Sony MBX-223 ,M971 , Shutdown after 40 seconds
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 350
    • India
    Hi.! This Sony board turns off after 40-42 seconds.
    (with adaptor/battery or both)
    Don't turn on until 20 seconds,
    If I disconnect Power immediately when off,than I can turn on, than again stays on same time, aprox 40 seconds
    Did changed ,
    thermal paste, CPU.
    Flashed bios also.
    fan heatsink also clean
    Before turning off fan also turns on.
    Any points I am missing
  • mikailcoban
    • Aug 2014
    • 73
    • turkey
    Re: Sony MBX-223 ,M971 , Shutdown after 40 seconds
    Did changed ,
    thermal paste, CPU.
    Flashed bios also.
    https://www.alisaler.com/sony-vpceb3...x-223-bios-ec/
    burdaki bios ve ecc cözdü
    write kbc bios please
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Having exact same issue on very same motherboard-sony mbx-223 M971 rev 1.1. Clean me bios flashed, ec bios also flashed. there is display on screen but shutsdown in 30-40 seconds. Has anybody solved this??
      PS: As per some russian forums, its me region of bios but i've already tried clean me bios. Just want few opinion before going ahead with PCH replacement. CPU/RAM swapped with known good.Heatsink cleaned,Fan perfectly working.
      • guruji
        • Oct 2012
        • 124
        • India
        I have the same model and the moment i press power it turns on for 2 sec and shuts off. there is no shorting in any aux power rails. I read one post where if i disconnect the resistor to memory enable the laptop remains on for every but i dont get cpu voltages or ram voltages.But again changed the memory chip smsp same problem.Something to do with sony protection circuit for some models.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          @guruji, your case differs with op's case as he gets all voltages, mb boots and then shutsdown in 40 secs.
          If you cut the power to memory, cpu core/gfx core wont rise. So it means you either have problem in ram circuit or VCore circuit. Very likely, not a protection issue here.
          • guruji
            • Oct 2012
            • 124
            • India
            i have changed the ram dc-dc controller still same issue.this is like a common issue with this model.
            • marian.pigna
              • Oct 2023
              • 12
              • Argentina
              did you manage to solve it? thanks in advance!!
              • marian.pigna
                • Oct 2023
                • 12
                • Argentina
                Did changed ,
                thermal paste, CPU.
                Flashed bios also.
                did you manage to solve it? please I need help! thanks in advance!!
                • mauda
                  Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                  by mauda
                  I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                  Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                  05-21-2023, 11:56 PM
                • tec3000
                  Sony LED 65X9005A shuts down after few seconds - looking for help
                  by tec3000
                  Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                  I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                  03-20-2024, 07:29 AM
                • sew333
                  Pc shutdown, monitor flickered with no signal after 10 seconds
                  by sew333
                  My pc:
                  10850K stock 4800mhz stock Kraken X73 good temps
                  2x16 GB DDR4 GSKILL 3000mhz XMP
                  Seasonic Tx-850 Ultra Titanium
                  Gigabyte Rtx 3090 Gaming OC
                  Aorus Z490 Pro Gaming
                  1 TB SSD
                  4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                  Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                  Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                  Power...
                  02-22-2022, 10:27 AM
                • DrFalken
                  Dell Inspiron 5593 shutdown after 5 seconds
                  by DrFalken
                  Hello everyone!
                  Motherboard model: FDI55 LA-J081P
                  Today a customer delivered this laptop completely dead, with the original power supply shorting when plugged into the connector.
                  I found and replaced a shorted MOSFET (PQZ3).
                  Now the laptop turns on (fan runs fine but no video signal) and after 5 seconds it turns off.
                  BIOS has already been updated (both 64MB and 128MB IC)
                  +3VALW and +5VALW are still present.
                  +VCCIN = 1.8V stable (measured on PLZ1 at power up)
                  Abnormal readings:
                  PLZ1 to GND = 0 Ohm
                  PLZ2 to GND = 0 Ohm
                  04-09-2025, 10:45 AM
                • rex98
                  Msi b250m bazooka shutdown after few seconds
                  by rex98
                  Does anyone here encountered the same problem i have on this motherboard? It shutdown after few seconds PCH is hot. The bios is fine. All voltage signals are normal it just shutsdown when it turned on a few seconds like 30sec the logo shows up ang bios settings shows the pch heats up then shutsdown itself. Can someone help me. I need schematics and boardview of this motherboard....
                  04-09-2023, 09:27 PM
