Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
This topic has been answered.
  • lotas
    • Jan 2016
    • 4500
    • Russia
    #181
    Strange, check the same on the second T-con. Measure the resistance on the inductors relative to ground, there should be no low or short resistance, except for the one that sits on the ground, to convert the negative voltage relative to ground (VGL).
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      #182
      Sorry for the delay my friend!
      It was next to impossible measuring the resistance of the smallest inductors because the leads are on the bottom and not on the side.
      Some of the inductors had wandering resistance readings but they eventually settled on a number. I indicated that with a ⇅ symbol.
      These readings were are basically the same whether I was testing the TCon on the TV or the one that I have off the TV.
      Hope these are of help. To be honest I am not sure what they mean. I assume the wandering resistances are due to the nearby capacitors.
      I used the copper mounting pads as my ground while measuring resistance.
      • KYBOSH
        • Oct 2011
        • 581
        • Unknown
        #183
        Funny story... i was looking over the old LVDS cable and noticed that the copper tracks at the end looked kind of dull.
        Upon further inspection i found that it was covered with scotch tape.
        Apparently the previous owner attempted to mask off 90% of the traces with tape in an attempt to get the TV working.
        Would have never noticed this if not by chance.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4278
          • Italy - Milan
          #184
          quite irrelevant, but if you wish to play and experiment a bit i can suggest you a 5 min. test, locate the quartz near the cpu, solder a thin wire to short circuit it, connect everything and see if the screen auto test begins.. this could be the same as running the screen alone but here we can see 1. if screen works, 2. if half of tcon is on the MB.. kindly it will not work because of bad main board, but lets see..
          • bohaboha
            • Nov 2012
            • 972
            • sweden
            #185
            Davi.p can you please point out where the tests should be carried out
            • Diah
              • Feb 2013
              • 6354
              what had SoC to do with quartz Hz, at time each SoC had his own Hz tact.
              • KYBOSH
                • Oct 2011
                • 581
                • Unknown
                #187
                Davi can you give a primer on how this test method works? This is actually my first time of hearing of any diagnostic test dealing with that timing crystal.
                If the MStar chip is not able to send a video signal how will this force it to do so?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4278
                  • Italy - Milan
                  #188
                  No...this test is a step back when i was suggesting the screen self test, we are not sure about the bad tcon circuitry, with this test you can see if all part related to screen is ok, then the other part, the processor would be not ok.. disabliing the quartz is disabling the processor, so like detaching a main board from the screen
                  • KYBOSH
                    • Oct 2011
                    • 581
                    • Unknown
                    #189
                    Interesting...
                    Okay so be clear:
                    With the power off/unplugged, I want to create a short as illustrated in the picture.
                    Then power ON/plug in the TV and check for a self test pattern on the screen.
                    Click image for larger version  Name:	Screenshot 2025-05-10 at 4.49.00 PM.png Views:	0 Size:	1.16 MB ID:	3634253
                    This scenario is the perfect reason why buying a TV160 4K-Vbyone & 2K-LVDS Screen Tester​ would be warranted! Its on my wish list!
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4278
                      • Italy - Milan
                      #190
                      the oscillator is not that, watch the processor, less than a inch down there is a grey 4 pin smaller one, don't; ask me the pinout, i do not know... the rest, thermal camera, special testers, im sure you don't last in the repair market witth these purchases..
                      • KYBOSH
                        • Oct 2011
                        • 581
                        • Unknown
                        #191
                        I dont see anything like what you are describing but its probably all well and good.
                        This experiment is probably way over my head anyway!
                        Im going to go with the assumption that the Mainboard is the issue.
                        If I send it in for repair and its NOT the issue then at least for a $30 bench fee I will have confirmation that it works.
                        And that'll just leave the panel as the only possibility.
                        Im not in the repair market. I do this for a hobby and quite enjoy learning.
                        A tool like the TV160 is probably worth it bcos it will save someone days/weeks/months running around trying to figure these things out.
Name:	2024-12-01 14.08.30_2024-12-01 14.08.44.jpg
                        • bohaboha
                          • Nov 2012
                          • 972
                          • sweden
                          #192
                          Originally posted by Diah
                          this guy hobby always smoke & BBQ, what had SoC to do with quartz Hz, at time each SoC had his own Hz tact.
                          it is so
                          • lotas
                            • Jan 2016
                            • 4500
                            • Russia
                            #193
                            Check these fuses just in case.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4278
                              • Italy - Milan
                              #194
                              My balls full with the elment here over, another reporting to the staff, i see people following him, keep him if you like, i seen him never fixing any product... anyway..
                              this is the item..
