Sony Bravia KDL-46V4100 power off itself
  • gabik111
    ORD spotter
    • 142
    • USA / Poland
    Hi guys.
    I got tv set Sony Bravia KDL-46V5100 that powering off itself. This is random shut down. Sometimes it works long sometimes 3-5 minutes. I entered to service menu and found that T-Con board has 15 errors and backit 3 errors. After reset errors tv was working some time and then shut off. Then I checked error log again and t-con board failed. Like month ago it shut off only backlit and after that it was difficult to turn it on so I reset it by remove main plug for half an hour.
    In this case looks like t-con board does not working properly. Is this common issue of this model? I found some reviews that this series have faulty LCD's too so my question is : is the t-con biard bad or LCD panel failed?
    Please advice and also where is a good place to buy working t-con board if so.
    Thanks for any help.
    Gabe
    Laptops and computers repair.
    Re: Sony Bravia KDL-46V4100 power off itself
    Did you already try re-seating the LVDS cable on the T-CON side and on the main board side?
    • gabik111
      ORD spotter
      • 142
      • USA / Poland
      Re: Sony Bravia KDL-46V5100 power off itself
      Not yet. I'm planning to do it before buy anything. Also will use isopropyl alcohol to clean connectors. Thanks for reply.
      • gabik111
        ORD spotter
        • 142
        • USA / Poland
        Solved. Cleaning and reseating LVDS cables did not change anything. Replaced t-con board solved problem. Tv works as new. Thanks everyone for help.
        • rustytierod
          • Sep 2014
          • 81
          Having the exact same problem, is there anyway to diagnose the tcon?
          • heavymachines
            • Mar 2011
            • 1028
            Read the op it says something about going into service menu and there it tells you it is bad it has ability to self test tcon.... Need to figure out how to get to service menu.
            Watch this https://www.youtube.com/watch?v=7hnrODX50Go
            • heavymachines
              • Mar 2011
              • 1028
              Also try reseating LVDS...
              • rustytierod
                • Sep 2014
                • 81
                Cannot get TV on for more than couple seconds, 2 seconds of which there is back light with blank screen.
                I tried disconnecting the LVDS cable at TCON while screen was blank as suggested somewhere else with no disturbance in blank image. Is this indication of bad panel?
                Also, if I disconnect the two connectors to the inverter and LVDS and power on, I get the same thing, no back light blank screen of course. Could the power supply be defective as well as the panel?
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Need good clear sraight on pictures of back of tv with cover off and each board.
                  Need voltages from connector that goes from power supply board to main board. Will need pin#-pin label-Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
                  Format:
                  Pin# - Pin Label - Pin Voltage standby - Pin voltage power on
                  1 - XXXXXXX - XXv - XXXv
                  2 - XXXXXXX - XXXv - XXXv
                  3 - XXXXXXX - XXXv - XXXv
                  4 - etc.
                  • rustytierod
                    • Sep 2014
                    • 81
                    It's a 46V5100
                    1 - REG 12V - 0v - 11.9v
                    2 - REG 12V - 0v - 11.9v
                    3 - REG 12V - 0v - 11.9v
                    4 - REG 12V_GND - 0v - 0v
                    5 - REG 12V_GND - 0v - 0v
                    6 - REG 12V_GND - 0v - 0v
                    7 - UNREG_15V_GND - 0v - 0v
                    8 - UNREG_15V_GND - 0v - 0v
                    9 - UNREG_15V - 0v -15v
                    10 - UNREG_15V - 0v - 15v
                    11 - STBY 3.3V - 3.3v - 3.3v
                    12 - AC_OFF_DET - 3.3v - 3.3v
                    13 - POWER_ON - 0v - 3.38v
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Is tv actually shutting down or are the backlights turning off. Your voltages suggest that tv is on. Backlights may just be shutting off. See any image on screen with flashlight?
                      • rustytierod
                        • Sep 2014
                        • 81
                        I get back light for a few seconds. Hear relay click and turns off then on again. Any attempt to unplug the t-con does not result in disturbance of image. However with the t-con and inverter disconnected the TV still power cycles. It definitely turns off and then on again
                        • rustytierod
                          • Sep 2014
                          • 81
                          On second inspection I noticed this raised cap on main, apologies as I'm having trouble with my upload software
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            What is voltage on main cap?
                            • rustytierod
                              • Sep 2014
                              • 81
                              Getting about 864
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                Typo? not possible
                                • rustytierod
                                  • Sep 2014
                                  • 81
                                  Whoops I meant 390 on, 163 standby. See my previous post with smd caps.
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    They do look bulged. I would replace.
                                    • rustytierod
                                      • Sep 2014
                                      • 81
                                      Can I substitute leaded? Correction it is not power cycling just turns off once back light shows for 2 seconds.
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        I would replace caps first and go from there if it doesn't fix problem. Regular 220uf 25v will work
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • swrb898
                                          Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                                          by swrb898
                                          What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                                          Problem:
                                          Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                                          My troubleshooting got me this far:
                                          With the left-hand TCON to bottom-board ribbon cable...
                                          12-28-2021, 08:12 PM
                                        • iglitare
                                          Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                          by iglitare
                                          i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                          Backlight seems to work, Sound (Setup menu after reset) works.
                                          If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                          Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                          With my small knowledge i would think at least the cables are good.
                                          Can this happen because of a bad tcon board?
                                          Or is it always a bad/shorted...
                                          09-04-2025, 07:13 AM
                                        • PopsCaps
                                          Sony Bravia KDL-40V2500 that will not power on
                                          by PopsCaps
                                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                          I do not hear any sound and I cannot see any backlight.
                                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                          03-25-2025, 11:23 AM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
