lg lcd 32 shaddow on screen
  • adamp91gvm
    • Jan 2014
    • 706
    Any one any idea how to get rid of these shaddows
    • 31187
    Re: lg lcd 32 shaddow on screen
    i call that "bruising",
    it's caused by pressure damaging the glass sandwich afaik.
    i'v also seen what looks like a liquid-stain in one corner once that i think is caused by ecessive heat.
    i dont think you can fix it.
      I've had a few like that from my experience it cannot be fixed.
      • adamp91gvm
        • Jan 2014
        • 706
        Dam just made it work it would not turn on
          For future reference would you share what you did to make it work?
          • adamp91gvm
            • Jan 2014
            • 706
            Yer it was only a cap change so did not think it was worth it swollen caps
              Was it a 32LC5D or 32LC7D?
              • adamp91gvm
                • Jan 2014
                • 706
                32lc46
                  Ah KK, yeah, same generation as the 5D/7D.
                  I had a 42LC46 with bad caps and it had no screen issues... guess it's just bad luck.
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • spice_disc
                    Vizio TV M50-C1 reboot cycle and static on screen
                    by spice_disc
                    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                    09-08-2024, 02:37 PM
                  • ipatch
                    ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                    by ipatch
                    i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                    08-24-2024, 02:36 PM