                              i don't kmow what do you mean for "hobby" , didn't you sell your works?
                              • nomoresonys
                                • 12087
                                • U.S.
                                #195
                                It's actually a compliment to you Diah, the little guy is intimidated by your knowledge.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4278
                                  • Italy - Milan
                                  #196
                                  kybosh if you want i can suggest you things in private, not here in middle of --------.. people here are continuing to trespass the technical questions, especially by sunday when staff is on rest, typical cleverness of the useless unfair elements..
                                    • 115469
                                    #197
                                    Davi.p - I agree with you the comments against your post are uncalled for so I will put in a ban for the user if it persists. However, you need to have a thicker skin as they remarks are quite tame. You can just ignore or say you dont respect them. At the end of the day we see you as a valuable contributor to the site so you should not let one person put you off from stating your opinion here. Zero tolerance to any bullying and admins are watching closely
                                    • KYBOSH
                                      • Oct 2011
                                      • 581
                                      • Unknown
                                      #198
                                      Hello everyone. Hope you are all well and in good spirits.
                                      I wanted to update this thread with information that I have found since I last posted.
                                      I found a good guy on ebay who agreed to test the mainboard for me for a bench fee.
                                      He told me initially that these TVs are known for their panels dying but I wanted to be absolutely sure it was the panel and not anything else since we have been working on this thing for several months.
                                      So he agreed to test it for me by putting it in another (similar but not same) TV model. Still dont know what model TV he used as I thought these mainboards were quite specific to the models they were made for.
                                      Anyway the mainboard is fine and he was good enough to send pics as proof of life.
                                      So Im at the end of my journey with this set.
                                      I may never be good enough to do short detection and remediation on these LCD panels.
                                      And even if I eventually could I certainly cant do anything like that now.
                                      Thank you all for your help, input and expertise. I learned a lot and enjoyed the experience.
                                      Hope this helps the next journeyman who has the same or similar symptoms.
Name:	Screenshot 2025-05-30 at 12.42.36 PM.png
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4278
                                        • Italy - Milan
                                        #199
                                        if you haven't tried another tcon, for a so large tv set i would try one..
                                        This phantomatic "good guy" has really tested the main board? Where are the proofs?
                                        • KYBOSH
                                          • Oct 2011
                                          • 581
                                          • Unknown
                                          #200
                                          Thank you for the input Davi.
                                          You may recall a few pages back I ordered a brand new T-Con board but there was no change.
                                          The "good guy" sent me proof by way of a screenshot (not posted) of set's serial number located in the System Information page (and they match 👍).
                                          No one wanted to fix this set more than I did but according to the Troubleshooting flow chart there is nothing left but the panel that could be at fault.
                                          • x_orange90_x
                                            Sony Bravia KD-50X690E NO SOUND
                                            by x_orange90_x
                                            Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
                                            Has anyone else had this happen to their tv?
                                            10-05-2024, 05:01 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • ryandesign
                                            Sony Bravia KDL-40v4100 has no picture but has power, backlight, and sound
                                            by ryandesign
                                            Hello! I would like to repair my father's Sony Bravia KDL-40v4100 LCD TV. It was in perfect working order the last time I used it before the pandemic. Then it sat plugged in but unused for a year or more. And now everything still works except that there is no picture on the screen. A relay can be heard to click when the power cable is connected. When the power button is pressed there is a green power LED and then the backlight turns on. If I connect an HDMI cable and play something with audio I can hear it through the speakers. The remote control buttons are recognized. There is just never anything...
                                            05-30-2021, 01:07 PM
                                          • x_orange90_x
                                            Sony Bravia KDL-46XBR3 No display or sound
                                            by x_orange90_x
                                            I just got an XBR3 that does not appear to be turning on. As soon as you plug it in the SONY logo and the green power light come on but the screen stays dark. Pressing the power button once gives a single blink of the power light and it remains on. Holding the button in for about 4 seconds causes the logo and the power light to turn off, but as soon as I let go of the button they come right back on.
                                            I have an XBR4 that if I recall correctly has a very distinct relay click when you turn it on, however I'm not hearing that from the XBR3. I just got it yesterday and haven't had a...
                                            07-02-2021, 04:10 AM
                                          • justin35
                                            Sony bravia kdl-43w755c - boot loop
                                            by justin35
                                            i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                            from what i read online it looks to be an emmc issue…
                                            i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                            i took out the board and say an samsung 16gb emmc
                                            i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                            i could try to put one instead of the 16gb one, but will it work?
                                            where do i get the software from?
                                            any help will be much appreciated!...
                                            03-06-2024, 12:26 PM
