sony kdl-40v3000 lcd 8 red blinks?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    so I got this tv, when I press power the green light will come on for a second then goes red 8 flashing blinks, nothing else
  • R_J
    • Jun 2012
    • 9624
    Re: sony kdl-40v3000 lcd 8 red blinks?
    An 8X blink code is Speaker protection, The speaker connections on the au board are monitored for dc voltage, if this is detected the tv will shut down
    • mattstolte
      • Dec 2013
      • 612
      • usa
      so what needs to be done? change speakers? or the au board that speakers connect to?
        That means you have Class D power amplifier failure.
        • mattstolte
          • Dec 2013
          • 612
          • usa
          what board is that on that needs to be changed? the board the speaker wires connect to?
            Yes. Did you hear it makes any funny sounds before it goes into 8X error?
            You see this board in your TV.
            http://www.shopjimmy.com/sony-a-1433-191-a-au-board.htm
            http://www.shopjimmy.com/sony-a-1433...rd-rebuild.htm
            • mattstolte
              • Dec 2013
              • 612
              • usa
              I have that board yes
              • R_J
                • Jun 2012
                • 9624
                One thing to check is that the speaker wires are not shorted to the metal chassis anywhere, I did have one that the wires were pinched between the plastic and the metal chassis, as soon as the volume was turned up the tv went into shutdowm. If thats not the cause then the AU board is at fault
                • mattstolte
                  • Dec 2013
                  • 612
                  • usa
                  the thing is it wont even turn on so ill check
                  • Easy-fix
                    • Sep 2014
                    • United kingdom
                    I bought a set with this power supply totally dead, the only problem I can find D907 &D911 seem to be reading short. I recommend checking these for this fault
                    • jason123
                      Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                      by jason123
                      Hi there,
                      I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                      So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                      I see 2 posts that are relevant:
                      https://www.badcaps.net/forum/troubl...j-oled-5-blink
                      https://www.badcaps.net/forum/troubl...g-hardware-dev...
                      10-29-2025, 02:01 PM
                    • matwan
                      Sony XR-55X90J 5 blinks
                      by matwan
                      I have problem with SONY 55X90J. After several check status is as below;
                      1. Running power board as stand alone:
                      TCON_12V =~ 12.6V
                      EVDD V On Max 24V= 19V.
                      2.
                      Running power board with TCON as stand alone:
                      Effect as below, attched.
                      3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                      "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                      Best regards....
                      09-28-2025, 04:26 AM
                    • GoodCapDude
                      Sony XBR-75X940E intermittent 6 blinks error code
                      by GoodCapDude
                      Hi everyone. First post on Badcaps!
                      I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                      09-20-2025, 06:07 AM
                    • stav242
                      Sony KD-55X8509C white flashing/pulsing LED
                      by stav242
                      I was asked to look at a Sony KD-55X8509C as it was not powering on, no lights.
                      On inspection, there was no physical issues.
                      I seated all cables and repowered the TV, then the LED light flashed Green / Amber.
                      - this seems to indicate repairing required, done by Firmware update.
                      so downloaded the latest Firmware from Sony website and wrote to 4Gb USB drive.
                      Inserted the drive and repowered the TV.
                      LED changed to white flashing/pulsing ... and it sat there for over an hour.
                      i was unsure what was happening so repowered the TV and now it just...
                      01-08-2024, 07:39 AM
                    • AK_777
                      Sony KD-65A1 Repair – 4 Red Blinks Error
                      by AK_777
                      Hi everyone!
                      I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                      Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                      02-20-2025, 04:15 PM
