Vizio E422VA not turning on
  • tibimakai
    • Jan 2012
    • 3680
    Re: Vizio E422VA not turning on
    OK. I have supplied the 5V externally and the power supply shows 1.37A and the voltmeter 2.6V.
    It seems like the mainboard is pulling down the voltage. Both boards are doing the same thing, this is the weird part.
    I have tried disconnecting everything else going to the mainboard and the load does not change.
    I still have to check the resistance to the ground.
    • hienton2
      • Sep 2009
      • 183
      Did you check p.on from main. I doubt your second main is bad.
      • tibimakai
        • Jan 2012
        • 3680
        I haven't yet, but since the standby is low, that can't be good.
        • hienton2
          • Sep 2009
          • 183
          Feel hot on any components on main?
          • tibimakai
            • Jan 2012
            • 3680
            I didn't have time to check for heating parts, but PS_ON doesn't work and resistance from standby to ground is 2Kohm.
            • tibimakai
              • Jan 2012
              • 3680
              The 5V standby voltage should be able to power a car 6V bulb? Without anything connected, it shows 5.17V.
              The power supply can't handle this bulb, it just drops to 0V.
              I think, that there is a "weak" part in the power supply and can't handle the main board.
                It should be able to handle 5 Ohms Load (1A) without problem. Try heating the cap around the standby power supply section, especially the startup cap to see if will run properly.
                • tibimakai
                  • Jan 2012
                  • 3680
                  I will do that in the morning.
                  We are dealing here, with a surge.
                  • hienton2
                    • Sep 2009
                    • 183
                    #29
                    I will make a modified circuit to make it works. must figure R1 R2 to make output
                    about 4v (on) 0v(off)
                      That will invert the Active HI signal from the main board, the PS_ON signal must be >2V = ON, <1V = OFF. The output at the Collector is inverted from the Input at the Base.
                      I am not sure how the circuit is related to this thread. Also the signal is DC so you cannot put cap on the Base pin.
                      • hienton2
                        • Sep 2009
                        • 183
                        #31
                        Ok Budm. May be I am wrong here. It is an inverter a hi on p.o will make a low
                        out.I just want to make a higher voltage for his p.o from main board.As I think
                        his psu board is good.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I have reconnected all the wires into there connectors and plugged in all the connectors in there places.
                          Place the voltmeter into the ground and 5V standby and after plugging in, it shows 2.5V and (very)slowly creeps up. By heating the secondary capacitors and the ones before the standby transformer on the primary side, the voltage went up slightly faster. After a while, a white LED started to turn on brighter and brighter. It reached 4.3V after a long wait(had dinner).
                          The TV, still did not turn on.
                          The board in the picture is not my TVs board, I'm trying to point out the place, that seemed the most affected by the heat.
                            I believe that cap in red circle and the other 2 close to it are part of start-up/running caps, just replace them will be faster to find out if they are bad or not, they should be replaced sooner or later any way as part of the caps kit.
                            What is the P/N of that 8-pin IC close to it?
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Unfortunately, I don't have a 100uf/50V capacitor, only 25V. Need to place an order.
                              They use Elite capacitors in the PS, I have never heard about this brand.
                              Should I replace all of them?
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5096
                                • New Zealand
                                #35
                                Probably a good idea, Elite aren't that great
                                -David VanHorn
                                  Can I see the bottom side of the board? Also take the DC Voltage readings right at the two legs of those 3 caps, and also the P/N of that 8-pin SMPS IC next to the cap in red circle.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Sorry about not providing enough info, I was busy in the last three weeks, I had a visitor at my place.
                                    Today, I will get everything that you have asked.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      TV it's running, yeah!!
                                      I have replaced the circled capacitor(100uf/50V) and the orange one(330uf) after the transformer(in secondary part of the PS).
                                      I'm not sure now which fixed the problem, because the capacitor meter is not showing a constant value, but I'm suspecting the orange capacitor.
                                      At the bottom of the power supply where the capacitor is and the diode on a heating it's yellow, it runs to hot and dried out this capacitor. Capacitor meter shows a value around 157 out of circuitry and it should be 330uf.
                                      Easy fix.
                                      The problem is, that I have purchased a main board for $130 and is not needed.
                                      Thanks for the help.
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5096
                                        • New Zealand
                                        #39
                                        Good to hear!
                                        -David VanHorn
                                        • gtoira
                                          • Mar 2015
                                          I have this same problem exactly, but changing the caps made no difference. For tibimakai: Do you still have that board you bought and do you want to sell it? I don't know how to contact you or how this forum works. My email is iragoodberg at hotmail. Let me know how I can discuss my issue with you.
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • pedromvu
                                            Vizio M65-E0 not turning on
                                            by pedromvu
                                            Hi, I know these TVs are common to have problems like this, but unfortunately I was not able to find repair guide for this specific model or for something with this kind of power board.
                                            The thing is this doesn't have the 5vsb pin which is used to determine from which board the issue comes.
                                            Everything in power and main board was inspected without any apparent problems, but haven't measured everything.
                                            The voltages from Power to Main board are as follows:
                                            NC = 0
                                            A = 0
                                            BL_on/off = (Some millivolts, probably considered 0)...
                                            11-18-2022, 12:28 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • howardc64
                                            Vizio SmartCast TV software bug that looks like hardware
                                            by howardc64
                                            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                            11-16-2024, 05:17 PM
