I have this model 47zv650u Toshiba lcd and when plugged in there is no power at all. No lights on front of panel or anything. I'm guessing this is my power supply but wanted to get a second opinion. Haven't found a service manual yet so can't really check any voltages yet. Obvious fuses have been checked and are good.
Toshiba 47zv650u no power at all!!
Re: Toshiba 47zv650u no power at all!!
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Interesting layout. Messy, but interesting.
Close to the center of the board is a small transformer with a yellow strip of tape across the top. GC1 TRS02 DK is printed on the tape. Just above it is a 7 pin IC labeled with Q840 outlined in white. I believe that is the standby SMPS controller. What is the part number of that IC?
Got a question for you. I don't think it matters but this diode in the pics D875 checked right and i reversed the leads to see if it would read 0V and it didn't it started slowly creeping up to OL. Is this normal? Most diode's i've checked will check a small voltage one way and swap leads and it reads 0V. I removed the diode from the circuit and checked again and it read like a normal diode, low volt on one side and zip with reversed leads.Comment
in ciruit there are other components(capacitor most likely) causing your odd reading.
as long as it checks ok out of cicuit youre good.Comment
You have a winner!!! That is an STR-A6169, an integrated SMPS controller / power FET. The datasheet is here.
Fortunately the pins are marked on the board. Pin 3 is Ground. What are the voltages on pins 1, 2, 4, and 5? Do NOT check the voltage on pins 7 and 8.
PlainBill
pin2- .005
pin4 -.498
pin5 - .054
Doesn't sound too good to me but IDK.Comment
If you are REALLY brave, try measuring the voltage from pin 3 to pin 7 or 8.
The STR-A6169 is available from Amazon at a very popular price - $19.99 - a 1000% markup. You might also try searching for it under the Sony part number - 6-600-279-01
PlainBillLast edited by PlainBill; 08-07-2011, 03:47 PM.For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
You might be premature. You can trace this down yourself, or provide pictures of the surrounding area (top and bottom of the board). Pin 5 SHOULD be at the same voltage as the mains filter cap. The application note shows it connected directly, but there may be a resistor between them.
PlainBill
That amazon price is ridiculous.Comment
Well i got Ballsy and checked the 7 and 8 pins and had nothing. That chip doesn't seem to be getting anything. Shouldn't i be getting an input to one of those pins? Checked the surrounding resistors and they seemed to be ok and none are shorted. Here's a couple pics for you. Is there any way to check the IC if i pulled out of circuit?
If F840 is open, do NOT jumper it with a wire. There is a significant chance Q840 is shorted pin 8 to pin 3.
With power connected, what is the voltage across C20?
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by ju123Hi guys,
So, I've been racking my brains on this one.
I have a Satellite C50-A which I'm repairing for a friend.
I recently replaced the main board due to failure.
Following this, absolutely everything works perfectly, except for the fact it won't power down.
Initially, shutting down via Windows would shut the OS down, screen would turn off (noticed the lighter black go to what looks like the darker black powered off screen as though the backlights have powered off), however the laptop was still running internally with a spinning... - Loading...
- No more items.
