Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
This topic has been answered.
  • admxxx
    • Mar 2019
    • 12
    • uae
    #121
    Originally posted by KYBOSH
    lotas
    admxxx
    No joy....
    Tried covering both sides and no change in the screen whatsoever.
    I could hear the OCD music playing and the TV was responsive to remote.
    Just no visual sign of life on the Display.
    Click image for larger version Name:	Screenshot 2025-01-05 at 10.20.10 PM.png Views:	0 Size:	1.84 MB ID:	3542047
    Did you got 32v on the Vone ? Are both U-link on the COF boards connected properly (under the metal frame of the TV)?
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      #122
      I never got 32v at Vone.
      in my p previous post i mentioned i never got hardly any voltage at all.
      im very sure the U-link films are connected properly as well.
      • KYBOSH
        • Oct 2011
        • 581
        • Unknown
        #123
        This this has been sitting/standing on my worktable for months now. I am ordering a new T-Con from Aliexpress today ($35). I need to start eliminating some unknowns!
        • KYBOSH
          • Oct 2011
          • 581
          • Unknown
          #124
          Got my t-con in today.
          IIRC you cant just pop new components on Sony TVs but rather you need to install them and re-install the firmware.
          Anyone know if that's the case with the t-con?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4318
            • Italy - Milan
            #125
            Sony needs a special pairing modality, unfortunately i took a note only on my dead tablet..
            • KYBOSH
              • Oct 2011
              • 581
              • Unknown
              #126
              I found the KD-75X780F service manual (not sure why I assumed it would be hard to find) and at first glance it doesn't specifically speak of any pairing procedure but it does give instructions on doing the firmware update which I have done before.
              It also has a flow chart on how to proceed when you have a NO PICTURE situation.
              Apparently the FFC cable is the first thing under suspicion and the panel/T-con is the last.
              I never considered the cable...
              Not sure if I can rule out the Mainboard even though I get sound and input responses with the remote control...
              Click image for larger version  Name:	Screenshot 2025-04-29 at 3.13.48 PM.png Views:	0 Size:	216.4 KB ID:	3626043
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4318
                • Italy - Milan
                #127
                i do not remember this entire thread, i don't even know what's the result of the new tcon board, if it is no display (it seems so) i can't help you, i remember i disucussed this pairing task in an old forum now closed, and no notes on my cellular/PC , only the dead note on tablet, i think i would be happier if i would find a very simple app to sincronize the very few files that i use commonly, years ago i wrote a terrible script to do this but i did not work so well.. what i recall is that in that discussion i did not found in time the answer to help a.guy, the requester user gave the tv to a sony center that made a secret procedure and fixed the tv, i tried to rebuild what they do and i thought i found the answer, but if i remember something i tell you.. what i remember maybe is that they have a special usb mem key with a script inside, i about sure of the usb key.. the script forces the main software to update the main.settings.to the replacement tcon/panel, Sony tv checks every boot some data on the tcon eprom, also a model ascii string, it must match the one stored in MB, maybe doing a deep reset the tv reinitializes, need to enter service menu blindly and perform the reset. check the service manual, some very old lcd had a shortcut to the service reset with key combination..
                • KYBOSH
                  • Oct 2011
                  • 581
                  • Unknown
                  #128
                  I have not tried the new TCon yet as it just came in the mail.
                  Apparently it requires a pairing procedure but that may be a simple firmware reinstall with a USB stick.
                  This does not require the display to be on bcos the update occurs (without user interaction) as soon as the USB with the firmware is detected.
                  In the video there is talk of potential FFC misalignment issues which i will have a look at.
                  New FFC cables are pretty cheap from encompass.com ($20 for the pair + S&H).
                  I may order them in order to follow the troubleshooting steps.
                  • admxxx
                    • Mar 2019
                    • 12
                    • uae
                    #129
                    In my case I replaced the t-con and it was a direct swap, there was no need for any pairing or firmware update.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4318
                      • Italy - Milan
                      #130
                      i know an update works but you have an already updated sw, so what you do? there is maybe a method to force an unwanted update..
                      • Diah
                        • Feb 2013
                        • 6363
                        sony android TV, even if the last update installed on it,,, put it on USB stick formatted FAT32 MBR mode an USB V.2 on the side, not at the back, TV take it out from wall socket... if it had joystick presst and pull it down, keep in this position and plug it back in wall... release the joystick only after the front LED change from white to green..
                        the TV will write back the firmware from eMMC/NAND section first and related to USB to register all other HW boards back include T-CON.. PUNKT
                        • KYBOSH
                          • Oct 2011
                          • 581
                          • Unknown
                          #132
                          Thank you Davi.p admxxx Diah
                          I got my brand new LVDS cables in today and installed them first, as its the first step of the troubleshooting chart, but no joy. Tv behaved the same. I then installed the new TCon board. Also no change. I can hear music from the SONY setup screen l, the backlight is on but no picture image. Apparently Admxxx is correct that there is no firmware update needed for a TCon swap on this model TV but i may do one anyway incase the issue is firmware related somehow. It certainly wont hurt to try.
