Sony KDL-32L4000 panel/ t-con problem
  • Shinju
    • Mar 2014
    • 1239
    Greetings!
    Got this sony when the screen is on the top 2 inches displays fine the other 90% of the panel is blank. After about 2-5 minutes several hundred lines start appearing no real image but you can see the lines shifting.
    I read this particular series of sony panels had bonding issues with the ribbon cables I do not have any cold air cans to see if that's the case I did however press pretty firmly all over the litter edges of the panel and nothing changed.
    Here are some images if the guts, possible t-con issue or a bad panel?
    Thanks friends!
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: Sony KDL-32L4000 panel/ t-con problem
    Looks like a bad panel
    • Shinju
      • Mar 2014
      • 1239
      Ah, I am going to break it down further and check the ribbon cables.
      Probably a parts pig!
      • rimwall
        Sony KD-65x8500b - bad Tcon or panel?
        by rimwall
        Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
        a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
        b) the Tcon board is malfunctioning,...
        10-24-2023, 07:58 PM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
      • swrb898
        Sony KD-70X690E Bravia; Bad TCON? Bad panel?
        by swrb898
        What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
        Problem:
        Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
        My troubleshooting got me this far:
        With the left-hand TCON to bottom-board ribbon cable...
        12-28-2021, 08:12 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
