E390vl help with regulator testing
+ More Options
Posts
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: E390vl help with regulator testing
    Right now since I replaced the flash chip I still get 5v on both sides of the 5v fuse on the main board but the standby logo light doesn't light up and the set will not even try to turn on.
      Well, did you get it the right way round? Did you damage the pads when soldering it?
      • ecking767
        • Oct 2009
        • 492
        Originally posted by audiofreak19
        No the fuses on the main board are not shorted. They are fine.
        they are shorted not open, anyway I will check the audio section mainly the audio chip
        • audiofreak19
          • Apr 2013
          • 556
          • usa
          The pads are good no damage when soldering.
          • audiofreak19
            • Apr 2013
            • 556
            • usa
            Ecking I'm not sure what your saying. Sorry. I did a continuity test on the 12v fuse and it read continuity.
            • audiofreak19
              • Apr 2013
              • 556
              • usa
              #26
              I soldered the old chip back in and it still does the same thing. I'm wondering if somehow I shorted something else in the main board.
              • audiofreak19
                • Apr 2013
                • 556
                • usa
                #27
                O another thing I should note is when I went to buy this from the guy he told me it would turn on as I stated in the first post. But when he plugged it in the tv didn't turn on nor the vizio logo as it is doing now.
                • audiofreak19
                  • Apr 2013
                  • 556
                  • usa
                  #28
                  Ok another update. With the tv just plugged in. A small adj regulator is hot like burning to the touch hot
                  • audiofreak19
                    • Apr 2013
                    • 556
                    • usa
                    #29
                    And that regulator the in has 3.28v. The out has 1.071 and slowly increasing and the adj reads 0. Does this sound like its bad
                      That does not sound good. Is the regulator running warm? What is its part #?
                      • audiofreak19
                        • Apr 2013
                        • 556
                        • usa
                        #31
                        The regulator is running hot like it burns to touch it. And that's just with the tv plugged in not even on. I don't remember the part number but it's one of the two that I listed in the first post I know that.
                        • audiofreak19
                          • Apr 2013
                          • 556
                          • usa
                          #32
                          I think it reads H 1117C then below it says 1.2v then 207.
                            It is bad. If it is running real hot you probably have a bad regulator, bad output capacitor or a problem with your load (e.g., a shorted CPU.) An oscilloscope can help check #2.
                            • audiofreak19
                              • Apr 2013
                              • 556
                              • usa
                              #34
                              What's the best way to troubleshoot this. I don't have a ocilloscope and haven't used one before.
                              • audiofreak19
                                • Apr 2013
                                • 556
                                • usa
                                #35
                                I'm wondering if it's the CPU. That would be a flat square chip with a million little solder joints right. Cause there is one next to the flash chip I put in an some solder splashed on some of the legs and I didn't realize it until after I already tried to plug it in.
                                  If you splashed solder like that, are you sure you made no other bridges?
                                  • audiofreak19
                                    • Apr 2013
                                    • 556
                                    • usa
                                    #37
                                    I honestly don't know how I splashed the solder cause I actually made really clean connections. It might have been when I took the old chip off it might have dropped some solder. But I was able to brush it off once I realized it.
                                    • audiofreak19
                                      • Apr 2013
                                      • 556
                                      • usa
                                      #38
                                      Ok so I just checked the tv and took some Picts. I still have the old flash chip in it and just out of curiosity I plugged the tv in after it sitting for over 4 hours and the vizio logo lights up again and does the origonal problem again. So I'm gonna try the new flash chip again and make sure solder doesn't get on anything. And see what happens.
                                      • audiofreak19
                                        • Apr 2013
                                        • 556
                                        • usa
                                        #39
                                        Here is a pict of the regulator that was hot when the logo wasn't lighting up.
                                        • audiofreak19
                                          • Apr 2013
                                          • 556
                                          • usa
                                          #40
                                          Here is a pict of the flash chip re installed. Now after letting it sit the logo lights up. The tv turns right on and the V logo appears for a couple seconds then the whole tv shuts down ad the logo turns off. Only way to get it back on is to unplug the tv and plug back in
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • Per Hansson
                                            Repair of Sign WiFi Smart Plug PCB: SA-P302A v1.2 due to bad caps - with schematic
                                            by Per Hansson
                                            I have repaired a Sign WiFi Smart Plug with model number: SNSM-WASINGLE sold by Spares Nordic AB in Sweden.
                                            The fault condition was that the device gave no signs of life: pressing the push button did not cycle the internal relay and the blue LED did not come on and it was not seen on the WiFi network.
                                            The fault was very simple, capacitor C3 on the PCB with writing "KSJ" and "LOWESR" had literally blown its top off, after replacing it the device works fine again!
                                            As I find linear high voltage regulator designs interesting I drew up the attached schematic...
                                            12-23-2023, 06:20 AM
