usp440m-42lp psu
  • joehezzer
    • Jul 2012
    • 251
    • England
    #61
    Re: usp440m-42lp psu
    still waiting for filter
    • paulstef
      • Dec 2013
      • 724
      Well if that's all there was you are very lucky.
      • joehezzer
        • Jul 2012
        • 251
        • England
        #63
        fingers crossed there is no other damage. the chap said he had a sparky round his house the week b4 sorting his house electrics out, then a week later he had a power cut because of the weather and the set never turned back on, fingers crossed there is no other damage
        • joehezzer
          • Jul 2012
          • 251
          • England
          #64
          ok so i have changed filter no joy, i must have tested something wrong somewhere or has blown old filter and something else. i have not had chance to test it properly yet. i did test the rocker switch and it tested ok but on closer inspection it looks a bit melted.
          when i plug the power cord in i can hear what sounds like a relay click from the area pictured and shorting sound if i can use that term
          • joehezzer
            • Jul 2012
            • 251
            • England
            #65
            Right ok test out put again and got 263v Ac atleast I have a reading this time lol
            • joehezzer
              • Jul 2012
              • 251
              • England
              #66
              Perfect. What's the voltage at the points indicated in the picture?
              37v AC
              • joehezzer
                • Jul 2012
                • 251
                • England
                #67
                37v AC from these
                • paulstef
                  • Dec 2013
                  • 724
                  37VAC is not enough, must be the same voltage as input AC voltage.
                  • joehezzer
                    • Jul 2012
                    • 251
                    • England
                    #69
                    • joehezzer
                      • Jul 2012
                      • 251
                      • England
                      #70
                      ok just double checked it got the same voltage as the input, 263v ac
                      • paulstef
                        • Dec 2013
                        • 724
                        Go right to the connector where it says 5VSB (CN801). Measuring DC you should have 5V.
                        Then connect a 1k resistor from 5VSB to RL_ON. The relay should come on and you should get 9V, 24V and 12V.
                        Then connect a 1k resistor from 5VSB to VS_ON. You should get about 190V VS and 60V VA. All DC.
                        • joehezzer
                          • Jul 2012
                          • 251
                          • England
                          #72
                          Just gonna have me dinner
                          • joehezzer
                            • Jul 2012
                            • 251
                            • England
                            #73
                            Ok not getting any voltage at all
                            • paulstef
                              • Dec 2013
                              • 724
                              check the measurements in the picture
                              the yellow part creates the 5V standby voltages
                              • joehezzer
                                • Jul 2012
                                • 251
                                • England
                                #75
                                Nothing from any.
                                • joehezzer
                                  • Jul 2012
                                  • 251
                                  • England
                                  #76
                                  Nothing from any of them. So probably need to pull off diodes and check em !!
                                  • paulstef
                                    • Dec 2013
                                    • 724
                                    No.
                                    Obviously the NCP1200 (8-PIN IC) is not oscillating.
                                    From cathode of D103 to heatsink, do you read high voltage DC?
                                    If not what do you read from the leftmost pin to the rightmost pin of the bridge rectifier BD101?
                                    • paulstef
                                      • Dec 2013
                                      • 724
                                      BTW, leave everuything disconnected from the board apart from AC IN of course.
                                      • joehezzer
                                        • Jul 2012
                                        • 251
                                        • England
                                        #79
                                        Voltage from cathode nothing .looking at the bridge rectifier from above the bottom pin 00.4 volts and the upper pin 00.5v dc
                                        • paulstef
                                          • Dec 2013
                                          • 724
                                          I don't understand.
                                          1st measurement: Put your multimeter probes on the 2 middle pins of BD101. Measure AC. What's the voltage?
                                          2nd measurement: Put your multimeter on the two outer pins of BD101. Measure DC. What's the voltage?
                                          • dicky96
                                            Need to buy buck regulator MP2329CGG but struggling to find supplier
                                            by dicky96
                                            Hi guys
                                            I need one of these MP2329CGG for a repair job. It's a 24V 6.5A buck converter. But I have not been able to find a supplier who has that component.
                                            Actually I would buy a few as I always think if I found one faulty already I will probably find more in the future
                                            I had one supplier on Aliexpress who gave me a price $2 each, but I have been waiting some days since I asked for shipping price and they don't reply
                                            Does anyone know where I can buy that part in small quantity (let's say 5 of them), or any equivalent I could use? it supplies the Standby...
                                            03-05-2021, 08:44 AM
                                          • Faileng
                                            Struggling with a soldering job, need help.
                                            by Faileng
                                            Hello, although I've never been formally taught soldering techniques, etc... I've not really run into too much trouble soldering, with the exception of this job...
                                            I've got a supposed blown transistor on my fuel pump on my car and I'm trying to replace it. It's a gel encased circuit booard with very fine connections. Please see photo uploaded.
                                            I've cleaned up the area that I'm working on with alcohol scraped off the wires, etc..
                                            I cannot get any solder to now stick any of the connections, I've used various grades of solder and flux combination, nothing...
                                            02-06-2020, 02:07 PM
                                          • yasin4286
                                            Alienware 17 R4 (6th gen) bios problem
                                            by yasin4286
                                            Hello friends. I have been struggling with this device for several months. The problem is that the laptop is 6th generation and every BIOS I find is 7th generation. In the BIOS settings, it says Kaby Lake in the integrated graphics. The graphics drivers are not installed properly in Windows either. I would be grateful if any of my friends could help me finish this laptop.
                                            Model : Alienware 17 R4 (6th gen)
                                            Motherboard : LA-D753P rev 1.0(A00)
                                            CPU: 6820HK​
                                            Today, 01:28 PM
                                          • TimScrawn
                                            A2337 820-02016-A Failing DFU mode
                                            by TimScrawn
                                            I have a very strange issue here. Customer was using Mac one day and stopped working when they went to use it the next day. I plugged it into my amp meter and I got 5v at 0.10amp.
                                            Checked all rails:
                                            PPBUS_AON: 12,3 V
                                            PP3V8: 3.79v
                                            PP3v3_AON: 3.29v
                                            PPDCIN_AON_CHGR_R: 5 V
                                            The very strange part of the issue is that I left the Mac on one side for a day, came back to it and reconnected everything. Connected the DFU cable to a WS machine and connected the charger. The Mac then booted to the login screen? I then logged in and because I was after...
                                            06-29-2025, 10:27 AM
                                          • Doesronnieevenlift
                                            Help a noob! Wson8 Pogo/Needle Adapters to read/Write
                                            by Doesronnieevenlift
                                            I had recently tried to reflash the bios on a dell latittude that has a Wson8 Chip however to no avail.
                                            My question is, Has anyone had much success using the Pogo/Needle adapters to read and write bios without removing the chip from the main board?
                                            I seem to struggling with the solder process wofh my reflow station and currently have 4 machines waiting for a bios mod/reflash.
                                            For context I have just ordered a EZP2019 SPI flash so this is what I would be using alongside the Pogo Adapter.
                                            Apologies if this is the wrong subcategory....
                                            06-22-2025, 04:51 AM
