Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
This topic has been answered.
  • nomoresonys
    • 12330
    • U.S.
    #141
    I would just let it sit like that for a couple hours, it might be that people are quiting too early before everything is done updating, maybe.
    • Diah
      • Feb 2013
      • 6566
      Originally posted by KYBOSH
      Diah nomoresonys
      I reformatted the drive (with RUFUS) and installed the file again (changing the name to upgrade_loader).
      I plugged the thumb drive into the TV and tried to boot from disk but it didnt take.
      I unplugged it. This time I pressed both the POWER and (-) when I plugged it back in and as soon as I did i saw a solid green status light.
      I let go of both buttons and the light turned from green to pulsing white. The thumbdrive was constantly active as indicated by the drives built-in LED.
      When I returned about 40 minutes later the status light is a solid dim white and the TV looks normal. It seems the firmware update is complete but there is still no picture.
      this what i wrote before at post #131 - 137, so you are successful now with firmware and parts married.
      now no picture you need to disconnect U ribbon at the panel buffer boards left and right .. you will have 3/4 picture...
      75 size id there broken small vcc line on screen glass will make the hole screen blank.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4539
        • Italy - Milan
        #143
        Kybosh You posted wrong photos, i asked only the portion of sticker, the second one is unreadable..
        • KYBOSH
          • Oct 2011
          • 581
          • Unknown
          #144
          Apologies Davi!
          I used an iphone 6 on my workbench to take that pic.
          I knew it was going to be garbage!
Name:	2025-05-07 22.57.20.jpg
Name:	2025-05-07 22.57.10.jpg
          • KYBOSH
            • Oct 2011
            • 581
            • Unknown
            #145
            Yes, the TV has been sitting for several hours. Same solid white status light.
            I believe it should have updated no problem.
            I will remove U-cables tomorrow morning and report back.
            If VCC line is the issue I maybe out of luck.
            I have never even attempted such a repair as cutting these small traces.
            I have watched it done (in amazement) on youtube but never dared to try it myself.
            I wouldnt mind giving it a shot but only if properly guided by an expert who is patient with a new student.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4539
              • Italy - Milan
              #146
              • KYBOSH
                • Oct 2011
                • 581
                • Unknown
                #147
                Tried the TV with Left and then Right U-cable off and still got no image.
                The LCD display is active however bcos when you tap the screen you get flashes of white,
                I guess i need to start considering cutting some traces....
                • KYBOSH
                  • Oct 2011
                  • 581
                  • Unknown
                  #148
                  Click image for larger version  Name:	LEFT.jpg Views:	0 Size:	1.74 MB ID:	3632461
                  LEFT
                  Click image for larger version  Name:	RIGHT.jpg Views:	0 Size:	2.09 MB ID:	3632462
                  RIGHT
                  Very Interesting Video!
                  As an aside... has anyone had any experience with a short killer device like the one he uses?
                  Edit to add:
                  Primer for reference
                  What is CKV1 CKV2 CKVB CKVB2 & Common Electrode of LCD
                  • nomoresonys
                    • 12330
                    • U.S.
                    #149
                    Need to think before acting, the question is, are we sure that the panel is shorted??
                    • KYBOSH
                      • Oct 2011
                      • 581
                      • Unknown
                      #150
                      Agreed! The video explains how to check various components (capacitors, rectifiers, etc) BEFORE cutting lines.
                      But their example was a simpler TV set (with a conveniently placed PMIC). I am studying the video still.
                      Will look if there is a schematic for this TV somewhere online so easily check the appropriate component(s).
                      • KYBOSH
                        • Oct 2011
                        • 581
                        • Unknown
                        #151
                        Definitely out of my league on this TV when it comes to shorts.
                        I'll wait to hear back from you guys who have experience with this.
                        • nomoresonys
                          • 12330
                          • U.S.
                          #152
                          Ok, so what was the vgl, vgh etc. readings on the tcon? When those correct voltages are missing it may very well be a sign of a panel short.
                          • lotas
                            • Jan 2016
                            • 4862
                            • Russia
                            #153
                            Check the resistance of each pin relative to GND.
                            • nomoresonys
                              • 12330
                              • U.S.
                              #154
                              • KYBOSH
                                • Oct 2011
                                • 581
                                • Unknown
                                #155
                                Doing more reading I saw that the CKV lines short to their corresponding CKVB lines (CKV1 goes with CKVB1 and so on).
                                I figured I could go in and measure the resistance of the pair to see if I could at least get a clue about what might be happening.
                                This logic maybe completely wrong but I figured I'd see what I could see.
                                Conveniently the T-Con has a section of test points dedicated to the CKVs and CKVBs.
                                Click image for larger version  Name:	Screenshot 2025-05-08 at 1.17.55 PM.png Views:	0 Size:	293.3 KB ID:	3632683
                                All the CKVs and CKVBs have ~12.0MΩ of resistance (11.95M-12.0M).
                                Just out of curiosity i started checking the CKVs against themselves (CKV1 to CKV2) and none of those were shorted either (roughly 3MΩ if I recall).
                                Im not sure if this is the proper way to go about checking them for shorts but I thought it was worth a try to see what I could find out.
                                The search continues...
                                • KYBOSH
                                  • Oct 2011
                                  • 581
                                  • Unknown
                                  #156
                                  I dont recall checking those before but I will have a look on my TCon to see if I can spot the test pads.
                                  Another (seemingly sure fire) way i have seen on Youtube it to tap the blank screen when the power is on.
                                  You will see flashes of white light pop up. I have done this and this TV responds in this way.
                                  • KYBOSH
                                    • Oct 2011
                                    • 581
                                    • Unknown
                                    #157
                                    I spot checked those already but using the ground from the chassis. but i went back just now to check again will check again (with the grounds you specified) and they are all showing as not shorted . I will post the resistances shortly.
                                    Edit to Add:
                                    The ones you asked to to measure show a resistance of 2.34-2.35MΩ on each of the legs of 6 legged SMDs (rectifiers?.
                                    The 2 legged device reads 2.468MΩ.
                                    Curiously on the panel board on RIGHT side, the same SMDs all read as OPEN (no resistance at all).
                                    • Diah
                                      • Feb 2013
                                      • 6566
                                      why you are jumping between youtube... u will never have answer there,,, just answer lotas last question.. if they are fine then u need to take out the bezel and carefully with loop check the round display glass
                                      • KYBOSH
                                        • Oct 2011
                                        • 581
                                        • Unknown
                                        #159
                                        I updated the post the data lotas requested. But i think your low opinion of youtube videos and tutorials isnt quite right or fair. A lot of amazing and informative things there and im quite appreciative of the content creators efforts. Of course not everyone or everything is good on their but a lot of it is.
                                        • nomoresonys
                                          • 12330
                                          • U.S.
                                          #160
                                          Gotta say plus 1000, some very bright individuals lending their expertise and of course a few not so good.
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
                                          • x_orange90_x
                                            Sony Bravia KD-50X690E NO SOUND
                                            by x_orange90_x
                                            Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
                                            Has anyone else had this happen to their tv?
                                            10-05-2024, 05:01 AM
                                          • JUCaESAl
                                            Sony bravia KD-65AF9
                                            by JUCaESAl
                                            Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                                            Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                                            10-20-2025, 04:03 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
