked me to do (take pictures of the mainboard). If nothing else, its just more data for us to consider, culprits to eliminate and things to learn from. If my thinking is wrong and goes against the Badcaps.net way please let me know. I would love to think this place a safe zone we all come together to learn and fix and have a little fun while we are at it.
I am not familiar with these circuits at all but I will study it and try as you intructed. When you say check all F of FRC & iQ.... does F refer to fuses?
Thank you againComment
from one point you want to learn... that's fine.... but did you know any attempt to work or fed V at wrong area, you will kill many other parts... so why we do spend.time to help you and we do read how you are going to kill the set ? better leave you and laugh !!! NO this no one serious man man will do it-
you can read on the area i show you F and in general F are fuse .Comment
by alegatorulsony bravia kdl-43w756c, no power, no sound
the charger brick has 19,2-19,3 vcc
changed the inverter board same result.
where should i start?
cheers -
by x_orange90_xFinally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
Has anyone else had this happen to their tv?
10-05-2024, 05:01 AM -
by JUCaESAlHola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television. -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by iglitareHi,
i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
Backlight seems to work, Sound (Setup menu after reset) works.
If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
With my small knowledge i would think at least the cables are good.
Can this happen because of a bad tcon board?
Or is it always a bad/shorted... - Loading...
