Any one any idea how to get rid of these shaddows
lg lcd 32 shaddow on screen
Tags: None
Re: lg lcd 32 shaddow on screen
I've had a few like that from my experience it cannot be fixed.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
For future reference would you share what you did to make it work?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Yer it was only a cap change so did not think it was worth it swollen capsComment
Ah KK, yeah, same generation as the 5D/7D.
I had a 42LC46 with bad caps and it had no screen issues... guess it's just bad luck.
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... -
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... -
by spice_discI'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...1 Photo -
by ipatchi have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
- Loading...
