Samsung ln40b550k1f no picture but has sound
  • HotHead
    • Mar 2011
    • 43
    Hi
    I have a samsung that does power on fine, shows a perfect picture and sound. After about 2-3sec the picture goes off but the sound stays on. The picture comes back on after about 5 sec and goes out 2-3 sec later. It does this four times then the picture does not come back on and the sound is still ok.
    I have tried different inputs(cable,av,ect) same results.
    I haven't opened it yet.
    What possibilities could it be? Most post I've read have been the inverter board, t-con, bad bulb but these post all said no picture at all.
    Any insight would be a great help.
  • R_J
    • 9588
    Re: Samsung ln40b550k1f no picture but has sound
    It sounds like a problem with either the inverter or it could be a failed ccfl lamp, Check the boards for bulged capacitors, post pictures of the power supply and inverter boards. all lamps must light, of one does not for whatever reason it will shut the inverer down.
    • Glitcher
      • Mar 2013
      • 673
      • USa
      Does sound like a ccfl lamp going bad. This model is also known for that problem.
      • HotHead
        • Mar 2011
        • 43
        I dont know why but i cant post pics.
        I open it up and there seems to be no visible problems that i can see.
        no bad caps or scorch/burn marks.
        Are the ccfl s easily accessible, i would think not. Can you test a ccfl?
        As for pictures, I'll try again but the page times out.
        • HotHead
          • Mar 2011
          • 43
          Here's the power supply/inverter board. this one uploaded.
          It's not too clear.
          • ecking767
            • Oct 2009
            • 492
            when you say the "picture goes off", do you still see backlight coming from the screen?
            try turning off the room light to confirm.
            • HotHead
              • Mar 2011
              • 43
              Goes off as in the ccfl turns off. no light whatsoever when picture is out.
              • R_J
                • 9588
                I have replaced the inverter transfomers in these before, you need to check the secondary resistance of the transformers. If my memory is correct, the three white transformers have dual secondary windings, the blue one only has one.
                • HotHead
                  • Mar 2011
                  • 43
                  hi again, sorry for the delay. Been busy but got around to testing inverters and finally was able to upload some pics.
                  After reading several tutorials i decided to test the transformer on-board as a first step.
                  not sure if i did the test right. I tried to follow the diagrams on a few sights for primary and secondary coils but got a little confused along the way.
                  I have edited the photos and put in the results i got with the multimeter. I used two settings, 1: @ 200ohm and 2: @20k ohm.
                  Again, not sure if i did this right. Do these results make sense to any of you.
                  I also added two other pictures that appear to have some discoloration near some solder points of transformers. Not sure if they are burn marks or residual flux from soldering?
                  • HotHead
                    • Mar 2011
                    • 43
                    Hi again. I take it from the lack of responses I have done wrong. :-(
                    Sorry.
                    I have taken the time to remove all three white transformers from the board and have tested them.
                    Multimeter set to 2k ohm
                    Transformer #1
                    Primary .013 secondary #1 1.171 secondary #2 1.174
                    transformer #2
                    primary .013 secondary #1 +#2 zero
                    Transformer #3
                    primary .013 secondary #1 1.071 secondary #2 zero
                    Transformer 3 broke while I was removing it. I forced it. My bad.
                    But transformer 2 came out easily and I get no readings from either secondary.
                    Are the readings for transformer 1 ok?
                    Should I just replace all three since they are out?
                    Why would transformer 2 not function, is it something else that shorted it out?
                    Any help would be appreciated. I'm still taking baby steps here.
                      I would replace all 3.
                      • HotHead
                        • Mar 2011
                        • 43
                        Ok, so I am back after a long wait. Here's the update!
                        Ordered some transformers qgah02095 012tm32c from overseas (instead of qgah02095 ny0924db) and wasn't too sure if they were the same even though they were for the same board.
                        Tested the resistance of each transformer and they all appeared good. Just finished replacing all three and the tv is now working with a picture and sound for over 45 min.
                        Hope it last years!
                        Thx for the help, this site is tops!!!
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • Mgiffune
                          by Mgiffune
                          06-09-2024, 10:28 AM
                        • Ierwin
                          by Ierwin
                          05-13-2025, 03:31 PM
                        • jchang
                          Samsung UN70NU6900F no picture and no sound
                          by jchang
                          Hi all
                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                          Symptom:
                          No picture no sound.
                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                          No sound at all.
                          What I tried:
                          1. I tried unplugging the left or right ribbon...
                          01-09-2023, 06:28 PM
                        • Dodgethis
                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                          by Dodgethis
                          Hello all,
                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                          09-11-2024, 07:39 AM
