Sony KDL 52w5500 No image, no Backlights
  • goulloux
    • Mar 2014
    • 52
    • goulloux
    Hi, I've a more global question compare to my current problem (post link)
    When you start your TV, you don't have any image or light but you do have sound.
    What would be the reason for loosing the backlights (inverter problem) and the image (T-Con problem) at the same time ?
    The only common point would be the Powser Supply board ?
    Or maybe the logic board ? I've read that the logic board is suppose to send the signal to the inverter to lit the backlights.
    I still have sound though ...
    Can an inverter board problem impact the T-Con board ? (and inverse)
    My points is that many people have suggested to me to change my t-con or inverter, but it just don't make sens to me ...
    Hope anyone can help me and point me to the right direction.
    Re: Sony KDL 52w5500 No image, no Backlights
    It can be the main board is not sending the switch B+ to feed the T-CON board or the T-CON board SMD fuse may be blown, as for the backlights, you may have bad inverter circuits, lamps, or the main board is not sending the signals to turn on the backlights.
    Do you see any LED flashing the error codes?
    • goulloux
      • Mar 2014
      • 52
      • goulloux
      When I power up the TV, I got no lights, no image, just sound. Then the TV turn off and I got a 13 blink then 14 blink and it keep on 14 then.
      I understand what you say, but what would be the odd to have a T-CON failing at the exact same moment as the Inverter ?
      Except if you tell me that a T-CON problem can impact the inverter (or reverse).
      This is why I'm guessing this is a more about power supply or logic board (this is the main board right ?) problem
      • tibimakai
        • Jan 2012
        • 3680
        Did you use a flashlight, to see if there is anything on the screen?
          We will have to look up the error codes for this chassis.
          • goulloux
            • Mar 2014
            • 52
            • goulloux
            @tibimakai
            Yes, I did check with a flashlight, nothing
            @budm
            Where can I found the chassis reference ?
            Here a link to all the reference i Found on the TV's chassis but there's so many that I can't really says which one is relevant
            http://entrepot2.free.fr/chassis.JPG
            Is it not possible to deduce from what I said (no backlights, no lcd screen) that either the power supply or Main board are at fault ?
              That is the panel sticker P/N. Still searching ELEKTROTANYA.COM
                *HE11 datasheet, might be close enough
                  http://elektrotanya.com/?q=showresul...oria=&kat2=all
                  EX2L-BASIL may be close to your TV.
                  I would download all 3.
                  You may want to read the PDF attached, not the same chassis but the same principles.
                  I believe I wen through the same stuff with tibimakai.
                  https://www.badcaps.net/forum/showthread.php?t=34262
                  • goulloux
                    • Mar 2014
                    • 52
                    • goulloux
                    I did already had those documentation
                    It does feel a bit odd that al screen size are there except mine :s
                    Mainly in those documentation, you can see that there's only one inverter board
                    I got 2 + two intermediate board ... not sure what they are for.
                    I did unmount the T-CON, Power supply board and the logical board to check if there's anything strange on it but they all seems fine ...
                      They are master and Slave.
                      Does you TV look anything close what is shown on page 68 of the CTV-45 EX1 traning manual?
                      "It does feel a bit odd that all screen size are there except mine :s" What do mena by 'S'?
                      Pictures of your TV so we can see what we are dealing with?
                      • goulloux
                        • Mar 2014
                        • 52
                        • goulloux
                        Yes quiet close
                        http://entrepot2.free.fr/global.jpg
                        Ok, I'm starting to understand the difference with my screen thx to the training manual
                        For small screen balancer and Inverter are on the same board
                        And since my screen is too big, those are separated, the balancer would be the long board and the inverter the intermediate board ?
                        • goulloux
                          • Mar 2014
                          • 52
                          • goulloux
                          Humm this is the first manual that I see that is treating about the "special" case of 52" screen that have two balancer/inverter
                          In this manuel, 14 blink says that it's a HFR problem which is a component of the LCD screen ... if this is accurate and applicable to my screen, I guess it's game over :s
                          Any one to confirm that this guide is accurate for my 52w5500 ?
                            Yes. You can use the CTV-45 as the guide to find, also read the link on post 9 on the other thread (tibimakai) which turn out to be bad inverter board. It took us awhile to figure that one out after reading the training manual many many times.
                            • goulloux
                              • Mar 2014
                              • 52
                              • goulloux
                              yes I had read this post few days ago.
                              The tv seems to be design in the same way.
                              But in my case I don't have any backlights (well, I haven't unmount the LCD screen, but I'm guessing that I should be able to see the light coming out from the LCD screen right ??)
                                You should at least see the backlights flash on for seconds before it goes into shutdown.
                                • goulloux
                                  • Mar 2014
                                  • 52
                                  • goulloux
                                  Nop, I dont get any response from the backlights at any moment. I did the test quiet some time. (Still with the LCD panel mount)
                                    OK, I will need the GOOD CLEAR closed up pictures of the small white connector on the Balancer boards, and the closed up pictures of the master inverter, slave inverter, the power supply boards. The pictures must be clear enough for me to read the labels on the connectors so we do some testing of the signals on the connectors.
                                    • goulloux
                                      • Mar 2014
                                      • 52
                                      • goulloux
                                      Hi budm, thx for your help, it's really appreciated!
                                      So here it is: http://entrepot2.free.fr/tv/
                                      There should be all the pictures in HR(a bit heavy ...)
                                      As for the balancer's connector I wasn't sure of which one you were talking about (well I guess the smaller one connected to the inverter)
                                      So I split the balancer board in 2 pictures in HR so it should be enough to see (the voltage ?)
                                      • goulloux
                                        • Mar 2014
                                        • 52
                                        • goulloux
                                        Not sure if this can help but this service manual feels like a bit more closer to my screen
                                        • caseyjay_48
                                          Sony KDL-46BX450 Inverter Troubleshoot Logic
                                          by caseyjay_48
                                          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                          09-23-2022, 08:08 PM
                                        • x_orange90_x
                                          by x_orange90_x
                                          01-29-2025, 09:24 PM
                                        • domix
                                          Sony KD - 65XF9005 - No image, sound OK
                                          by domix
                                          at tv KD - 65XF9005 i have a problem.
                                          Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                          is this a common problem for this tv?
                                          i attached pictures of inside. Supply board looks okey, no blowed caps....
                                          07-21-2025, 06:37 AM
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Dreamcazman
                                          Sony KV-XJ29M31 CRT TV - Very dim image on turn on
                                          by Dreamcazman
                                          Hi all, I recently picked up a Sony KV-XJ29M31 CRT TV (BG3R chassis, Australian model) cheaply & completed the RGB mux mod on it for some retro gaming. That worked great, however, I have another problem which I hope someone can help me with or at least steer me in the right direction.
                                          Basically, the issue is when it's cold, it takes a while (like 2 mins) for the picture to come up. I think the image is there, it's just very dark or dim. I can hear the degaussing sound & I can change inputs & hear audio but no image.
                                          Once it's running properly, it keeps...
                                          02-28-2022, 07:47 PM
