Sony Bravia KDL-40EX400 will not power up
  • suiramix
    • Mar 2011
    • 131
    Just another typical case of 3 years old Sony KDL40-EX400 lcd tv which refuse to power up (dead) by pressing the remote or tv set power button … no electronic components damaged or swollen capacitors so far …so I started checking the power supply output voltages .
    According to power supply G2HE circuit diagram (attached) at connector CN6101:
    pin 1 [STBY 3.3V] = 3.31V
    pin 2 [AC OFF DET] = 0V , and everything else is 0V
    According to training manual ctv-61, if the tv in plugged in an active power outlet, AC OFF DET should have 3V …so the power supply / IC6301 (CXA3809M) is defective… at this point what other voltages should I measure before replace anything else ?
    Re: Sony Bravia KDL-40EX400 will not power up
    What voltage do you have at pin 3 AC DET IN and at PIN 23 of the IC6301 (Ground ref point at the negative leg of the main filter cap)?
    BTW, do you have the link to the full SCH of this TV?
    • suiramix
      • Mar 2011
      • 131
      Hi Budm... thanks for fast reply (btw, big fan of your photobucket pictures) ...so IC6301 has voltage on pin 3=2.68V and pin 20=9.48V
      Unfortunately, I have no other schematics of this lcd tv !
        You could try as a quick test disconnecting the AC OFF DET wire from PSU and connecting it to STBY 3.3V. Use a 100 ohm resistor in series to protect the main board in case there are any shorts.
          Pin 23 is the one I need, if that pin is low the LED in the opto will be on which will turn on the photo-transistor which will cause the AC DET to be low and lock out the circuit. Normaly, the AC DET will be high if this is the same detection used in other SONY power supply. Or you can try TOM's method.
          • suiramix
            • Mar 2011
            • 131
            I was doing a lot of reading regarding Sony CXA3809M IC and according to the pdf. datasheet , recommended VCC (pin 20) should be 12 to 18V …sorry for earlier confusion ! Tonight I will measure the voltage at pin 23 !!! Thanks again Budm and Tom!
              Hmm:
              Under Voltage Lock Out Circuit Block (VCC pin)
              Item Symbol Measurement conditions Min. Typ. Max. Unit
              Turn-on voltage Vact 10.2 11.0 typ. 11.8 V
              Turn-off voltage Voff 9.0 9.6 typ. 10.2 V
              Hysteresis Vact-Voff Vact – Voff 1.1 1.4 1.7 V
              So you have indicated the VCC of pin 20=9.48V.
              That is low. Are you getting about 360~400Vdc (measured at the two legs of the cap) on the main filter cap?
                Please check the DCV on the cap C6117, it should have around 18VDC, if not check the cap and the two Zener diodes.
                • suiramix
                  • Mar 2011
                  • 131
                  Hi BudM....so IC6301 has voltage on pin 23=0.1V...main filter cap C6325 has only 168.3V and C6117 has 10.15V...!!!
                  • suiramix
                    • Mar 2011
                    • 131
                    Just a quick update... I did replace C6117 and C6323 with new one, but almost the same voltage reading . Can someone tell me why all the capacitors are rated to 105C except the main one (270uF/450V) which is only 85C and so close to the biggest heat-sink ???
                    • mixmix
                      • Jul 2014
                      • Portugal
                      You solved this issue? i have teh same problem.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        There is a 40EX500 in this list and it shows a bad CXA3809M IC if the TV it's
                        dead.
                        http://www.mikestvtips.com/index.php...le%20Histories
                        I had a similar issue with a 46" which had a 6x blinking light and it was the mainboard.
                          Oops, wrong thread.
                          • t4796
                            • Feb 2015
                            • 79
                            If you have ~10v across C6117 could the mean one zener is short so you're only getting 9.1 (maybe ~10v on your meter) across it?
                            • t4796
                              • Feb 2015
                              • 79
                              actually i think the zener are there to protect the ic in case the voltage goes above 18.2v is this right? i can't edit my other message
                              • coofhair
                                • Apr 2014
                                • 4
                                • viet nam
                                Thank for helpfull
                                • PopsCaps
                                  Sony Bravia KDL-40V2500 that will not power on
                                  by PopsCaps
                                  I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                  I do not hear any sound and I cannot see any backlight.
                                  I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                  The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                  My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                  03-25-2025, 11:23 AM
                                • PantherDave
                                  by PantherDave
                                  Hi all!
                                  05-29-2024, 02:01 PM
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                • repair-it
                                  SONY Bravia OLED XR-77A80J will not power on
                                  by repair-it
                                  SONY XR-77A80J shuts off as soon as it is powered on. It goes into standby ok when plugged in but when power button is pressed, relay clicks and tv powers off. Power supply board makes a sound that sounds like momentary coil whine when it clicks off. The main board appears to turn on and has working optical.
                                  I pulled the power supply board for visual inspection & there wasn't anything obvious. I am not sure how to go about testing this OLED as it is a bit different than the last one (LG) I tried to repair. The only voltage listed on the PSU is 12v for T-CON. The 12v is not present...
                                  01-24-2024, 10:15 PM
