Samsung TV - Only get picture after warming up
    I have a Samsung LN-T4069 TV. When I first turn the TV on in the morning, I have sound and backlight (whitish, grayish light) but no picture. If I leave it on for 2-3 minutes, turn it off and then on again, the picture will then show up.
    I thought it was a capacitor issue (saw 2 bad caps) got a cap replacement kit from LCDAlternatives (those guys ROCK!) - swapped out all the caps, but the problem remains……
    So now what? What could be causing this?
    Thank you one and all. As a woman attempting her first capacitor soldering activities, my friends think I am crazy, but I am really enjoying this - just wish I could fix the problem!
    Re: Samsung TV - Only get picture after warming up
    Try that hair dryer first:
    https://www.badcaps.net/forum/showth...410#post449410
    If you are not sure where the T-CON board is, please post the pictures of the back of the TV so we can point it out to you.
      That did the trick! I did the test twice. I made sure the TV was "cold" and that the picture would not come on. And both times, after heating up the TCon, I got a picture.
      So I am assuming this means I need to replace the Tcon correct?
      Thank you for the help
        Can we see what you T-CON board looks like?
        Does it look like this?
        http://www.shopjimmy.com/samsung-lj9...-con-board.htm
          It does - it was at the top of the tv - under a metal panel with silver tape - and I watched the ShopJimmy Video on how to find you part number - mine is lj94-01973H
            When the time comes to swap it out - how in the world do I disconnect those four wire connectors at the top?
              Bud - Scott from LCDAlternatives says hi!
                Well shoot - I replaced the T-con board successfully, but the problem has not been resolved…… now what? anyone, any ideas?
                  Does the hairdryer heating still bring it on?
                  Check all your connectors
                    i will have to try that again - shoot shoot shoot!
                      if heating it brings it back on, maybe its a tab bonding issue ?
