Sceptre X32
    Re: Sceptre X32
    OK, check the resistance between #1 and #2 (I do not know if it is fusible resistor or jumper wire).
    • thetonywarren
      • Feb 2013
      • 169
      Re: Sceptre X32
      when I have my multimeter set on ohms for resistance my meter beeps as if it has continuity
      both with power off and power on
        Re: Sceptre X32
        Fuse is OK, could be one of those red poly caps is bad, or the driver IC is not driving the bulbs. My bet would be on the red poly caps.
        • thetonywarren
          • Feb 2013
          • 169
          Re: Sceptre X32
          when I check across points1 and 2 that is.
            Re: Sceptre X32
            Yes, those two caps are part of the bridge drive circuit for the inverter transformer. If you have the scope, you will need to find out if there is GATE drive signal from T2 or not.
            • thetonywarren
              • Feb 2013
              • 169
              Re: Sceptre X32
              This is going to turn into a really fun thread. Yes, I do have a scope, but I have absolutely no idea how to use it, bought an old Heathkit tube scope from a guy on craigslist, it's been sitting on my bench, but I dont even have a probe for it, let along know what knob to turn and make stuff happen. Can we go down this road, or am I asking too much? I can provide pics on the scope.
              Thanks to all, this is getting fun....for me at least
                Re: Sceptre X32
                Picture of the scope - we might be able to suggest probes you can use.
                • thetonywarren
                  • Feb 2013
                  • 169
                  Re: Sceptre X32
                  before I do that, should I take both of the red caps out of circuit and test them with my esr meter? or are they different that I cant test? I have only tested electrolytic capacitors up to this point with my esr meter.
                    Re: Sceptre X32
                    You are going to have isolation transformer to plug this power supply board into for safety, there are other ways to do it but dangerous.
                      Re: Sceptre X32
                      An ESR meter can't test those, but if you have an ordinary capacitance meter it probably can.
                      • philliesfan30m
                        • Aug 2013
                        • 542
                        Re: Sceptre X32
                        mip320fl-t3 transformer is bad but finding a replacement is almost impossible because they don't sell just the transformer everywhere i looked. just spend the $34 and buy a mip329fl-q3 new power/inverter board. thats from china so it will take a while for shipping. what is the resistance between the 2 output pins of that transformer around 68 ohms? if you do by a new board compare the resistance of the old 1 to the new 1.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5095
                          • New Zealand
                          #32
                          Re: Sceptre X32
                          Not sure what you mean by that but if you are testing resistance of parts in the PSU while the PSU is turned on that is a bad idea! You can damage your meter and maybe the PSU too.
                          -David VanHorn
                          • thetonywarren
                            • Feb 2013
                            • 169
                            Re: Sceptre X32
                            sorry, I did not know that, is there a reason why?
                            Please let me know.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5095
                              • New Zealand
                              #34
                              Re: Sceptre X32
                              To test resistance, the multimeter outputs a small voltage into the test leads and across anything you connect it to for measuring. It actually measures the resulting current flow and converts that into Ohms.
                              If you connect it to a live circuit, high voltages\current could be applied to the meter circuitry, and cause damage.
                              -David VanHorn
                              • thetonywarren
                                • Feb 2013
                                • 169
                                Re: Sceptre X32
                                I just ended up buying a new power supply/inverter board on ebay, the mip329fl-q3, which looks like it may have some improvements over the one that failed. FYI.
                                • huckster24h
                                  • Mar 2015
                                  • 6
                                  Re: Sceptre X32
                                  Can mip320fl-q3 be used to replace mip320-2??. They look the same (same PCB). But I do not know the specs.
                                  • Soulzink
                                    Samsug washing machine. Power supply DC41-00189a board issue
                                    by Soulzink
                                    I am trying to fix a samsung washinmachine power supply main board.
                                    I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                    Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                    The power supply board reference is the following: DC41-00189a
                                    I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                    04-19-2025, 06:26 AM
                                  • Asraf Atb
                                    by Asraf Atb
                                    01-27-2025, 05:02 PM
                                  • Stephen
                                    A2991 Logic Board issue, 20volts 0 amps help!
                                    by Stephen
                                    Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                                    09-10-2025, 03:16 PM
                                  • Stephen
                                    A2991 logic board issue, 20volts 0 amps help!
                                    by Stephen
                                    09-10-2025, 03:15 PM
