Toshiba 52XV645U LCD Dead Power Supply
  • RCFLYER
    • Jan 2012
    • 36
    I have a Toshiba REGZA 52XV645U LCD TV with a dead power supply
    (V28A000962A1) With the help of a link on this website I found the culprit. https://www.badcaps.net/forum/showthread.php?t=15787 The fusible resistor R850 is open. My question is I found 2 resistors R827 and R828 showing thermal heat damage. What can cause these resistors to get so hot?
    I'm replacing two 150uf 450v capacitors that looked a little rounded but measured ok.
  • Namenotfound
    • Jul 2014
    • 14
    • USA!
    Re: Toshiba 52XV645U LCD Dead Power Supply
    I have a similar problem. A resistor reading open. I have yet to check those two. I just started "tv repairs" so I don't know very much however iv been reading a book on power supplies. But aside from the resistor I "found" (I was looking for a schematic and found a "repair kit" on eBay that pointed me in the right direction my meter reads 30vac from the chassis ground to neutral. Is this normal? Also I get ac readings past the bridge rectifier 50vac or so. Is that because of the way the meter works? I'm sorry please bare with my ignorance. And sorry for posting on your thread but I had to make my first post somewhere. Any help is appreciated.
    • Namenotfound
      • Jul 2014
      • 14
      • USA!
      Rcflyer what should those read. I'm getting .2oms. is that correct?
      Sorry I found it. First time Iv seen milli ohms.
      Last edited by Namenotfound; 07-18-2014, 09:10 PM. Reason: Just started with component repairs
        27m Ohms = 0.027 ohms, it is OK you are basically reading your probes resistance. The one on the right is 1.8 Ohms. The section of your pictures with heated reistors are in the PFC Voltage booster section.
        BTW, those AC voltage reading are due to there is no safety Ground wire connected to the chassis, as long as you are getting 120VAC at the AC input connector, it is OK. You use chassis as the ground ref point when you measure the voltage in the secondary side, the primary side circuit ground ref point is the negative leg of the main filter caps (those 450VDC cap).
        The fusible resistor that blown open probably due to shorted out MOSFETs for the PFC circuit.
        • Ltank
          • Jun 2013
          • 776
          I have had another set where a shorted part caused the low ohm 2 watt resistor to open. I was curious why use such a low resistance that will heat up and open. In over 30 years as an industrial electronics tech I dont remember coming across this before.
            It is not just regular resistor, it is fusible type.
            Learn more here:
            • Namenotfound
              • Jul 2014
              • 14
              • USA!
              Thank you! I bought one of those cheap esr/everything meters, it's not in yet. Any opinions on those? I'll check those MOSFETs tomorrow.
                You can use your meter in Ohm mode to check for shorts between the combination of all 3 legs of the MOSFET. When semiconductor is shorted out, there is no need to use Diode mode for testing them, I use Ohm mode so I can also see if there is leakage resistance of the semiconductor junction.
                • Namenotfound
                  • Jul 2014
                  • 14
                  • USA!
                  So I tested 5 MOSFETs and one pnp. The pic below is of my results. I was under the impression that I should have read OL when discharged with the diode check. However when switched to ohms readings were in M ohms. Is this usual or am I doing it wrong? Prob just a lack in experience. Also if I need to be posting somewhere else let me know where.
                  • Namenotfound
                    • Jul 2014
                    • 14
                    • USA!
                    The readings on the MOSFETs are between drain and source. All other resistance readings were OL. So I think the second one (q821) is bad or going bad? Resistance is higher? I checked it several times.
                    • Namenotfound
                      • Jul 2014
                      • 14
                      • USA!
                      I posted that wrong it's the first one q860a
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                      • Andreas_de
                        Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                        by Andreas_de
                        Hello!
                        i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                        Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                        Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                        04-12-2025, 10:38 AM
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • JimBanville
                        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                        by JimBanville
                        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                        09-13-2023, 07:21 AM
