Sony KDL-46NX700 Led does not stay on
  • PowerAmpFreak
    • 982
    • Sweden
    Hi all.
    This Sony led-tv model 46NX700 does not stay on more than 30 seconds at a time. It shows a good picture and sound during this period.
    Then exactly after 30 seconds it shuts down and re-starts.
    Front led does not flash either.
    Mostly working on Samsung's, would need help with this dude.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony KDL-46NX700 Led does not stay on
    I have repaired a similar one, the 720 model and it was the LED driver board(one driver IC).
    There are some test points on that board, you can see if there are any differences between them.
    Mine, didn't reboot if I remember correctly.
    • PowerAmpFreak
      • 982
      • Sweden
      Do you mean the PSU board, containing the LED driver?
      See attached...
        It looks like your power supply board also contains LED driver circuits.
        • djluis
          • 12
          need schematic for aps262 power supply used on this model.
          • mauda
            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
            by mauda
            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
            05-21-2023, 11:56 PM
          • tec3000
            Sony LED 65X9005A shuts down after few seconds - looking for help
            by tec3000
            Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
            I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
            03-20-2024, 07:29 AM
          • ravi_1617
            VBU30 LA-9223P ,stay on for 5 seconds,
            by ravi_1617
            Hi to all.
            This HP board LA-9223P stays on for not more than 5 seconds,
            Problem no V-core power .
            PL302 3.3+3VALWP OK
            PL303 5+5VALWP OK
            PL402 1.5 VP OK
            PL602 1.8 VSP OK
            PL5021.08 VCCP OK
            PL1002+1.5V_PCIEP goes to 1.2-8 Mil volt
            PL204 .7 Mil VOLT+VGFX_CORE
            PL202 2.2 mIL Volt +CPU_CORE
            Please Help
            https://www.badcaps.net/forum/troubl...eed-schematic-...
            02-05-2025, 09:36 AM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
          • ravi_1617
            Sony MBX-223 ,M971 , Shutdown after 40 seconds
            by ravi_1617
            Hi.! This Sony board turns off after 40-42 seconds.
            (with adaptor/battery or both)
            Don't turn on until 20 seconds,
            If I disconnect Power immediately when off,than I can turn on, than again stays on same time, aprox 40 seconds
            Did changed ,
            thermal paste, CPU.
            Flashed bios also.
            fan heatsink also clean
            Before turning off fan also turns on.
            Any points I am missing
            08-31-2021, 11:42 PM
