Cap exploded...help required. Philips LCD 42PFL5404H/05
  • rakonja
    PHILIPS 42PFL7008k/12 HARDWARE UPGRADE(REQUIRED HARDWARE/EXPERIENCES)!!
    by rakonja
    Hello everyone! I am the owner of a Philips 42PFL7008k/12 TV! It served me well all the years. Sometimes it used to get "stuck", after which I used to disconnect it from the voltage, hold the power button on the device for about 30 seconds, and after turning it on again, it worked like new!Only once it threw something like no software!Now it happened that it won't turn on anymore, the red LED blinks twice!Do you have any suggestions? They are probably not cost effective to repair, but I am sorry to get rid of it, it has served me well and looks like new!The only downside is the slow...
    09-07-2023, 09:50 AM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    Today, 03:43 AM
  • aidanmo
    Philips 43PUS7506/12 - Loud blown out sound
    by aidanmo
    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
    I thought maybe the speakers got damaged, so I replaced them - no dice.
    • Using the internal speakers, it always happens.
    • Using the headphone jack, it never happens.
    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
    02-28-2025, 03:13 PM
  • Cornito
    Philips 50PUH6400 bad color and gosting / slow motion on one side
    by Cornito
    Hello Team,
    New issue on LCD panel where I need to find out the cause and the potential solution.
    This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
    I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
    When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
    I've checked voltages, no issue found comparing right and left side of the panel driver.
    VHG VGL CKV... are the sames on...
    03-08-2024, 06:41 AM
  • spantor
    Activate power board Philips 40PFH40009/88 tv
    by spantor
    Hello partners.
    Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
    The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
    02-11-2024, 05:07 PM
