I got a e390vl. And I plug it in the vizio logo lights up press power and the set turns on the screen turns on displays the vizio splash screen then tv shuts off even the logo and will not turn back on. I checked and I'm getting 5v standby but no 12v. So I'm thinking its a v regulator. I'm having issues checking them cause I cannot read the writing on all of them. One reads ax1008 then 12101. Another regulator reads H 1117C then below it says 1.2v then 207. And another regulator I can't read the writing but I can make out 1117
E390vl help with regulator testing
Tags: None
Re: E390vl help with regulator testing
Also I checked the 12v fuse on the main board and it doesn't get any voltage. Does the main board send 12v to the power board or is it the other way around? -
I'll bet corrupted flash over regulator on these, this is a newer Vizio (39" panels didn't start appearing until 2012) so you proboably want to focus on that, especially if splash screen pops up.
Not saying it isn't a regulator, but flash memory failure is 99x more likely, in my opinion, the bane of Vizios.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Also on the regulator that I couldn't quite read. The ground pin read.257v shouldn't it be at 0.Comment
You can sometimes buy the flash chips on ebay for about $20. But if not you would need a new main board.
If a regulator is adjustable the ground isn't usually 0V but is instead floating about 1.25V below the output.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
That is what it is sometimes called, although incorrectly.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Also is there a way to test the EEPROM to make sure it's working.Comment
Also I'm not sure if I was clear when I said it turns off. The tv then would not turn back on even if I unplugged it and pressed the power button for 30sec and plugged back in.Comment
No way to test the flash as far as I'm aware unfortunately.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
How do I figure out which chip on the board is the EEPROM I have the new one just don't know how to find the origonal oneComment
Also does it matter which way it goes in? Meaning there is no marking of which leg is leg one and which on is leg eight.Comment
Yes it does. You need to locate pin 1 marker on your original device or on your board. Then solder new one same way round...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Some of these small flash-chips have a side thats sloped--thats the side on which is pin 1
Just gotta look carefully at them--There'll definitely be a marking or indentation or some kind of indication which end/side is which....
The part number--is generally printed the same way on these things when they are by same maker--but not always the case.TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
So on this one it has a dot in the corner of the chip and that actually matches up with the pad side of the pcb that has a dot in the same corner. I figured it out by looking at the other chips on the board and they all were the same way. So I got it soldered in but when I plug it up the tv does nothing. Not even light up the logo. I have 5v standby at the fuse on the main board.Comment
The +12v supply power to (coming from the power supply) the audio amp and the LCD screen, are you saying the 12volt fuse is open?Comment
No the fuses on the main board are not shorted. They are fine.Comment
Assuming...7 Photos -
by sam_sam_samI bought one recently but this is the first weekend that I did not have work Saturday morning or the sun did not want to cooperate with me but today it is coordinating with me and I run a very simple test on a 12 volt battery pack and it stop charging ar 14.4 volts
Here is the website link where I bought it from
https://www.ebay.com/itm/395434828814
I ran this test with a new 12 volt solar panel that has a no load voltage of 19.0 and an output current of 9.1 amps
I do not remember the starting voltage but the charging amps was 1.4 amps
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by disorderhello,
i have a hp display 2311 to repair, totaly dead
on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
thank you-
- Loading...
