Sony KDL 52w5500 No image, no Backlights
  • goulloux
    • Mar 2014
    • 52
    • goulloux
    #61
    Re: Sony KDL 52w5500 No image, no Backlights
    Oh ok, then I'll wait a bit more before rushing this buy ^^
    So from what I understand the diagram show that there's other switch on the inverter board, right ?
    But the signal is going from the [Main board] => [Power supply Board] => [Inverter] => [Balancer]
    Since I did not see any signal from the [Main board] to [Power supply Board]
    The inverter should not be relevant ?
    Or am I missing something ?
      The signals from the main board (BACKLIGHTS and Dim) are routed through the G5 power supply connector and out through another connector to get to the D5 inverter board.
      On the G5 power supply board, there is the circuit that can lock out the BACKLIGHTS signal (using OPTO, part of the AC detect which we have already verified that it is OK), then on the D5 board, there is also circuits that will lock out the Backlights signal if the Balancer board error.
      So at this point I am not 100% sure if the problem is on the main board or in the D5 Inverter board. We will have to disconnect the protection circuit to find out.
      • goulloux
        • Mar 2014
        • 52
        • goulloux
        #63
        And if we take in account that the T-CON is not working either
        Can the inverter board have an impact on that ?
        • audiofreak19
          • Apr 2013
          • 556
          • usa
          #64
          On mine I checked the fuse on the t con and it got 12v on the main fuse. But that's as far as I went on that.
          • goulloux
            • Mar 2014
            • 52
            • goulloux
            #65
            But do you get any image on screen ? (in case you don't know it, the LCD may still show a really dark image on the LCD screen, you may need to use a flashlight to see it)
            • stretchstudebaker
              • Mar 2014
              HFR is the High Frame Rate convertor, located under the T- Con.
              The inverter pcb should have a pin marked inv/on or something similar. This will almost always be a high (sometimes only 2.9 volts or so) and tells the invertor circuit to fire the lamps. The hfr/t-con pcb must be operational before the main CPU puts out the "on", If the on is there, the problem is invertor or lamps. BE careful if you have operational uncovered invertors. Get too close to a transformer or lamp connection and the first thing you'll notice will be the smell of burning flesh (yours)!!! Consult SM or TM for loacation of test points.
              • goulloux
                • Mar 2014
                • 52
                • goulloux
                #67
                Hum, will it imply some soldering ? :s
                • goulloux
                  • Mar 2014
                  • 52
                  • goulloux
                  #68
                  I have another question poping in my head and this must be realy basic electronic stuff:
                  Should I be able to see the backlight signal going through the power supply board even if the inverter lock the signal after ?
                  Basically the question is does a signal can be fired if the circuit is lock somewhere.
                    There is lock out circuit on the master inverter board and also on the power supply board, we have already verify that it is not the opto on the power supply board, so you can disconnect the cable between the power supply board and the master inverter board to see if the BACKLIGHTS signal will be present on the power supply board or not.
                    • goulloux
                      • Mar 2014
                      • 52
                      • goulloux
                      #70
                      Are you talking about the CN6702 (I guess) or the CN6600 on the inverter (master)
                        Yes, the CN6702 on the master inverter board.
                        https://www.badcaps.net/forum/showth...t=36482&page=3
                        • goulloux
                          • Mar 2014
                          • 52
                          • goulloux
                          #72
                          ALright just did the test, no change
                          I don't see any signal going through
                            Do you still get the 13X and follow by the 14X codes when the cable is disconnected?
                            • goulloux
                              • Mar 2014
                              • 52
                              • goulloux
                              #74
                              Yes, I just chek
                                I am running out of idea to verify for sure if it is the main board problem or not, per post 66, "The hfr/t-con pcb must be operational before the main CPU puts out the "on"" then I would expect to see 14X code first before code 13X.
                                • goulloux
                                  • Mar 2014
                                  • 52
                                  • goulloux
                                  #76
                                  Well maybe this is a FILO stack of erros (first in last out)
                                  And if
                                  "The hfr/t-con pcb must be operational before the main CPU puts out the "on"" is accurate, that would mean that you can't have backlights witchout a working T-CON ?
                                  I feel like I have read some people saying that they were geting backlights but a black image (T-Con problem)
                                  • goulloux
                                    • Mar 2014
                                    • 52
                                    • goulloux
                                    #77
                                    Otherwise, is there any way to test the HFR ?
                                    I've read that this part is inside the LCD screen ... and if it's the problem you should change your tv ^^
                                      It is part of the T-CON board.
                                      • goulloux
                                        • Mar 2014
                                        • 52
                                        • goulloux
                                        #79
                                        I can't find where I read about this HFR being inside the LCD panel and not the T-CON...
                                        Is there any way to test the T-CON
                                        I have done the test to unplug / replug the T-CON connector to see if there's any reaction
                                        But nothing
                                          Can you show the picture of the T-CON and model number of the LCD panel?
                                          • caseyjay_48
                                            Sony KDL-46BX450 Inverter Troubleshoot Logic
                                            by caseyjay_48
                                            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                            09-23-2022, 08:08 PM
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • NSkyLab
                                            Sony XBR-65X900F black and white image on one side (fading saturation)
                                            by NSkyLab
                                            I though I've seen all possible kinds of failures but this one is new...
                                            Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
                                            I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
                                            Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?...
                                            Yesterday, 07:37 PM
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:20 PM
