I have you a detailed information and steps to troubleshoot it, if the LVDS was covered with tape you must remove that tape and follow my instructions again, there’s no way that the panel KV lines are shorted on both sides of the panel, remove the tape from the LVDS and connect it back with your new t-con and try the troubleshooting again; if could you’re living in Dubai I would do it for you.
Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
This topic has been answered.
The tape was on the original LVDS.I have you a detailed information and steps to troubleshoot it, if the LVDS was covered with tape you must remove that tape and follow my instructions again, there’s no way that the panel KV lines are shorted on both sides of the panel, remove the tape from the LVDS and connect it back with your new t-con and try the troubleshooting again; if could you’re living in Dubai I would do it for you.
I purchased brand new sets of LVDS cables and was working with those since I started back up looking at this few weeks ago.
It was only recently when i looked at the original LVDS cables that I noticed the tape from the previous owner.
I have been using brand new LVDS, brand new T-Con and a confirmed working Main board only.
Nothing really else to do or try.
Just put a the red multimeter prop on VONE point and the black one on GND then turn the TV on and see if you have any changes on the multimeter screen (if digital) or if you have analogue multimeter you’ll have a sudden move on the gauge; if so that mean your t-con and motherboard and everything is working fine but you have a short on the lcd panel, after that you have to isolate which side is having short. Just give this a final try before scrapping it.Comment
by alegatorulsony bravia kdl-43w756c, no power, no sound
the charger brick has 19,2-19,3 vcc
changed the inverter board same result.
where should i start?
cheers -
by x_orange90_xFinally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
Has anyone else had this happen to their tv?
10-05-2024, 05:01 AM -
by JUCaESAlHola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television. -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by iglitareHi,
i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
Backlight seems to work, Sound (Setup menu after reset) works.
If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
With my small knowledge i would think at least the cables are good.
Can this happen because of a bad tcon board?
Or is it always a bad/shorted... - Loading...
