Dead dps-162kp-1 powerboard
This topic has been answered.
  • Danny kikkert
    • Aug 2024
    • 18
    • Nederland
    I have a dps-162kp-1 runtka932wjqz powerboard wich has no power at all on the cold side.
    I replaced ic7903, r7900, R7902, C7901, d7950.
    Checked the diodes around the chip and also the caps.
    On the ic pin 5 no voltage, pin7-8= 315V
    On the T7901 pin 1-4 no voltage, pin 2-3=315V
    Anybody have any idea where to look further?
    Any help is welcome
    Thanks Danny from holland
  • Answer selected by Danny kikkert at 09-10-2024, 04:01 AM.
    Danny kikkert
    • Aug 2024
    • 18
    • Nederland
    Originally posted by R_J
    Check the resistance of IC7903 pin 4 to 3, if it is not shorted, there may be a possible fault with ic7902 ac brown-out ic you might try removing J7018 near @5 and see if you get any vcc on pin 5 of ic7903, If you look at the datasheet you will see the startup vcc is generated by the ic internally and charges C7907
    In post #3 I said to replace C7918, that should have been C7907
    and as stated above, they may be fake ic's
    Did you mean to remove the @5 on the photo?, pin 4 to 3 is not shorted, the caps 7918 and 7907 are fine I checked them with an esr meter and multimeter.
    Greetings dannny
    • Diah
      • Feb 2013
      • 6399
      once i faced dead dps-162kp after repairing all parts on primary it remain dead.. then after taking the main transformer outside the circuit i found there are cut between the coil and standing pins.
      • R_J
        • Jun 2012
        • 9559
        The A6069H gets the vcc startup voltage on pin5 from an internal startup cell inside the ic, so you either have a short on pin5 or the new ic is bad, also replace C7918
        Pin 5 must have at least 15.3vdc for the ic to start
        Why did you replace r7900, R7902, C7901, d7950 ? were they bad, as that would give an idea what may have happened
        • nomoresonys
          • 12206
          • U.S.
          Maybe check out D7907.
          • Danny kikkert
            • Aug 2024
            • 18
            • Nederland
            The r7900 was blown, R7902 gave bad reading, the C7901 wasn't blown, but replaced (wanted to check out of cirquit, but fell on the ground and lost it some where in my barn) d7950 was shorted. Yesterday I replaced the ic with new one. Nothing changed.
            Cap 7918 and D7906 did look fine in circuitry, I Wil remove them and check them later on
            Thanks for the reply
            • lotas
              • Jan 2016
              • 4668
              • Russia
              The photo shows that the STR-A6069H is not the original (relabeling), but a fake.
              • nomoresonys
                • 12206
                • U.S.
                Does appear to be a fake, I don't recall that 5 in the real ones, where did you get it?
                • R_J
                  • Jun 2012
                  • 9559
                  • Danny kikkert
                    • Aug 2024
                    • 18
                    • Nederland
                    I don't know it for sure, I thought ebay
                    • Danny kikkert
                      • Aug 2024
                      • 18
                      • Nederland
                      Greetings dannny
                      • Danny kikkert
                        • Aug 2024
                        • 18
                        • Nederland
                        I just ordered new ones, just in case. Now from a shop in Germany.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4367
                          • Italy - Milan
                          Hi, about what R-J says, that IC7903 has startup current on pin 5, sound strange to me, i have not searched datasheets, based on photos, i see that Pin 5 takes current only from aux winding of transformer, usually those type of chips takes the startup from the primary winding of transformer, after the normal current on pin 5, i suggest Danny to check the original IC7903 for short on pins 1,8, if there is, check the R7907, the pink one near the big PFC inductor, it must be opened.. replace it and test the board, preferably with lamp in series..
                          PS: i see no signs of counterfeit, you can use the actual one for me..
                          • Danny kikkert
                            • Aug 2024
                            • 18
                            • Nederland
                            Thanks, I always test with a lamp in series, I desolderd most components in that area and tested them. They tested fine.
                            On the transformer I get B+ voltage on pin 2-3, but on pin 1-4 nothing, the trafo also has no shorts.
                            On the cirquitry of ic 7902 also everything tested fine but also there is no voltage.
                            Is it possible that the voltage needed for that circuit comes from ic 7801?
                            • nomoresonys
                              • 12206
                              • U.S.
                              Any update on this??
                              • Danny kikkert
                                • Aug 2024
                                • 18
                                • Nederland
                                Today I received new ic, I'll keep you updated
                                • Danny kikkert
                                  • Aug 2024
                                  • 18
                                  • Nederland
                                  so ive installed the new ic7903, nothing! i also noticed a shorted diode D7903.
                                  i gues the transformer is dead​
                                  • R_J
                                    • Jun 2012
                                    • 9559
                                    Why would the transformer be dead? did you replace the shorted diode and see if the supply works? D7903 is a 15 volt zener diode NZX15B.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4367
                                      • Italy - Milan
                                      Yes,.replace diode and replace completely transformer solder
                                      • Danny kikkert
                                        • Aug 2024
                                        • 18
                                        • Nederland
                                        idd replaced the diode with ann original.
                                        my electronics knowledge is a little poor so i guess that the te transformer have to deliver some voltage to pin 5 on the chip. but there is none!
                                        or should the cip deliver voltage to the transformer?
                                        on pins 2 and 3 i have normal voltage. on 1-4 none. when icheck with multimeter pins 1 and 4 have continuity.
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4367
                                          • Italy - Milan
                                          What model of tv we are talking of? Where do you got the chip? Is probably a fake , scrached surface.. try a different source an don't get the cheapest..
                                          • craig1410
                                            820-01700 (A2141) R7900 failed, power cycling after R7900 bridged
                                            by craig1410
                                            My wife's 2019 MBP died a couple of weeks ago and I have been trying to figure out what is wrong with it. I have an electronics background and equipment but never tried to diagnose a modern MBP before. I have the board view and schematics already and have been climbing the learning curve steadily!
                                            Initial fault was no power with USB ammeter showing 5.19V @ around 12 to 35ma. I won't go into all the initial debug I did because ultimately I found R7900 to be high resistance when it should have been a 0ohm link.
                                            So, going from the power sequence...
                                            04-28-2023, 09:14 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
