Vizio E470VL, no picture
  • dav255
    • Apr 2014
    • 5
    I have a Vizio E470VL that displays no picture. The backlight turns on, sound comes on, but there is no visible picture. No Menu's, volume, input, just a nice backlight black screen.
    I am unsure what caused this issue as it was handed down to me and I thought it would be a quick repair.
    I searched all over google through forums and concluded it was the main board I had to replace. So i bought one from ebay and swapped the part. Exact same issue. So I thought maybe something from the power board is malfunctioning.
    Returned the first main board and bought a power board. Swapped the power board, same issue. I thought maybe I got a bad part from ebay the first time since everything kept pushing me to conclude it was a main board issue.
    Returned the power board and got a new main board from a different seller on ebay. Swapped the board, same issue... I am returning the new board and keeping my old board since i noticed the same issue.
    I have concluded my boards are good, and the issue lies else where. I believe the issue has to be either the ribbo inen cable, or the lcd screen.
    My question is am I missing something between the board and the lcd screen? I see the ribbon cables connect to the top of the lcd panel and see two small boards. Not sure what they are or do. It is also my understanding that this tv has the tconn integrated to the mainboard.
    I am also unsure what happens when an LCD screen goes bad. Hope I was through in explaining my issue.
    Re: Vizio E470VL, no picture
    Check the surface mounted fuse on the T-CON board to see if it has 12V (or 5V depends on the LCD panel) on both ends of the fuse, this board is under the metal shield. Pictures of the back of the TV will help. Your panel may have integrated T-CON board type.
    • Glitcher
      • Mar 2013
      • 673
      • USa
      Hmm, assuming that the two new main boards are good and there is no tcon board for this set the last thing left would be the panel itself I'm afraid...
      • dav255
        • Apr 2014
        • 5
        Sorry for the late response, here are a few pictures of the back.
        Quality is a little bad due to phone camera.
        http://imgur.com/a/ioc3M
        • dav255
          • Apr 2014
          • 5
          When I unplug the left ribbon cable i get an image on the right but white on the left.
          http://imgur.com/aUIJheP
          So it looks like my panel is good. but something goes bad when I plug in the left side.. Any suggestions?
          • dav255
            • Apr 2014
            • 5
            I tried some other combinations and now I cant get the backlight to come on. Tried the flash light test and did not notice a picture either.
            • amdmadcap1
              • Feb 2015
              Did you get an answer to this? I have the same exact issue on a Vizio E470VLE
              • nomoresonys
                • 12331
                • U.S.
                another NO FOLLOW UP, gee thanks.
                • nomoresonys
                  • 12331
                  • U.S.
                  amdmadcap1, try to post good clear pics. of each board and one of how they are all connected, maybe start by testing expected voltages on power supply board, there should be a label by the connectors, as always be careful working with power supply, HIGH VOLTAGE, on primary side can be deadly.
                  • nomoresonys
                    • 12331
                    • U.S.
                    might as well use this abandoned thread, cuts down on clutter anyway.
                      That means you have bad panel, the TFT drivers or MLCC shorted out.
                      • ralphebuoy
                        • Feb 2015
                        • united states
                        i have a similar issue with vizio vo47l-fhdtv10a i googled my problem, and followed a few suggestions. i did the flashlight test and did see images, which i was told means one or both of my inverters were bad. i just received the parts today( by the way i ordered them from shopjimmy.com i paid $44.00 including shipping, for both master and slave) installed first the master and when that did not resolve the no pic issue i added the slave, same problem i can see images with flashlight,but no pic.
                        could it be a fuse or the back-light itself and if it is the back-light would that be a relatively easy fix?
                          Do you have 24VDC from the power supply board feeding the inverter boards?
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • Tr0ll
                            by Tr0ll
                            Original T-con:
                            First replacement T-con:
                            10-07-2023, 07:48 PM
                          • Soulzink
                            Samsug washing machine. Power supply DC41-00189a board issue
                            by Soulzink
                            I am trying to fix a samsung washinmachine power supply main board.
                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                            The power supply board reference is the following: DC41-00189a
                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                            04-19-2025, 06:26 AM
                          • gavric
                            Vizio M70-C3 Half picture is bad, main board on its last leg?
                            by gavric
                            Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                            When tv powers on vizio V logo shows nice on whole screen. picture 1
                            When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                            When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                            When i click video to start playing picture goes black(like when you change...
                            09-02-2021, 08:55 PM
                          • Asraf Atb
                            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                            by Asraf Atb
                            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                            01-27-2025, 05:02 PM
