VBU30 LA-9223P ,stay on for 5 seconds,
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 351
    • India
    Hi to all.
    This HP board LA-9223P stays on for not more than 5 seconds,
    Problem no V-core power .
    PL302 3.3+3VALWP OK
    PL303 5+5VALWP OK
    PL402 1.5 VP OK
    PL602 1.8 VSP OK
    PL5021.08 VCCP OK
    PL1002+1.5V_PCIEP goes to 1.2-8 Mil volt
    PL204 .7 Mil VOLT+VGFX_CORE
    PL202 2.2 mIL Volt +CPU_CORE
    Please Help
    https://www.badcaps.net/forum/troubl...12#post1012912
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    MB is LA-A992P or LA-9223P as shown in title?
    Check SUSP# signal. If it is zero, very likely SOC balls are dry and/or SOC is bad.
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 351
      • India
      Thanks for you Reply ,while posting 1st time ,came to know about this power problem.(PL1002+1.5V_PCIEP goes to 1.2-8 Mil volt) this are was corroded ,
      Cleaning / resoldring this area ,board started
      Thanks,
      • twonk9098
        Lenovo Legion 5 high fan spin turns off after 34 seconds
        by twonk9098
        I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
        I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
        I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
        I have tried a few new bios but exactly...
        07-14-2024, 11:19 AM
      • gabri2211
        external hd Seagate, broken down the +12 volt and USB 3.0 SATA board
        by gabri2211
        Hi to all 😎
        I'm looking for any useful information to repair this interface (I have attached the image).
        On this board I read E3215-1215A_4D.
        This is the small plate inside the HD enclosure that allows to connect a 12 volt power supply, interface the disk with a USB 3.0 socket and is connected to the HD with the SATA connector.
        If any of you have found a burnt or short-circuited component in a circuit like mine​, if you have useful diagrams for the repair, or even better a description for the tests at the test points, I would be very grateful.
        in particular...
        11-12-2024, 08:08 PM
      • liquidzorch
        Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
        by liquidzorch
        Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
        10-18-2024, 05:19 PM
      • Yanleb
        Sharp LC-60LE810UN Lamp Error
        by Yanleb
        I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
        I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
        Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
        I've tried all the key...
        08-24-2021, 11:48 PM
      • Rick_1234
        by Rick_1234
        Good evening, gentlemen.
        Things I tried
        06-22-2024, 04:44 PM
