Sanyo DP32648 Backlight on/off
  • CraigR
    • Dec 2013
    • 973
    Sanyo DP32648 Push power and LED on front turns green then the backlight flashes on then goes out. Visually caps look good and I see no hot spots or anything out of the normal. I checked each inverter on the board with a test bulb and all looked fine so I would say not inverter or bulbs so something making it go into protect mode.But what to check next?
    Re: Sanyo DP32648 Backlight on/off
    DARFON inverter, so check the transformer secondaries using your multimeter's 20kohm range. With TV unplugged place meter across outer lower two terminals of transformer. Record reading for each.
    Any reading substantially different from any other reading indicates a bad transformer, which can be replaced, they are about $15 each on eBay.
    • CraigR
      • Dec 2013
      • 973
      I thought testing each transformer with a test bulb would show a bad one??
        Not necessarily - if your bulb requires less drive than the panel one it won't show a partially bad transformer.
        • CraigR
          • Dec 2013
          • 973
          Well just checked them all and all are about the same.
            Possibly a bad bulb in the panel then.
            • CraigR
              • Dec 2013
              • 973
              Doubt it since I tried a bulb on every transformer and I got the one with a bad bulb then TV would have stayed lit. Make that 2 size bulbs tested on every one.
              • CraigR
                • Dec 2013
                • 973
                My bad tom66, I took another meter (el cheapo) and did find a bad transformer.
                • CraigR
                  • Dec 2013
                  • 973
                  Got another board and that fixed it! Thanks tom66.
                  • zman6
                    • Jan 2015
                    • 9
                    CraigR I have the same problem that you had same model which board did you replace the one with the inuts or the tan board in your second picture? Thanks
                    • CraigR
                      • Dec 2013
                      • 973
                      the green inverter board.
                      • zman6
                        • Jan 2015
                        • 9
                        So the board in your first picture? Sorry I am new to this.and would like to try to fix it before I purchase a new one. Thanks
                        • CraigR
                          • Dec 2013
                          • 973
                          Last pic.
                          • zman6
                            • Jan 2015
                            • 9
                            Ok thanks
                            • zman6
                              • Jan 2015
                              • 9
                              By chance CraigR do you still have your old board or the transformers from it? I found 1 bad one on mine and was unable to fund it online.
                                http://lcdparts.net/TransformerDetai...ProductID=2771
                                4013Lxxxx
                                • dehrhard
                                  • Sep 2015
                                  • 5
                                  Hey folks, got a question.
                                  I was checking the resisitance of the tranformers on the inverter board and found some variances. My question, is it enough to call a transformer "bad"?
                                  The secondaries varied from
                                  1.078 K to 1.093 K
                                  The primaries varied very little.
                                  0.15 to 0.16 ohms
                                  Thoughts?
                                  • triplefour
                                    by triplefour
                                    09-13-2023, 10:43 PM
                                  • DanPoka
                                    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                    by DanPoka
                                    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                    02-15-2025, 05:05 AM
                                  • Comp_Pro
                                    No Backlight Macbook A1990 820-01041
                                    by Comp_Pro
                                    Hello all,
                                    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                    Tests performed:
                                    There is no backlight even with a good screen.
                                    Backlight IC is receiving the correct support voltages.
                                    Fuse F8400 ok
                                    Current sense resistor R8400 ok
                                    Backlight IC is receiving 3.3V on enable pin.
                                    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                    Backlight IC receiving 5V from PP5V_G3S
                                    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                    05-06-2024, 10:23 PM
                                  • jimbofz
                                    lg 32LC46 backlight inverter board fault
                                    by jimbofz
                                    Hi this oldie had no backlight .after replacing caps on 24v rail ,
                                    still no b/l this uses inverter type:1315 B1-16A,
                                    im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                                    all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                                    this allows protect to be temporary overridden.
                                    b/l now comes on
                                    but the left hand side of pic is gradually darker than the right side
                                    i have the cct for the tv
                                    but it does not have inverter cct.
                                    i opened it up to inspect the ccfl tubes
                                    and they dont have any...
                                    12-19-2021, 06:58 AM
                                  • cheebster
                                    iPad Pro 12.9 5th Gen Backlight Issue
                                    by cheebster
                                    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                    Anyone...
                                    05-20-2025, 09:17 AM
