vizio gv47lfhdtv10a bad t-con!?
  • Shinju
    • Mar 2014
    • 1239
    Just got this on the super cheap, panel turns on and works the menus look fine, when a picture is on the screen you can see the picture is starting to look solarized.
    Before I tear into it, I am making a thread.
    Here is a photo of the screen in action.
    I will take the back off in a day or two.
    Re: vizio gv47lfhdtv10a bad t-con!?
    I would re-seat the cables on the T-CON and on the main board, then check the GAMMA Voltages on the T-CON.
    • Shinju
      • Mar 2014
      • 1239
      Will do, the menus seem unaffected with or without a picture.
      • Shinju
        • Mar 2014
        • 1239
        Gamma voltages are fine, here is where it gets strange. This is supposed to be 1080p according to the fancy placard on the front of the unit.
        When the source is at 1080p the picture looks like it does in the photo above. When set to any other resolution the picture is fine.
        So this leads me to believe the mainboard is shot.
        • Shinju
          • Mar 2014
          • 1239
          HDMI controller was going out, replaced the mainboard and it is now working as intended.
          • Electronic Handyman
            • Apr 2016
            • 58
            I have the same model GV47LFHDTV10A that has a damaged main board.Anybody have the actual schematic for it?I can only find trouble shooting charts for and I need a true schematic that shows me what parts connect to what.Also if you've the schematic for the audio board and anything else it would be much appreciated.I've had the set sitting in storage so I can give the actual board part numbers but I'd love to fix it.Thank you in advance
            • Fly_Among_Stars
              VIZIO E70-E3 Half picture with half TCON
              by Fly_Among_Stars
              I have a VIZIO E70-E3.
              Symptoms: Black screen, no picture, but LED backlights are working.
              I probed the power board and voltages are as listed on the board.
              Main board appears fine, too.
              I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
              There are two separate ribbon cables feeding the LCD.
              If both are connected, the screen is black.
              If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
              04-24-2023, 08:20 PM
            • iglitare
              Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
              by iglitare
              i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
              Backlight seems to work, Sound (Setup menu after reset) works.
              If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
              Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
              With my small knowledge i would think at least the cables are good.
              Can this happen because of a bad tcon board?
              Or is it always a bad/shorted...
              09-04-2025, 07:13 AM
            • ggil44
              Vizio M65-E0 No Picture, No Sound
              by ggil44
              Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
              09-03-2024, 08:30 PM
            • maricm
              Vizio m65-c1 picture flashing on and off on the screen
              by maricm
              HI all,
              hope someone point to the possible issue before I start buying replacement parts.
              Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
              Backlight stays on all the time,
              Sound works fine.
              screen keeps changing form black to full picture in about 1sec intervals.
              Picture looks fine with no visible artifacts.
              I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
              Disconnecting left and right ribbons on...
              11-25-2023, 06:32 PM
            • jason123
              Vizio P602UI-B3 No Picture or Sound - No TCON Voltage
              by jason123
              Help is much appreciated as I don't have any experience with this model TV.
              Picked it up and it was smoking in the back when powered.
              Open opening the LED Driver board was charred (see last photo.)
              I noticed some blown caps on the Power board as well.
              Replaced the LED driver board, and bad caps on Power supply.
              Voltages on CN301 (upper power supply connector to LED driver board)
              X000017 - All 24.39V
              GND - 0.001
              OD - 0.015
              VSNS - 0.009 (does that imply bad backlight or bad LED Driver?)
              11-14-2020, 08:43 AM
