VIZIO SV470M orange to white logo
    Re: VIZIO SV470M orange to white logo
    Just a guess but possibly a cold solder joint under the main video processor.
    • CraigR
      • Dec 2013
      • 973
      I will get some freeze spray and and try that and see if it makes a difference.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Remember the story of the shoemaker and the elves??? Well you may not have elves but a cold solder joint or joints.....This happened to me so time ago with CRT TV.....Most troubling repair, I tell you...
        • CraigR
          • Dec 2013
          • 973
          Well put it all back togather and hooked it to cable and beautiful picture but No sound. So it looks like I still need a main board. Just can't find one anyplace.
          • CraigR
            • Dec 2013
            • 973
            Found one and that fixed the problem.
            • johnboy1313
              • Nov 2012
              • 1959
              Thanks for the update.
              • MisterD
                • Oct 2012
                • 668
                I need the same mainboard 3642-0692-0150, where did you get yours?
                • CraigR
                  • Dec 2013
                  • 973
                  eBay
                  • RICHARD REISNER
                    • Jun 2016
                    Originally posted by CraigR
                    I just measured what I could see. it goes from left to right.
                    U9
                    556mV
                    1.8V
                    3.29V
                    U5
                    2.04V
                    3.2V
                    5.07V
                    U3
                    2.04V
                    3.29V
                    5.03V
                    U7
                    2.03V
                    3.28V
                    5.07V
                    U6
                    6.96V
                    8.21V
                    12.13V
                    U2
                    2.05V
                    3.29V
                    5.10V
                    U4
                    1.46mV
                    1.25V
                    3.29V
                    What blows the f2 -5amp fuse on this board
                    • RICHARD REISNER
                      • Jun 2016
                      What blows the f2 - 5amp fuse on this Visio board?
                      • Super360
                        Vizio E701i-A3 Vizio logo flashing then turns off
                        by Super360
                        Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                        07-25-2024, 07:06 PM
                      • noipi
                        DELL INSIPRON 14 No power blinking orange/white
                        by noipi
                        i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
                        05-06-2025, 08:08 PM
                      • jorpec
                        HP Elitebook 8460p battery led white and blinking orange
                        by jorpec
                        Hello everyone
                        I have this Elitebook that wont turn on, only the battery led is white and blinking orange, does this even without battery.
                        If this is a error code i couldn't find any info about it.
                        Already tested with a another charger, measure the presence on 19v on the 19v rail, checked if there was capacitors in short-circuit
                        Thanks...
                        05-05-2025, 04:39 AM
                      • x_orange90_x
                        Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                        by x_orange90_x
                        I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                        12-28-2023, 06:26 AM
                      • JaquesPratt
                        Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                        by JaquesPratt
                        I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                        This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                        07-16-2024, 01:04 AM
