magnavox 32MF605W TV wont turn on
    Re: magnavox 32MF605W TV wont turn on
    First we need to figure out if the PSU is working - if the voltages are low or if some are missing it could cause a loss of backlight.
    • jack1
      • Mar 2013
      • 30
      • usa
      i checked in vdc mode . left top 10 pin conn to vid board 53.7 53.5 53.6 53.553.6 41.2 37.9 37.937.8 37.8 9pin conn right top to main board 47.5 47.6 53.5 41.0 39.7 37.6 37.6 39.9 37.8 5 pinn conn bottom left 39.8 39.8 39.0 39.8 39.7 thats all on power board
        Sorry, but none of those readings make sense, you are either checking it wrong or your meter is not working.
        PLEASE check a fresh AA battery so we can see if your meter is working.
        • jack1
          • Mar 2013
          • 30
          • usa
          changed power cord now backlight comes on for two seconds. if you could tell me what readings should be and also where to hook up black probe on board i could give you right readings .i am sorry for miscommunication on my part i am trying to learn
            Tell us first as to where you put the Black probe of the meter? How about testing the battery voltage as Tom has suggested?
            • jack1
              • Mar 2013
              • 30
              • usa
              #26
              yes i checked with battery. negative side of large cap 120 uf 450v
                You should use the CHASSIS as your ground, i.e. metal shielding. Not the negative of the capacitor.
                • jack1
                  • Mar 2013
                  • 30
                  • usa
                  #28
                  using proper ground 14.5 14.5 23.9 1.4 3.2 0.0 0.0 0.0 3.2 0.0 to main board
                  • jack1
                    • Mar 2013
                    • 30
                    • usa
                    #29
                    thanks for help . i found problem inverter board has visable short on board
                    • pajdek
                      Lenovo Y700-17ISK turn on and off
                      by pajdek
                      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                      09-20-2023, 02:49 AM
                    • RdeveLabs
                      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                      by RdeveLabs
                      To all the members here...
                      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                      05-05-2025, 04:59 AM
                    • robante15
                      Acer Aspire 4520 won't turn on after reboot
                      by robante15
                      Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                      It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                      The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                      If I remove the...
                      04-06-2024, 06:50 PM
                    • masoksian
                      Dell latitude e7470 not turn on .power buton on off and Run Power problem
                      by masoksian
                      I am dealing with the problem of turning on and off my Dell e7470 notebook.
                      The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                      The system does not turn on, there is no post.
                      I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                      The problem continues in the same way.
                      I tried to turn on the Fn key, nothing came to the screen....
                      02-15-2025, 12:08 PM
                    • dqtech
                      lenovo x240 nm-a091 wont turn on
                      by dqtech
                      i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                      board number VIUX1 NM-A091 REV:1.0...
                      02-07-2024, 01:57 AM
