Sony KDL-32L4000 panel/ t-con problem
  • Shinju
    • Mar 2014
    • 1239
    Greetings!
    Got this sony when the screen is on the top 2 inches displays fine the other 90% of the panel is blank. After about 2-5 minutes several hundred lines start appearing no real image but you can see the lines shifting.
    I read this particular series of sony panels had bonding issues with the ribbon cables I do not have any cold air cans to see if that's the case I did however press pretty firmly all over the litter edges of the panel and nothing changed.
    Here are some images if the guts, possible t-con issue or a bad panel?
    Thanks friends!
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: Sony KDL-32L4000 panel/ t-con problem
    Looks like a bad panel
    • Shinju
      • Mar 2014
      • 1239
      Ah, I am going to break it down further and check the ribbon cables.
      Probably a parts pig!
      • iglitare
        by iglitare
        09-04-2025, 07:13 AM
      • kca
        by kca
        Hello all ~
        08-31-2025, 06:38 AM
      • rimwall
        Sony KD-65x8500b - bad Tcon or panel?
        by rimwall
        Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
        a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
        b) the Tcon board is malfunctioning,...
        10-24-2023, 07:58 PM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • netgearnetgear
        TCL 43S423 TCON OR PANEL FAULTY???
        by netgearnetgear
        Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
        08-20-2025, 06:04 PM
