Samsung LN46A630 - too bright picture
  • dsatya
    • May 2014
    • 11
    • usa
    Hi all
    I had this TV since 2009 and about 3 weeks ago started seeing this brightness issue. Initially I thought it was skin tones only. But it seems to be more than that. I do not have any issues with power cycling or red tinting,etc. I will figure out a way to add pictures here.
    The mfg date is Jan 2009
    I read about the capacitor issues and opened up the back and took pictures. The capacitors seem to be fine.
    Any help is appreciated...
    Sat
    PS: sorry for the upside down photos .. some reason picasa is showing them correctly but the images are upside down. will try and figure this out.
  • dsatya
    • May 2014
    • 11
    • usa
    Re: Samsung LN46A630 - too bright picture
    Forgot to mention..
    I called Samsung tech support and all they could do was to setup a repair call. They did not provide a cost estimate. I did try the factory reset once.
    • Shinju
      • Mar 2014
      • 1239
      I am going to go out on a limb here and say the AS15 gamma chip on your T-con board is going bad.
      There has been well over a dozen of these popping up over the last few weeks.
      Take a photo of the t-con board it's behind a metal shield.
        Take the DC voltage reading on those test points VGMA1~18.
        You have one of these two T-CON board.
        http://www.shopjimmy.com/media/catal...16584b-top.jpg
        http://www.shopjimmy.com/media/catal...03334j-top.jpg
        • dsatya
          • May 2014
          • 11
          • usa
          I had to open up the tv again!!!
          The tcon bord I assume is the one in the picture I am attaching. This was behind the metal plate at the top center of the tv.
          Bud, which points should I take a reading on. I am not sure about the VGMA1~18. Any guide I need to refer.. Thanks!!
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Third pic does illustrate a gamma type problem pretty well....
            Under one of the smaller heat-pads, one of the chips will probably be an AS15 chip--which is the suspect....
            TELEFIX
              http://www.shopjimmy.com/auo-55-46t0...-con-board.htm
              Picture provided by SJ.
              • dsatya
                • May 2014
                • 11
                • usa
                Bud,
                I will get to test them tonight. Also will check on the gamma chip version.
                Assuming the gamma chip is bad, are there other probable issues with these boards ?
                Wondering if I am better off getting a "New" from china or used/pull from ebay or getting mine repaired.
                I do not have the tools for replacing the chip myself.
                Ebay Pull: http://www.ebay.com/itm/Sceptre-X460...item1c3543c116
                thx
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  These gamma chips--Appear to have a finite lifespan, Some say 10-15K hours, dont know if this is the case, but we see loads of 'em faulty on this forum--and in real life!
                  Trouble with any used board--you just don't know how many hours on it....
                  Electronics--these days literally wear out, they are made to--Unlike some years ago.....
                  --Its a combination of things that causes this issue, lead-free/Rhos directive, smaller manufacturing techniques for chip components etc, all adds up to a finite life-span.
                  TELEFIX
                  • anotherdude
                    • Feb 2013
                    • 488
                    Electronics--these days, literally wear out--Unlike some years ago.....
                    easy money for the companies, TV breaks most people scrap them and buy another
                    same as anything really everything is built to break
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Planned Obsolescence its called--Driven by stupid brainwashed 'Consumers' and daft Govt 'growth' incentives--That Cannot Continue Indefinitely....
                      TELEFIX
                      • dsatya
                        • May 2014
                        • 11
                        • usa
                        I wanted to close the loop on this one. I got the board repaired by ShopJimmy. They were excellent. Fast turnaround after they received it (4 days from receiving to delivery).
                        The TV is back to normal!!!! Thank you all for your diagnosis and advice....
                        • tibimakai
                          • Jan 2012
                          • 3680
                          How much it was the repair?
                            Thanks for the follow-up, SJ charges around $67 for repair.
                              09-07-2024, 05:50 AM
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • JJAAMM
                              by JJAAMM
                              Problem
                              07-06-2023, 06:01 AM
                            • Schwoin
                              Philips 243v5lhsb00 Monitor Picture too bright
                              by Schwoin
                              Hey everyone,
                              the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                              While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                              you can see them on the top half of the photo.
                              At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                              03-21-2023, 12:40 PM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
