Pioneer PDP-435PU, no picture after 10 seconds
  • beurjean
    • Mar 2014
    • 6
    • Nederlands
    Hello I have the following problem. When I make the room dark and I see something I lit him with a big black blur in the middle turn on the TV and text that can not be read at the top left corner. This he hold a full 10sec and then falls back to black screen.
    Voltage on the power supply is good. There should be 215 volts to go from the power board? Drive to the x-and y-drive This comes on the second count, but then falls back to 10volt very quickly.
    The capacitors look good on the eye. I did not know much about TVs and measuring components but would like to learn from and fix the problem here.
    http://s3.amazonaws....43_img_0793.jpg
  • beurjean
    • Mar 2014
    • 6
    • Nederlands
    Re: Pioneer PDP-435PU, no picture after 10 seconds
    can everyone read this text or is it a bad translation
    • philliesfan30m
      • Aug 2013
      • 542
      pic isn't found and if you tried to turn a pioneer tv on with the back cover off they have a protection switch which will put it into a protect mode and you have to reset it with the original remote. i personally don't understand what you are saying about a blur or blotch in the screen might be a bad panel. take pictures of the fault and of the whole back of the tv with the cover off and each individual board so we can see them.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Originally posted by beurjean
        Looks like a typo on your link.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        "Β‘Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -MΓ­ mismo
        • Fred53
          • Mar 2014
          • 33
          Found this on a dutch site http://www.sat4all.com/forums/ same user name
          link typo correct URL for picture.
          http://s3.amazonaws.com/f01.justansw...3_img_0793.jpg
          I don't like to leave a job I started unfinished
          • beurjean
            • Mar 2014
            • 6
            • Nederlands
            I have no remote control.
            I only see a black screen light up for 10 seconds.
            And in the upper left corner a text what i can't read.
            There must be 215 volt on the x and y-drive.
            The 215 volt allows 10 seconds on the x and y-drive.
            but falls very quickly back to 8 volts.
            • paulstef
              • Dec 2013
              • 724
              Any flashing red or green LED on the panel or media unit once it turns off?
              • beurjean
                • Mar 2014
                • 6
                • Nederlands
                The Green and the Red led burns
                • paulstef
                  • Dec 2013
                  • 724
                  You do have the service manual, right? At what intervals do they turn on/off? How often? Or are both constantly on??
                  • beurjean
                    • Mar 2014
                    • 6
                    • Nederlands
                    I have the service manual from internet.
                    When i turn on the tv the green led at the front is on
                    And the red en green led at the media unit ar both constantly on.
                    When the tv turns off the red led at the front is on (constantly)
                    And the red led at the media unit is on. (constantly)
                    I don't have a media reciever i'm using a ps3
                    • paulstef
                      • Dec 2013
                      • 724
                      Found this one too. Field service guide for your plasma TV.
                      • JJAAMM
                        by JJAAMM
                        Problem
                        07-06-2023, 06:01 AM
                      • Tr0ll
                        by Tr0ll
                        Original T-con:
                        First replacement T-con:
                        10-07-2023, 07:48 PM
                      • PowerAmpFreak
                        Pioneer Kuro KRP-500 picture turns black
                        by PowerAmpFreak
                        This Pioneer Kuro KRP-500 plasma display has an intermittent issue in that it the picture turns black suddenly.
                        Sound works all the time.
                        Powerled is on all the time.
                        This set has a separate control box which for a few years had a similair problem which was fixed by replacing a number of voltage regulators.
                        Quite a common issue as fas as I know.
                        Question is: are there more of the notorius voltage regulators also inside the display unit which should be replaced?
                        Other advice?
                        There are not a common cause which makes the issue. Can work for two days,...
                        03-26-2022, 04:41 PM
                      • zklgfs
                        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                        by zklgfs
                        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                        08-11-2025, 02:14 PM
                      • twonk9098
                        Lenovo Legion 5 high fan spin turns off after 34 seconds
                        by twonk9098
                        I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                        I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                        I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                        I have tried a few new bios but exactly...
                        07-14-2024, 11:19 AM