                          Before i do that i wanted to have a look at the buffer panel boards again to see if i could spot any shorted components i missed earlier. All of the capacitors read okay however (not shorted according to MM).
                            • 12151
                            • U.S.
                            #133
                            Can you tell me the number of the update you are trying to install?
                            • KYBOSH
                              • Oct 2011
                              • 581
                              • Unknown
                              #134
                              sony_dtv0FA60A0AA0AA_00004300_16072201000365.pkg
                              But for some reason it doesnt want to boot.
                              I went in and changed the name to update_loader as described in the video above.
                              But even then I got the pulsing with light but never got a green light no matter how long I held the (-) button.
                              The USB drive was blinking continuously indicating it was being read but nothing happened other than that.
                              Eventually the TV just restarted and went back to the normal solid white light.
                                • 12151
                                • U.S.
                                #135
                                Can/have you tried a different one? I think it may work with the update_loader at the end of a different firmware. I think it can also take quite a while too in some cases to update. I would let it go a couple hours maybe. Plus as mentioned many times, these sonys are fussy, use no bigger than 8gb and trying different brands of thumb drives may be necessary.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4318
                                  • Italy - Milan
                                  #136
                                  Post a picture with a portion with original board sticker image, and the one on replacement board..
                                  • Diah
                                    • Feb 2013
                                    • 6363
                                    never got a green light no matter how long I held the (-) button..
                                    keep the file name as it should dont rename it, press power on set and - , usb stick formatted fat32 mbr mode, keep press then plug tv in wall it will change from white to green
                                      • 12151
                                      • U.S.
                                      #138
                                      Did you ever get green and white pulsing on indicator? If you did the tv needs an update nothing more. If you have somehow downloaded a corrupt firmware or something weird happened during download then it won't work. Try Diahs instruction if no joy, I would try in order and ignore if you have already tried some of them. 1, download firmware again and try both ways without the update_loader, then with it, no joy, try a different browser for download. No joy get a different number firmware and do same procedure.
                                      • KYBOSH
                                        • Oct 2011
                                        • 581
                                        • Unknown
                                        #139
                                        Diah nomoresonys
                                        I reformatted the drive (with RUFUS) and installed the file again (changing the name to upgrade_loader).
                                        I plugged the thumb drive into the TV and tried to boot from disk but it didnt take.
                                        I unplugged it. This time I pressed both the POWER and (-) when I plugged it back in and as soon as I did i saw a solid green status light.
                                        I let go of both buttons and the light turned from green to pulsing white. The thumbdrive was constantly active as indicated by the drives built-in LED.
                                        When I returned about 40 minutes later the status light is a solid dim white and the TV looks normal. It seems the firmware update is complete but there is still no picture.
                                        Davi.p
                                        As you have requested.
                                        Top = OLD (Original pulled from TV)
                                        Bottom = NEW (Replacement ordered from Ali-E)
                                          • 12151
                                          • U.S.
                                          #140
                                          Maybe ask Nick, he has done over 1000 sonys.
                                          • x_orange90_x
                                            Sony Bravia KD-50X690E NO SOUND
                                            by x_orange90_x
                                            Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
                                            Has anyone else had this happen to their tv?
                                            10-05-2024, 05:01 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • ryandesign
                                            Sony Bravia KDL-40v4100 has no picture but has power, backlight, and sound
                                            by ryandesign
                                            Hello! I would like to repair my father's Sony Bravia KDL-40v4100 LCD TV. It was in perfect working order the last time I used it before the pandemic. Then it sat plugged in but unused for a year or more. And now everything still works except that there is no picture on the screen. A relay can be heard to click when the power cable is connected. When the power button is pressed there is a green power LED and then the backlight turns on. If I connect an HDMI cable and play something with audio I can hear it through the speakers. The remote control buttons are recognized. There is just never anything...
                                            05-30-2021, 01:07 PM
                                          • justin35
                                            Sony bravia kdl-43w755c - boot loop
                                            by justin35
                                            i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                            from what i read online it looks to be an emmc issue…
                                            i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                            i took out the board and say an samsung 16gb emmc
                                            i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                            i could try to put one instead of the 16gb one, but will it work?
                                            where do i get the software from?
                                            any help will be much appreciated!...
                                            03-06-2024, 12:26 PM
                                          • x_orange90_x
                                            Sony Bravia KDL-46XBR3 No display or sound
                                            by x_orange90_x
                                            I just got an XBR3 that does not appear to be turning on. As soon as you plug it in the SONY logo and the green power light come on but the screen stays dark. Pressing the power button once gives a single blink of the power light and it remains on. Holding the button in for about 4 seconds causes the logo and the power light to turn off, but as soon as I let go of the button they come right back on.
                                            I have an XBR4 that if I recall correctly has a very distinct relay click when you turn it on, however I'm not hearing that from the XBR3. I just got it yesterday and haven't had a...
                                            07-02-2021, 04:10 AM
