Burinng out cables on Baird PR32BAIRD
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    ok guys got this TV from a friend and when i plugged it in i got no backlight whatsoever, decided to pop back off tv and quick check of bulging caps etc however i noticed that the cable leading from PSU to Inverter was severely damaged, what could be causing this issue ?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Burinng out cables on Baird PR32BAIRD
    This is a case of bad connectors overheating. If the traces are ok on the board then just pull the connectors and use wires with no connectors. Replace the caps when you are at it because replacing them after is a real bugger.
    Follow the white rabbit.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      thanks for reply goontroon. will the caps need replaced though as there is none bulging etc ?
        • 31187
        probably not,
        he means it will be a lot simpler to change them now,
        than in a year when you cant seperate the boards!
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          ahh ok thanks. i actually pulled the same cable from another TV, plugged it in and it works fine now. but is that is all that was wrong just a cheap shoddy cable and connector ?
            • 31187
            problem with using another cable is that the connector is probably also damaged - and so it will burn the new cable.
            when you have a burned connector - you should replace both parts.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              echoing what stj says, the new cable will burn in the year that it takes the caps to fail, but that time it might take the traces with it.....
              it will be a lot simpler to change the caps now than in a year when you can't separate the boards, yes.
              • Mikeyboy2007
                • Mar 2013
                • 745
                • Scotland
                thanks guys.
